Old 11-24-2018, 07:49 AM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Engine blew up!
My boss has a brand new 2018 RAM 1500 with the 3.0 V6 turbo diesel and 18,000 kms (11,250 miles) on it. He tows a 14' box trailer partially loaded with furniture or millwork quite a bit for work purposes; but quite a few kms were put on going to northern Michigan this fall from southern Ontario to look at a boat; so, no not all kms towing.
Thursday night during that very cold blast, heard the engine develope a ticking noise, which grew louder upon depressing the accelerator; he backed off, looked at the gauges, which were in the green; decided to make it the rest of the way up the hill but the noise developed rapidly into a severe clunking, and then the engine seized.
Yes, he has had oil changes done, as the dealership is five minutes down the road.
It took a boat load of time trying to figure out how to get the truck out of gear once the engine is off, as the gear selection is tied to engine management. Supposedly there is a tether by the emergency brake that you have to pull; so look at your owners manual you Dodge truck people with the gear selector knob.
I will deliver updates once the dealership determines what happened.......
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 11-24-2018, 08:07 AM   #2
2017 30' International
Charlotte , North Carolina
Sounds like no oil pressure and spun rod bearings. Bad oil pump?
Al U. Minium is offline   Reply With Quote
Old 11-24-2018, 09:57 AM   #3
1971 27' Overlander
Kansas City , Kansas
Guessing why a modern diesel has failed. It will only ever be guessing. Chances are the dealership will probably only guess too, then put another engine straight from the factory into it.
Manufacturers don't like giving out details on why their new engines start failing until they can find the cause. Sometimes that takes a long time. Even then, it's in their interest to keep the real details from the public as best as possible.
Shermy1987 is offline   Reply With Quote
Old 11-24-2018, 10:19 AM   #4
weirdstuff's Avatar
2018 23' International
San Diego , California
This sounds similar to what happened to our friend about 6 weeks ago. Iím gonna send him the link to this conversation.
weirdstuff is offline   Reply With Quote
Old 11-24-2018, 11:37 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Not really a new engine...been around since 1947....gm and others use it..
Old 11-24-2018, 11:51 AM   #6
Dazed and Confused
Isuzusweet's Avatar
This I guess is not surprising to some....instead of praying your engine makes it to 200,000+; with the Ecodiesel, you pray it makes it past 30,000kms
https://www.wheels.ca/top-ten/seven-...ke-the-plague/
Cheers
Sidekick Tony
Old 11-24-2018, 12:33 PM   #7
VernDiesel's Avatar
Dayton , OH, 2017 33' Classic 8,561 dry
Yep I own one love it and have had great luck with it but too many have had this problem. The 2019 2nd gen is supposed to remedie this and more. Fortunately Ram replaces any blown ED with a brand new engine and balance of a 100,000 mile warranty.
Some now are also working a fresh 100,000 mile warranty into the deal. Probably not of much value for your friends new 18 but certainly of interest to someone who has say 90k at the time of failure. Ram will also pay for your tow and provide a rental.
Looking forward to seeing how the new GM inline 6 3.0 diesel does as well as the 2nd gen ED and the Ford 3.0 diesel. My understanding is that VM Motori first offered this from the drawing board up new engine in 2011 and the states in 2014.
Transportr AS & TT Mfg 2 dealr RAM ED factory brake controller tow mirror hitch camera & receiver 1,290/12k, No sway WDH, Adj. hitch, axle 2 frame air bags, tune w turbo brake, SLT Grill, 31.9" load tires, Max ED tow 9,200, GCAR 7,800, Max Ram 1500 GCVW 15,950, truck hitches steer 3,240 drive 2,560
VernDiesel is offline   Reply With Quote
Old 11-24-2018, 01:57 PM   #8
AirstreamJim's Avatar
2007 25' Safari FB SE
Lake Worth , Florida
I have the VM Motori 3.0L EcoDiesel in my 2015 Jeep Grand Cherokee and it blew up at 25,000 miles, a month after the 24 month limit on NY lemon law coverage expired. FCA replaced the engine under warranty and after a lot of b1tching directed at Auburn Hills, they gave me a lifetime bumper to bumper warranty.
