Old 04-20-2015, 12:56 PM   #15
2016 30' Classic
Erie , Colorado
From page 9-91&92
Tow/Haul is designed to be most
effective when the vehicle and
trailer combined weight is at least
75% of the vehicle's Gross
Combined Weight Rating (GCWR).
See “Weight of the Trailer” under
Trailer Towing on page 9-72. Tow/
Haul is most useful under the
following driving conditions:
When pulling a heavy trailer or a
large or heavy load through
rolling terrain.
large or heavy load in
stop-and-go traffic.
large or heavy load in busy
parking lots where improved low
speed control of the vehicle is
desired.
Operating the vehicle in Tow/Haul
when lightly loaded or with no trailer
at all will not cause damage.
However, there is no benefit to the
selection of Tow/Haul when the
vehicle is unloaded. Such a
selection when unloaded may result
in unpleasant engine and
transmission driving characteristics
and reduced fuel economy. Tow/
Haul is recommended only when
pulling a heavy trailer or a large or
heavy load.
This may describe the behavior you are seeing. Good luck.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 04-22-2015, 09:13 AM   #16
callmedave's Avatar
2013 28' Flying Cloud
Cohasset , Massachusetts
Images: 14
Gary,
Thanks for your post. You're right about that quote…it was in a different place in my manual.
Odd that the page does not show up in either the table of contents or the index…and there are similar errors elsewhere in the manual.
"This may describe the behavior you are seeing. Good luck."
I'm not sure if you are replying to my (former)issue or Jack's(the OP)?
Are you saying that neither of us needs to engage T/H mode with our AS's?
In either case, I believe we're both well above the 75% threshold…
I'm also puzzled about the transmission temperature issue. I believe that an important concern when considering a tow vehicle is trans. cooling capability.
As I mentioned before, I notice a considerable increase in trans. temp. when towing without T/H mode, which seems to just ask for trouble.
Any thoughts?
Thanks again,
Dave
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
callmedave is offline   Reply With Quote
Old 04-22-2015, 09:58 AM   #17
2011 30' Flying Cloud
Arvada , Colorado
I thought since I've now had the truck looked at by a dealer I would provide an update. We are on the road in Colorado and I visited King GMC in Loveland. I've had them do routine service on our earlier Suburban during previous visits here. They are first rate by the way. My truck is a CPO so still covered under warranty, so no cost to me whatsoever.
Anyway it turned out to be a reprogramming of the transmission control module. On my way back to St. V'Rain State Park this morning, I manually downshifted from 6th to 5th and all seems good. Thanks for all the feedback here.
Jack46 is offline   Reply With Quote
Old 04-22-2015, 10:50 AM   #18
2012 30' Classic
Homosassa , Florida
Great outcome. Safe travels.
Tater is offline   Reply With Quote
Old 04-22-2015, 01:35 PM   #19
ericpeltier's Avatar
Superior , Colorado
Enjoy CO! We've had a nice rain and it's green!
ericpeltier is offline   Reply With Quote
Old 04-22-2015, 02:06 PM   #20
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I have owned an 2003 and currently drive a 2012.
Both downshift from OD a bit firmer than other cars/trucks. Especially with tow/haul activated.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-04-2015, 11:41 AM   #21
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
I have a '15 Duramax towing a '15 Classic. Through the mountains of Vermont & New Hampshire, I enable T/H only while descending hills which works amazing with the exhaust brake to keep the set speed.
If I keep T/H always engaged; she'll have a tendency to stay in 5th gear longer than I'd like.
In the city, I always keep her in T/H.
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is online now   Reply With Quote
Old 05-04-2015, 01:20 PM   #22
2016 30' Classic
Erie , Colorado
I do the same thing with Tow/Haul as Ron. On the highway exhaust brake is on and not in T/H. Actually seems to improve MPG since you are in 6th instead of 5th gear. In traffic, either on the highway or in town typically use T/H as you get better down shifting if you need to slow down.
Gary
2015 Classic
ProPride
NØVPN
Old 05-27-2015, 02:12 PM   #23
2015 25' FB Flying Cloud
Meadow Vista , California
I am considering the 2015 2500 Duramax, can anyone comment on MPG?
SilverSinbad is offline   Reply With Quote
Old 05-27-2015, 02:29 PM   #24
2016 30' Classic
Erie , Colorado
towing a 2015 Classic, 12.5-13.5 range. Around town 16. Highway no towing 22-24.
And regular and diesel are the same price at the pump here in Erie, CO. $2.49
Gary
2015 Classic
ProPride
NØVPN
Old 05-27-2015, 02:44 PM   #25
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
40% deduction isn't bad. It's within the usual 30-40% range. Same speed towing and solo? Use cruise in both instances? 14-15 is possible if so, would be my guess.
Old 05-27-2015, 03:33 PM   #26
2016 30' Classic
Erie , Colorado
Tow at 65 and use cruise most of the time. Actually much better mileage than my previous 2014 5.3l Sierra.
Gary
2015 Classic
ProPride
NØVPN
Old 05-27-2015, 05:17 PM   #27
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our 2012 hits around 12MPG towing... on nice and flat running around 55 indicated, but close to 57-58 actual. When climbing hills (small Texas type) I hit around 9MPG.
Towing a 34' and usually loaded with headwinds..
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-28-2015, 12:49 AM   #28
2016 30' International
Scottsdale , Arizona
Another data point... but not towing, we've been averaging around 17.5 mpg with mixed around town and highway driving during the first 1300 miles driving a 2015 Sierra Denali HD Duramax/Allison. And we LOVE this truck! The engine is surprisingly quiet, surprisingly powerful (fast!) and the features/creature comforts are great.
DHart is offline   Reply With Quote
Calling all Duramax/Allison owners Silvertwinkie Tow Vehicles 31 10-04-2004 05:19 AM
Duramax=Trouble ???? Silvertwinkie Tow Vehicles 37 08-10-2004 04:45 AM
Duramax vs Rover, Hmm Coloradobus Tow Vehicles 3 03-02-2004 05:19 AM
Duramax-Allison Pahaska Tow Vehicles 34 11-23-2003 10:55 PM
Duramax towing question Mark Wiltrakis Tow Vehicles 6 11-07-2003 12:24 PM
