Old 12-20-2014, 05:48 AM   #1
Tincampers's Avatar
Sneedville , Tennessee
Dodge recalls 2005 Ram pickups.
Something to do with the rear axle and driveshaft.
Chrysler to recall about 288K Ram pickup trucks - + KSHB.com
Tincampers is offline   Reply With Quote
Old 12-20-2014, 07:09 AM   #2
SteveH's Avatar
Common Sense , Texas
That's a new one. I just received my third recall on my '12 2500 Ram. The first was for an ECM reflash that ended up costing me 15-20% in fuel mileage, the second for failing tie rod ends (fairly major deal), and now the Diesel fuel heater connector is failing causes them to catch fire. (another major deal IMHO)
However, the current recall says they will issue another recall to let me know when they actually have the parts to fix the fuel heater connector!
At this point my plan is if it catches fire, I will quickly disconnect from the trailer, and let it burn.
Regards,
Steve
Old 12-20-2014, 07:25 AM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The recall is for 1/2T trucks. I can attest that losing the driveshaft on a permitted 84,000-lb semi loaded with 280F asphalt is exciting. Due to incompetent mechanic. Imagine trying to stop something that can't really be stopped with brakes alone.
A controlled crash is the choice but how to choose among the options available?
Just another day at work.
SteveH, is the fuel heater necessary for likely Texas weather? Is it "hot" with ignition off? I'd disconnect it and see if codes come up. I'd imagine the more knowledgeable on CF have already covered this.
OTOH, maybe an insurance claim can get you into a (better) 14 or 15.
A fire extinguisher, even partially discharged, covers the bases (ha!)
slowmover is online now   Reply With Quote
Old 12-20-2014, 07:42 AM   #4
SteveH's Avatar
To answer your questions about the fuel heater, I don't know on either of the points. Maybe wrongly, but I would have to assume they were smart enough to operate the thing from the ECM driven by temperature.
However, I do carry a fire extinguisher in the Airstream, but in this event it will only be used to protect the Airstream, not the Ram.
I just think Dodge has had way too many recalls on this thing, and I've had way too much trouble getting it to tow the trailer with acceptable stability.
Regards,
Steve
GM Recalls over 300k 2014 pickups for possible engine fires overlander63 Tow Vehicles 20 01-15-2014 09:05 AM
Dodge Recalls 1.2 million pickup trucks pappy19 Tow Vehicles 14 11-26-2013 08:00 AM
Chrysler recalls 242,000 Ram pickups from 2008-2011 JFScheck Tow Vehicles 0 07-13-2011 01:35 PM
recalls and only recalls.... 2airishuman Electronics & Connectivity 7 04-29-2008 07:28 PM
GM recalling 155k Vans, Pickups and SUVs Silvertwinkie Off Topic Forum 0 02-10-2005 11:43 AM
