Old 05-20-2016, 07:09 PM   #1
Sioux Falls , South Dakota
E250/350 vs F250/350
As I sit here, there is an E350 van parked outside. As I look at it, I see that the distance from the rear axle to the bumper appears to be less than that of a pickup. Since everything that is now in the basement bays of our MH will have to go in the tow vehicle, and toppers are not always watertight, I'm wondering if a van might be a better choice.
Needs:
1. seat four adults in comfort
2. tow 34' Airstream (9800 pounds gross weight)
3. about 150 cubic feet of storage for about 1500 pounds
I haven't started looking for vans yet, but it seems that most of the pickups are diesels with 4wd. I'm guessing that the vans probably won't have the 4wd, although they may have the diesels.
Thoughts?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 05-20-2016, 07:11 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
You may find this useful.
http://www.themoreweexplore.com/fred-the-van.html
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-20-2016, 10:00 PM   #3
SailorSam205's Avatar
Northville , Michigan
Not sure if you can still order a new Econoline. I went onto the Ford web ordering site and after a devious pat, was able to pull up a screen that supported order a new 2014. Only 150 and 350 versions were offered. The 350 could be ordered with a 6.8L EFI V10 or 5.3L EFI V8, no diesel. According to the 2014 towing guide available at http://www.fleet.ford.com/towing-guides/, you can pull a 10,000 lb trailer. The E350 does offer an integrated trailer brake controller.
I also took a quick look at the Transit, which does offer a diesel, but max tow weight is 7,500lbs.
The Expedition/Navigator support towing up to 9,200.
You may be better served in an F series Super Crew...
SailorSam205 is offline   Reply With Quote
Old 05-20-2016, 10:08 PM   #4
One other thought which is discussed in other spots on this site, You may be able to tow your trailer with Fords gas Eco-boost engine. While not exactly scientific level testing, this site shows what various truck were able to handle going up hill in the Rockies. They pulled 10,800 with the V6 Eco-Boost successfully. Take a look at: http://www.tfltruck.com/tfltruck-hall-ike-gauntlet/. I know a lot of folks here will say you need the diesel, YMMV...
Old 05-21-2016, 03:41 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I used 250 and 350 Ford vans for years. They worked well for storage and comfort and 34 was ok. Passing trucks gave a pretty good push. You almost needed to lean into them to keep going straight. Switched to a Chevy dually crew cab with full box and push was not a problem anymore. Not sure whether it was the lack of the big slab sides on the van that caused the problem or the dual wheels on the Chevy that solved the problem. I did blow the engines at 120K-140K on the vans. Chevy, replaced the in-tank fuel pump twice and ignition timing sensor once.
Old 05-21-2016, 06:33 AM   #6
K.C. , Missouri
One ton dually with 8' bed and a cab high truck cap. Awesome towing ability, luxurious interior, amazingly good ride when loaded as you state you will be. Choice of gas or diesel engine. These trucks are the ultimate consumer multi-use towing/daily use vehicle.
Don't let the naysayers rain on your parade, these trucks are quiet, ride and handle well and are far sturdier than trying to set up a lesser vehicle for this duty. These trucks are real towing/hauling platforms with an appropriate body on frame construction, big brakes, and a suspension designed for the job at hand. Go look at one and check the door sticker for payload, you will be pleasantly surprised.
my badge of honor here:
"a genius nanny boy that drools in public"
....this according to a "slow-moving" poster here on the forum.... ( thanks )
gmw photos is offline   Reply With Quote
Old 05-21-2016, 07:01 AM   #7
Libertyville , Illinois
I tow with a Chevrolet Express 1500 van with a 5.3 L motor to a 4700 pound (dry) trailer. The 1500 is tow rated at 6600 pounds. They don't make the 1500 anymore; they only make the 2500 and the 3500. They do have a diesel offering in these vans will tell up to 10,000 pounds. They also used to make an all wheel-drive version; I don't know if they still offer this. I love my van for the great seating and dry storage capabilities. While I wish I had either the 6 L gas motor or the diesel, mine does get the job done.
Short563 is offline   Reply With Quote
Old 05-21-2016, 07:35 AM   #8
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We tow with a 2015 Ford F-350 diesel, short bed, 4x4 pickup. I put a Leer cap on the back and it is certainly watertight. My old truck ( '06 Dodge ) had a Leer cap, also watertight. So don't let that keep you out of a pickup. I have a sliding bed insert that gives easy access without needing to climb all the way inside for access to my " STUFF".
So far as I know the F-250's and F-350's are one and the same with the small exception of the rear spring pack to give the 350 some extra capacity. I think you'll find them comparable in every way so go for the best deal you find. In my case I was looking for the F-250 but the 350 is what fell into my lap.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-21-2016, 08:31 AM   #9
1973 25' Tradewind
Beautiful , Oregon
I love having a van as a tow vehicle.
The AWD drive on the Express vans was only on the half ton.
Look at the Nissan NV3500 I bought one and love it. Also have a 1/2 AWD Express. No comparison.
You can add aftermarket 4 x 4 to the NV delivered from the factory to the installer. $11,500.00 No charge for shipping from the factory to the installer if you order the van.
Below is a post I started that is related post #30 and #31 gives my impression with the NV 3500 van.
http://www.airforums.com/forums/f238...le-144015.html
Good Luck
Tony
Tony S is offline   Reply With Quote
Old 05-21-2016, 09:23 AM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We tried to come up with a single vehicle that could travel extensively with the two of us and our Airstream and be a convenient daily driver at home. Either way there were compromises.
So we have settled on two vehicles, one matched closely to our Airstream travel and a sedan matched closely to our daily driving needs at home. We actually have another, a 91' Suzuki Samurai to squeeze onto back trails and old logging roads neither of those vehicles could even think about.
We have thrown out the one-vehicle-does-it-all concept for now. Very happy with two (or three).
Doug and Cheryl
Old 05-21-2016, 03:41 PM   #11
Thanks, all. Since we're buying used we'll see what we can find when that day finally arrives. Sounds like the van would work, but the pickup might be a better choice. Vans seem to be a bit scarce right now, but who knows what will be available when we're ready to buy.
First have to get the Foretravel sold.
TAC SD-6
AIR 54240
F250/350 questions kb0zke Tow Vehicles 46 09-29-2015 12:27 PM
1994 19 AIRSTREAM FORD E250 B 190 78k miles CLEAN , TURN KEY, READY TO GO! eBay Watch Airstreams on eBay 0 12-03-2011 04:40 PM
E250 Possibilities Denis4x4 Tow Vehicles 4 11-16-2009 04:53 PM
Ford e250/e350 Vans - anybody have one - what are your impressions sigv Tow Vehicles 20 11-28-2008 08:17 AM
'08 F250/350 vs 2500/3500 diesel 4x4(?) crew cab Roamin Cat Tow Vehicles 31 03-21-2008 06:03 AM
