Old 03-27-2012, 12:25 PM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by phbarnhart View Post
I know that your comment is directed at 1/2 ton subs and tahoes but the 3/4 ton Sub has leaf springs.
And an "active" suspension, Autoride, which improves ride quality a great deal but without the auto level feature of the 1500's.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-27-2012, 02:58 PM   #16
dznf0g's Avatar
Oswego , Illinois
Correct....the title of this thread is ....1/2 ton......
-Rich-
Old 03-27-2012, 05:18 PM   #17
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Oops, duh. ATQ, right?
phbarnhart is offline   Reply With Quote
Old 03-27-2012, 06:21 PM   #18
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
My 08 Tundra has plenty of power thanks to the 5.7L motor with 400 lb-ft of torque, a 4.3 rear end and a 6 speed transmission, and it has plenty of braking with 13.9" 4 wheel disc brakes. The weak link is the rear axle rating of 4,100 lbs. I wish there was some way to increase this, but I see no solution, easy or hard.
Dan
Old 03-27-2012, 07:57 PM   #19
2004 16' International CCD
Orem , Utah
I would think 1/2 suburban could barely handle it's own weight
While new 2012 ford f150 would do twice good job towing. Yota axles while small I have never heard a bad thing said about them. My nissan 1/4 ton comes with 9.3/4 ring axle forget code name but pretty dam stout. Kind of sad to look at old Rangers and S10s think dana 28 or something like that. Springs in toyota seem to be week link on older Tacomas saggy with little weight. You could always beef up yota Teraflex 60 now that's strong.
starcraft is offline   Reply With Quote
Old 03-27-2012, 08:21 PM   #20
dznf0g's Avatar
Oswego , Illinois
re. your title line.....you would think wrong, IMHO.
-Rich-
Old 03-27-2012, 08:33 PM   #21
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
The rules have changed
First,, there is a limit what a stock rear axle can handle.. Knew of a GMC 1/2 ton that had bent axle tubes from a over load.. Made a funny noise going down the road and wore the inside edges off the tires..
My research when I got my Dodge last fall,, it boiled down to less than 400 lbs difference payload between my HD 1/2 ton and a standard 3/4 ton.. UNLESS you shelled out the extra $7000 and got the Cummins package. Then the options list, weights and prices grew even more.
I went from the 3.55 gears for the 3.96 option and glad I did.. That alone moved my Gross trailer load up from 7500 lbs to 10,500 just that alone!
So yes one can add some air bags, or updated springs but it all boils down for what the axle bearings and housing itself can handle.
What I found about my HD 1/2 ton was a 4500 max lbs for the rear axle.. The payload is only around 1850lbs.. So there is room for a margin,, but you also have to allow for that huge hidden pot hole you always seem to hit when fully loaded..
As for frames,, do some research.. The newer Dodges use the same frame between the 1/2 and 3/4 ton..
Sodbust,.
Sodbust is offline   Reply With Quote
Old 03-27-2012, 08:46 PM   #22
mefly2's Avatar
2015 25' FB Eddie Bauer
Well ... we loved our 2005 F-150 buuutttttt... we like our 3/4 Ton MUUUUUUUUUUUUCHHHHHHHHHHHHHHHHHHHHHHHH better. We considered all of the add-ons for the F150/ triton to make it more suitable as a tow vehicle, but as has been already pointed out ... enuf said!
1/2 ton
SUV, not pickup to tow 25' airstream? cotons Tow Vehicles 22 03-12-2015 08:18 PM
Can 1990 1/2 ton 4x4 Suburban tow a 26 or 28 ft Airstream mudsummer Towing, Tow Vehicles & Hitches 7 03-09-2012 01:26 AM
My 1/2 Ton Numbers AirHeadsRus Towing, Tow Vehicles & Hitches 7 01-16-2012 08:11 AM
Newbie ordering a pickup - Which bed Length? GinMame Tow Vehicles 41 10-26-2011 09:41 AM
1/2 Ton Tow Vehicles brianw Tow Vehicles 39 09-08-2011 06:44 PM