This had (has?) been a common issue with these EcoDiesel engines; the RAM and Jeep forums are full of stories of catastrophic engine failure. I had hoped that FCA had figured out what was causing it and that my new engine wouldnít be susceptible to another failure. Hearing this about a 2018 vehicle is very disturbing. While Iím covered financially if it were to blow up again, the huge hassle I went through isnít something I want to experience again.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 11-24-2018, 02:07 PM   #9
1971 27' Overlander
Perhaps everyone should be installing the 1947 mode enginel into their trucks. It probably made 47hp. No more blown engines. Problem solved.
Old 11-24-2018, 03:26 PM   #10
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, it simply blew up because it was a "V-6" instead of an "Inline Six". [sarcasm]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 11-24-2018, 05:34 PM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Knock on wood.... Have 185,000 miles on my 2007 Mercedes 3.0L V6 turbo diesel in my ML320 CDI. Had a couple of gasket replacements in the engine valley that were past expensive on my dollar (way past my nickel). Change oil and and filter every 5,000 miles since new.
Recent versions of this engine have become more problematic for the Sprinter vans and MB cars with regeneration (wife's 2009 E320 Bluetooth) and Def fluid starting in late 2009 and 2010.
We have a straight six 3.2L turbo diesel in our 2002 Mercedes E320 station wagon we bought new in the UK with only 35,000 miles on it. Just now getting loosened up. Would love to bring the car over, but wife thinks I am not smart enough to drive a right hand drive car here.... It gets an oil & filter change annually regardless of miles driven (plus whatever else is in the maintenance cycle - more for time than miles).
Old 11-24-2018, 07:09 PM   #12
2013 28' International
Bozeman , Montana
Does it have the same Bosch fuel pump as the Ford 6.7 diesels? The one that apparently self destructs on a somewhat regular basis and send metal fragments through the fuel lines and injectors. I just heard about this problem the other day, started looking into it and found that there are many people that have been left with a dead truck, a 9-12k repair, and Ford not standing behind the problem. I am very concerned that our relatively new F350 could experience the same problem and leave us stranded in a remote area.
HeadWest is offline   Reply With Quote
Old 11-24-2018, 07:19 PM   #13
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
We have four Jeep diesels in our family. My 2008 CRD that I passed down to my son has 500,000 k on it. Towed a 25 and then 30 for 300,000 k. It's a daily driver now but increasingly unreliable. My other sons 2008 CRD is on its 3rd engine with 165,000 k . It's a piece of junk. My current ECO Diesel just imploded at 190,000 k . No warrantee but I had a long block installed. Apparently a bearing associated with a cam fell off. The bearing ended up in the oil pan. No help from Jeep due to mileage but I did ask given the abnormal failure rate on these engines. My wife's ECO diesel works great but a number of other parts have been replaced under warrantee. My point is you just never know what lurks under the hood and the thing is going to break eventually. Sort of like our bodies.
Jim Flower is offline   Reply With Quote
Old 11-24-2018, 10:28 PM   #14
St Augustine , Florida
158k miles on my Jeep CRD. No problem yet but reading with interest to the thread.
Textdocs is offline   Reply With Quote
Hail Storm Just Blew Through DEITZ645 Off Topic Forum 8 03-30-2009 05:41 AM
Tire blew causing trailer damage RUSSELL Tires 1 11-02-2007 04:20 PM
WOW....I just blew past 2000! lewster Off Topic Forum 23 10-04-2007 11:14 AM
blew my 110V breaker - where is it wavemaster Electrical - Systems, Generators, Batteries & Solar 3 10-24-2006 08:33 AM
tire blowout blew hole in wheel well munimula Roof 16 06-03-2006 11:05 AM
