Old 10-16-2006, 08:21 PM   #15
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I have run syn in my gassers for a long time. Got rid of the "piston slap" in the small block GM engines...
One of my motivations for running syn oil is longer intervals between changes. Other than that, I agree, if you are religious about changes and use quality oil, there probably is not much advantage to syn oils.
I am still confused about the Delvac/Mobil 1 for Turbo Diesel info on the mobil.com site. This is confusing. Is Delvac synthetic?
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 10-17-2006, 04:19 AM   #16
hiker's Avatar
2007 25' International CCD FB
Needham , Massachusetts
Thanx, Bill
I think OldDog's post in the folllowing Diesel Place thread is correct
http://www.dieselplace.com/forum/sho...mobil+1+delvac
Mobil Delvac 1 5W/40 CI-4 plus used to be Mobil's synthetic for trucks. Mobil probably wanted to give Mobil Delvac a stronger tie to the strong brand name "Mobil 1" so they changed the name from Delvac to Mobil 1. They must have gone through a few false starts creating a lot of confusion. If it's 5W/40 and CI-4 plus and says Mobil then its probably the same oil
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
hiker is offline   Reply With Quote
Old 10-17-2006, 06:09 AM   #17
1 Rivet Short
1989 25' Excella
Thanx Hiker, yeah that seems to be the case. I could only find Delvac 1300 (Dino oil) and I had an appt at the dealer today, so I guess I'll be running that for a while. I'll keep looking for the Mobil 1 TBD Syn for next time. Went to 3 places last night. All they had was Delvac 1300...gotta say the Mobil website is confusing...
Mobil Delvac 1300 Super is 15W40 diesel dino oil (good dino oil)
Mobil Delvac 1 is 5W40 diesel synthetic oil (good syn oil)
Mobil 1 Truck & SUV USED TO BE 5W40 synthetic oil and good for diesel
NOW Mobil 1 Truck & SUV is 5W30 synthetic oil and NOT FOR DIESELS
Mobil 1 Turbo Diesel is the new synthetic for diesels
Old 10-17-2006, 06:40 AM   #18
hiker's Avatar
I think the next decision for us diesel owners will be whether/when to switch to the new API CJ-4 rated diesel oil that is supposed to be available sometime this month. API CJ-4 oil will be required in model year 2007 engines. The claim for pre-2007 engines is that API CJ-4 oil will provide better protection, including improved wear protection, high temperature oxidation control and soot handling which will enhance engine durability and cleanliness of the engine.
But I'm not sure. Is this marketing hype or real? Will other forum members be switching? Any opinions?
Mike & Joan
Old 10-17-2006, 07:46 AM   #19
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Note to add: the Mobil 1 Turbo Diesel is 5W-40. with the CI-4 rating
according to the Mobil website. I suspect they will update it to CJ-4 soon.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 10-17-2006, 07:58 AM   #20
1 Rivet Short
1989 25' Excella
I suspect the new as the new oils hit the market to meet CJ-4 that they will replace (not supplement) the oils meeting CI-4 so we really won't have a choice. But as stated they will be "new and improved"!
Old 10-17-2006, 08:44 PM   #21
lsinclair's Avatar
2008 30' Classic
Pagosa Springs , Colorado
Exclamation Duramax oil change
Most GM trucks have the "oil change" reminder and with Onstar you will be alerted via email when service is due.
Syn oil (Mobil 1 Trk/SUV or Castrol) is good. For warranty purposes, it is important to use the specified weight as noted on the oil filler cap. In addition, if you have an Allison trans, the owner's manual instructs you to change the external trans filter on your first oil change. It sells for $33 at the dealer but is less expensive at Napa.
Larry
Pagosa Springs, CO
'05 Classic 25'
'05 GMC 2500 Duramax
lsinclair is offline   Reply With Quote
Old 10-18-2006, 05:59 AM   #22
1 Rivet Short
1989 25' Excella
Larry
Pagosa Springs, CO
'05 Classic 25'
Hi Larry. just a note; Mobil1 for Truck/SUV is not rated for diesel engines.
