Old 08-23-2008, 01:07 PM   #15
Cracker's Avatar
Pittsfield , Maine
Dually Won't Fit???
Rick:
I was just curious when you said the dually wouldn't fit through a 9'-0" garage door. My garage is 90 degrees to the driveway so I have to jocky a bit to get lined up, but with a 9'-0" opening I've got at least 10" of net clearance - which I try to center the dually in. Height isn't a problem.
Cracker
Cracker is offline   Reply With Quote
Old 08-23-2008, 03:36 PM   #16
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
I'm able to put mine through a 9' opening as well. I just need to make sure I am centered going in.
94Tri is offline   Reply With Quote
Old 08-23-2008, 06:51 PM   #17
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
For me it's simple: Any RV that NEEDS a dually is one I don't want.
I pull my '34 Silver Streak with an SRW Cummins, and it's complete overkill. The PO used a 6.0L Suburban that I imagine was easier to live with than this truck for daily duty. (I needed a truck for other purposes, and, with that, it is ideal all around in its' duties).
DRW is overkill for an Airstream, IMHO. A cheap one would be on my list, too, but I'd convert it to SRW and change the spring packs.
Old 08-23-2008, 08:11 PM   #18
1973 25' Tradewind
Romulus , New York
Duelly's are great for stock trailers,race car trailers and such. Drive one in a snow storm and you will bring new meaning to the phrase "white nuckling". An AS needs a softer ride.
jayray5 is offline   Reply With Quote
Old 08-23-2008, 08:15 PM   #19
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Uh...wouldn't that defeat the purpose. I mean, what's the purpose of starting with a dually if you're going to convert it to a SRW?
Family of Disney Fanatics
WBCCI# 4821
Old 08-23-2008, 08:36 PM   #20
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
Towing with a dually
Originally Posted by ShikariJones View Post
I have poked around this section a bit but have not seen anyone post specifically if a dually is better for towing say a 29er A/S than a non dually would be.
I have the opportunity to buy a '99 dodge ram 3500 Cummins dually with next to no miles on it and thought that this might make a fine TV.
Have done lots of towing and carrying with a '94 Cummins TV and would consider no other engine.Still have the'94 and can't wear it out!!
Are there any reasons why a dually would be a bad choice?
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXX
SJ,
I have driven and had both dually and standard in the F350, as far as the truck itself they the same as far as engine, frame, trans, steering, cab, in fact there is no difference between the 250 & 350 on these points. The only difference is in the fact that a dually rear end is more heavy duty than the standard one.
Where you will notice the difference is the fact of the wider clearance at the bed, the extra tires if you have a flat, and the stiffer springs, some parking problems. Like some of the others indicated in here the more stiffer rear will cause problems with in the AS trailer. Dually's really shine their best when towing a fifth wheel, goose neck cattle trailer, large boats, because of the stance of the wider/heavy duty rear end, stiffer springs, which are much more stable than any thing else.
With you only pulling a 29 you might consider a 3/4 ton (F250, GM/Dodge 2500,) and you could even go down to a full size 1/2 ton.
Hope this is of some help.
Sarge
SARGE/AF is offline   Reply With Quote
Old 08-23-2008, 08:42 PM   #21
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A cheap, well-maintained truck that can be set up for the owners EXACT needs.
Old 08-23-2008, 10:43 PM   #22
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have seen people remove the inner pair of wheels, leaving in essence a single rear wheel truck that looks like a dually. If you get a dually, you will have the flared rear fenders to do something with, and doing it this way will at least fill the fenderwells. It only looks bizarre when following one that has had this treatment, from the side it still looks like a dually.
Old 08-24-2008, 03:18 PM   #23
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
I use a dually for stability. The extra traction in an emergency situation could make the difference. I use the Air-Safe hitch and the ride is vary smooth for both the trailer and us. As for parking I always park away from crowds to avoid door dings and for exercise so parking is just what you make of it. Safety first!
Phil Gobie is offline   Reply With Quote
Old 08-25-2008, 10:50 AM   #24
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I might add that when you take the outer dual wheels off it looks like you have a narrow stance in the rear which seems like it would add sway or rocking in wind. I might also add dually takes away traction in rain snow and mud or ice condition. You still have the same downward force but it is now split between 4 wheels instead of 2. If you choose to purchase a dually I would like to make everyone aware, Do Not, use cruise control when in these conditions. You will experience loss of control. Accident or roll over or what ever happens you will have less chance to recover.
mustang is offline   Reply With Quote
Old 08-25-2008, 06:59 PM   #25
Cracker's Avatar
Pittsfield , Maine
Mustang:
I respectfully submit that it doesn't matter what you're driving in rain, ice, or snow conditions - cruise control is a "no-no" - especially when towing! I stated earlier that the dually is worthless on an ice-covered road and that I'm fortunate enough to be able to store mine during the winter. Beyond that, I believe that many of the duallie's remaining faults can be somewhat offset by positive features - not the least of which, for me, is the pure enjoyment and confidence it imparts when I'm towing with it!
Cracker
Old 08-26-2008, 08:50 AM   #26
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
cracker
You are obviousely a person in the know. I noticed the 4X4 in your description of 3500. A heavy suspension likes to be loaded, that is why a truck runs smoother under a load. A dually is designed for a Heavier application then any Airstream except the old 5 th wheel can provide.
Your choice is that. I threw out my opinion. 4X4 does change alot for traction, and in my opinion is a must when going dually, because it corrects most traction problems.
Old 08-26-2008, 05:37 PM   #27
Cracker's Avatar
Pittsfield , Maine
As somewhat of an aside - I just read the article in the latest "Airstream Life" about the new 34' Airstream Toy hauler! Now that's a beautiful match for a dually! The hitch weight comes in at 1,400 lbs with an all-up weight of 11,500 lbs. Perfect for the latest dually specs - but a bit of a pull for my 2003 using the 80% rule!
Cracker
Old 08-26-2008, 07:23 PM   #28
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
My feeling is that maybe only a 34' slide out (newer) might get any benefit from a dually due to the significant hitch weight that unit has (1150lbs). In the case of a 29', I don't think it'd be needed.
Check out my 1996 F3504dr dually tow vehicle donfuzzy70 Member Introductions 0 02-13-2008 09:55 AM
Piggyback Car on Dually Cracker Towing, Tow Vehicles & Hitches 27 01-13-2008 04:38 AM
Best 1-Ton Dually on the market and why? Streamer1 Tow Vehicles 25 10-23-2006 08:16 AM
MPG of F350 Diesel Dually??? joossens Tow Vehicles 13 06-13-2004 12:55 PM
