Old 01-05-2007, 10:25 PM   #1
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
Duramax/Allison Losing Power...???
I have a 2002 GMC Duramax/Allison.
When accelerating from a standstill, you can pour the pedal to it and it will accelerate furiously until 3rd gear....then approaching 2800 rpms, it just acts starved for fuel or air and just loses power right when you think it should shift and pin you to the seat again.
All the get up and GO, just stops, and until you back out of it and let it shift soft, it will just stay there at 2800 rpms and not go on no matter how much pedal you give it.
Also, traveling at 65-75 mph, and romping down on it to pass, it will shift down and accelerate like the devil until about 2800 rpms in 4th, and it just acts fuel starved and no power.....until you back out of it and let it shift soft and sort of "catch up".
Once it shifts you can accelerate swiftly, as long as it doesn't downshift, all the way out to 96 mph where it is topped out.
I don't understand what is happening.
Is it fuel starved from filter being clogged, or injector pump not keeping up? If so, how could it run over 90 mph?
Is the turbo kicking out?
Is the Allison tranny screwing up?
Any ideas why I am experiencing this?
It hasn't happened before....until now, I oculd pour the pedal to it and it would run like the wind...shift all the way up...and when it got to those critical 2800 rpms places, hit the next gear and pin you to the seat....now it isn't.
I don't know what the deal is, and would like the advice and help of the forum experts, please?
David
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
archival giclée prints available for each picture, 16 x 21 and larger.
dscluchfc is offline   Reply With Quote
Old 01-05-2007, 10:56 PM   #2
wingfoot321
Profile:  1987 29' Sovereign
Sparta , Tennessee
Try posting on Chevy Talk - Chevy Forum / Chevy Forums for the Chevy Enthusiast as there are some real gearheads on that site. Use the 99-current trucks.
Sorry I am no help as my gm is a gasser.
wingfoot321 is offline   Reply With Quote
Old 01-05-2007, 11:08 PM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I've repaired many diesels with those same symptoms with a fuel filter change. If it's a recurring problem, you may have algae growing in your fuel tank. Diesel will suspend enough water in it to actually grow algae, as wierd as that may sound. I would go the fuel filter route first.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-05-2007, 11:25 PM   #4
dscluchfc
dscluchfc's Avatar
Abernathy , Texas
Thx Dave...I was thinking it sure feels more like fuel starved more than anything.
I am guessing that there is also some tank treatments available to kill any growing bugs?
David
AIR # 410
Old 01-05-2007, 11:28 PM   #5
dscluchfc
dscluchfc's Avatar
Abernathy , Texas
Forums there are being moved to new server this weekend and are presently read only....I'll have to wait to post there.
David
AIR # 410
Old 01-05-2007, 11:29 PM   #6
Fyrzowt
Fyrzowt's Avatar
Images: 8
Yes there are, but if the fuel is contaminated, you usually would need to drain or pump the fuel out and start over. If you kill the algae, it is still going to be in there. IMO, the additives work better for prevention, or to control a mild case of contamination. Good luck.
Dave
Old 01-06-2007, 07:20 AM   #7
hiker
hiker's Avatar
Profile:  2007 25' International CCD FB
Needham , Massachusetts
try posting to:
Diesel Place - Duramax Diesel Discussion Forums
this is a site dedicated to Duramax diesel similar to AirstreamForums
Mike & Joan
WBCCI #1521 New England Unit
06 Chevy Duramax/Allison
hiker is offline   Reply With Quote
Old 01-06-2007, 07:37 AM   #8
ZoominC6
ZoominC6's Avatar
Profile:  2004 30' Classic Slideout
Blacksburg (College Town USA) , Virginia
D.I.C. advisory
GM may be trying to help owners who forget regular fuel filter changes by now programing into the DIC an advisory as to how much time is left until a change is recommended. Pretty cool idea and it may help us out.
HAPPY TRAILS ONE AND ALL
ZoominC6 is offline   Reply With Quote
Old 01-06-2007, 08:32 AM   #9
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Classic symptom of a clogged fuel filter...
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
BillTex is offline   Reply With Quote
Old 01-06-2007, 08:58 AM   #10
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
Almost always , first step , second step , check the air filter . If you have algae the fuel will look slimmy in the filter . Good luck , and let us know the outcome.
ticki2 is offline   Reply With Quote
Old 01-06-2007, 09:10 AM   #11
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
David,
If I read you correctly it will accelerate hard in 1-3 gears then die off in 4th? That is not a fuel feed problem that sounds more like a transmission program error. I am not familiar with the Duramax/Allison combo at all. I am an first generation PSD man myself But if it pulls hard in the lower gears it is not fuel or air flow.
Aaron
WBCCI #2449 AIR #2495
Old 01-06-2007, 09:13 AM   #12
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
for what its worth...
I had similar symptoms with my ex-2001 PSD. I had used the truck in the pastures during hay cut/bale/ delivery summer season. The air filter was jammed closed with hay debris...as indicated by the airflow gadget on the filter box...something I did not know about 'till pointed out by the mech who showed me, changed the air filter and solved the problem. The air filter had closed off in about 1200 miles of work and did not make it to the 3000 mile service I usually do. I had changed both fuel filters with no effect. Note...I said both filters. Good luck!
Edit....I noticed the above note on tranny problems. I went through two PSD trannys with very similar symptoms. Am now a Duramax owner.
Old 01-06-2007, 09:13 AM   #13
fltlevel510
. , Kentucky
I have a 2005 Silverado Duramax/Allison and believe the fuel filter should be the first thing to check. However there have been several recent articles about the algae growth for those who have been using bio-diesel. Those fuels made with blends of recycled cooking oils etc.
In the past algae/microbe growth in jet aircraft was a common problem. There is a product called BioBor, usually about $10 for 8oz which will prevent the problem.
fltlevel510 is offline   Reply With Quote
Old 01-06-2007, 09:22 AM   #14
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Stanadyne Corporation has products which have been the standard for the trucking industry for years. Check out their site: Stanadyne Corporation - Home Of High Quality Diesel Fuel System Components
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
power boosters John Our Community 18 11-19-2002 04:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
towing and the Banks Power Pack kooblekidz Airstream Motorhome Forums 11 10-31-2002 01:09 AM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 11:23 PM
no power Mike Electrical - Systems, Generators, Batteries & Solar 10 08-20-2002 07:38 PM