I think the Castrol is a blend? Not pure syn?
Also first oil change is due at 5k miles, not in accordance with the DIC. Many folks even change out sooner for the first one. My last two Suburbans I changed out (to Mobil 1) at 1k miles. As the diesel is 10qt, I waited a little longer!
I ususally do my own maint, except for the initial break-in. Just gives me a better feeling to have the dealer ship look things over. Going forward I will follow the DIC. With the gas Suburbans, running Mobil1, I found I got about 7k-8k between OCI's following the DIC durring tow season. A little longer in the winter.
p.s.The dealer charged $27 for the Ally filter yesterday...
Old 10-18-2006, 07:37 AM   #23
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I have run both Mobil 1 syn and Mobile Delvac 1300 in my Duramax and have done oil analysis with both oils. My conclusion is the 1300 dino is just as good as the syn, for all practical purposes. I run my oil about 7500 miles, so I do not see an advantage to filling the sump with $60 worth of syn oil versus $20 worth of dino in my application. Currently I have 6 qts of Mobil 1 syn and 4 qts of 1300 in there.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-22-2009, 03:53 PM   #24
newyork , New York
quick oil drain valve
If you change the oil yourself, using this small equipment helps saving your time a lot. I bought one at qwikvalve.com. Worth to give it a try
AKJack08 is offline   Reply With Quote
Old 04-22-2009, 04:37 PM   #25
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I would reccomend doing your first oil change well before 5000 miles. Keeping in mind, I dont know your Vehicles MFG date but the oil is at least that old. If you vehicle is at its model year end, it is already overdue before you purchased it.
To many oil changes isnt a bad thing. I ussually dump mine when I get it home. I use Castrol GTX for the first 2. They are done within the first 1500 miles. Then I switch to Mobil 1. I do it every 5000 on synthetic, then I can rotate my tires at the same time.
I have used this system for gas / or diesel engines. Keep in mind a good oil filter is just as important. Mobil 1 also makes a good filter. I am not a big Fram person. They bypass way to early circulating dirt and other grit causing premature wear. An old name I would also reccomend is Hastings. They also make Federated brands.
mustang is offline   Reply With Quote
Old 04-22-2009, 05:36 PM   #26
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
I change at 10K, with Shell Rotella SJ grade synthetic, it's what I use in my fleet diesels too. cost is reasonable, and meets all requirements. I change the fuel filter at 10 also, WIX gold filters in both applications
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 04-22-2009, 07:15 PM   #27
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Well since Bill Tex kicked over the ant hill . I'll add my 2 cents.
I have used Shell Rotella 15-40 for at lease several MILLION miles, IN I care not to count how many Cummins engines over 45 yrs of ownership and driving for other people. I have never lost and engine even with a million miles on em.
In my 7.3 liter International Harvester (Ford) I still use Shell Rotella 15-40 year round. I change oil and filters every 10K miles .I am now at 75K and my engine does not require adding of oil between changes.
For Me I cannot justify the extra cost of a Synthetic Oil.
What works for me might not work for someone else. So I will continue doing what works for me.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-22-2009, 10:05 PM   #28
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Larry
Pagosa Springs, CO
'05 Classic 25'
Larry... You can pick up the spin on Allison transmission filter # 29539579 for approximatly $15.78 at a Allison Transmission dealer. You can get the location of your local dealer at Sales & Service Locator: Allison Transmission
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Engine Oil Question ViewRVs Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 08:45 AM
Oil Change Fear and Woes Chaplain Kent Classic Motorhomes 14 04-09-2006 07:09 PM
Vortec 8.1ltr Krazykraut Mechanics Corner - Engines, Transmission & More... 13 10-20-2002 05:53 AM
oil and trans fluids ALANSD Airstream Motorhome Forums 22 08-01-2002 02:47 AM
Partial Floor change winner Floor Finishes 12 07-22-2002 06:08 AM
