Old 04-28-2007, 02:07 PM   #1
1978 25' Tradewind
hot springs , Arkansas
dry weight tahoe tradewind
am i safe to assume that a 1978 tradewind (25') with a published dry weight of 4200 lbs, is safe to tow behind a tahoe 5.3 vortec with tow rating of 6800 lbs? i tow completely dry, and can't imagine that i would have 1800 lbs of sofa and cargo in the trailer.
i guess my concern is that although we have towed comfortably all over 2 lane mountain highways in arkansas, we are contemplating a trip to new mexico down i40 for 10 hours. i have the original eaz lift weight distributing hitch with no sway bar. i have never noticed any appreciable sway, but then again i haven't towed with 10000 18-wheelers down i40 before. is a sway bar mandatory? is the friction bar setup effective, or should i consider scraping the whole deal for a new reece dualcam or equalizer?
any advice would be appreciated. btw my tahoe is equipped with airride load levelling suspension.
thanks
thollis is offline   Reply With Quote
Old 04-28-2007, 02:19 PM   #2
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
You're more then ok assuming that you're not going to pack the Sub with a lot of heavy "carbon based life form".
I went to Lake Tahoe via HWY 395 dry with the exception of food in the refer and the back of my P/u fully loaded. going up the hills on the hottest day of the year was a challenge and that's with a 4.7L engine but we made it.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 04-28-2007, 04:59 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
We tow our Safari with our '06 Tahoe which sounds like yours. 5.3L with the tow package and auto-level system. We use the reese with a friction sway bar and have had no problems. Up the Big Horn and down and across the Rockies. Just remember the total tow weight includes not only what you put on the ball but also what you put in the truck!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
weight specs for 68 Overlander 26D PeterH-Airstreamer 1969 Overlander 5 02-08-2003 03:49 PM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
Trailer weight Dbraw 1969 - 1973 Safari 3 06-26-2002 12:01 PM
'71 Airstream Caravel 18' weight specs PeterH-Airstreamer 1969-1971 Caravel 0 06-15-2002 06:28 AM
