Old 12-11-2009, 04:35 PM   #29
2000 34' Limited S/O
Jamestown , North Carolina
What is the thinking and experience on here relative to adding a chip for better mileage?
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 12-11-2009, 04:49 PM   #30
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by SteveH View Post
I just traded an '07 1/2 ton GMC pickup (5.3L gas) for an '08 3/4 ton GMC Duramax Diesel 4X4. Took a short trip to New Mexico to pickup a small trailer (17 footer), and AVERAGED 14.9 MPG on the entire trip. The best mileage running empty was 16.8, and the worst pulling the little trailer was 13.6. This is actual mileage dividing miles driven by gallons used, not by the dashboard computer, which by the way, agrees.
This stuipid thing gets WORSE fuel mileage than my 1/2 ton gas truck did.
So, let's see now.....the fuel is about 20 cents a gallon more expensive, and it gets worse mileage????
Sorry folks, I just don't see any savings here. On the contrary, it will cost more to drive this Diesel. The only good thing is, it does have lots more power.
Something strange going on! We just moved from a 1/2 ton gas GMC Sierra pulling a 4000# (low profile, light wt) trailer to a 3/4 ton diesel GMC Sierra pulling a 7300# AS, and I am getting at least 10-15% better fuel mileage with the new setup. And as you say - much more hauling power.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-12-2009, 02:30 PM   #31
JimGolden's Avatar
1977 31' Excella 500
Jim,
My point of my post was, and obviously you missed it, is that I've been reading on here as long as I've been on here, that Diesels make
way better mileage than gasoline trucks, and that is NOT TRUE of the newer Diesels. My gasoline truck made one to two miles per gallon better mileage than this '08 Diesel does under the same driving conditions.
Driving on the interstate at 70 MPH, the gas truck got 18mpg, the Diesel 16.4. Pulling the 17er, the gas truck got 15, the Diesel gets 13.4. Doing 80, the gas truck got 15/16, the Diesel gets 13.
No, I have not pulled a 34 footer, nor do I intend to. I haven't even pulled our 6500 pound 25er yet, but pulling the same small 17er at the same speeds, the gasoline truck got better mileage. I'm almost afraid to see what the Diesel does pulling the 25er at this point.
I still maintain this is not an apples to apples comparison. A half ton truck with a gas V8 weighs probably 3000 lbs less than a big 3/4 ton diesel. The 1/2 ton has five or six lug semi floater hubs with smaller bearings; which means less rolling resistance. Everything on a 3/4 ton HD or 1 ton (usually not much difference between them other than springs) (deeper frame, full floater axles, 8 lug hubs heavy bearings, etc) is made heavier which results in more weight and rolling resistance.
A fair comparison is take a 3/4 ton HD truck from whichever brand you like, and try one of their diesels vs. one of their gas engines. In this case, the diesel is always going to win.
But the field is wide open. You can pull a 25' stream quite happily with a 1/2 ton gasser. On flat ground, you might come close to breaking even. Anything smaller than that, you're definitely going to either break even or beat the diesel.
The diesel will only win the fuel mileage debate against a modern V8 gasser with cylinder deact if the trucks are the same size (like a diesel Jeep Liberty vs. a gasser...my gasser gets 18mpg, the diesels do 28mpg); or pulling a big load. At least that's my opinion.
The guys that pull the 34 footers and get 17 mpg...my hat's off to you. I've never gotten that well. My trailer grosses just under 5 tons, and my wife doesn't leave anything behind, so I'm probably running her at full weight. I get 13mpg on the super slab and 11 mpg in the big mountains. I have a crew cab, long bed, 4wd. But, I defy anybody with a half ton truck to even begin to pull this rig through the mountains.
Truthfully, if I had a smaller trailer, I'd look really hard at a hemi half ton Ram. I think it's a great truck. 390hp, good torque, but I think I'll just get a Charger instead
If you really were inclined, it's not that hard to remove all the particulate stuff off a newer truck either. The info is out there.
But different stroke for different folks. Those who like gasoline, vroom vroom. Those who like oil burners. make some grunt. They're all good!
How 'bout a '65 Sport Fury with a heavily breathed on 447 V8 making 500hp and 500 ft-lbs? Yeah, I got one No hitch on it though....yet.
see ya on the road
- Jim
JimGolden is offline   Reply With Quote
Old 12-12-2009, 02:41 PM   #32
SteveH's Avatar
Common Sense , Texas
Jim,
One last time....there are reports all over this forum of Diesels getting 20-22 MPG running empty, and they have to be 3/4 toners because there are no 1/2 ton Diesels. My gasser only got 18.5, best case.
The Diesel I now have only gets 16.5 MPG, best case.
So, my gasser got better fuel mileage than my Diesel.
Old 12-12-2009, 05:49 PM   #33
2009 30' Classic
Salem , Alabama
After a 7000 M trip (Apr 2008) TV 2008 Tdr L V8; Tw a very LW F Finder. I became more concerned about the limited range after TO; than I was about Ms per G etc. We traveled the SW region through some extremely desolate area's. Upon return; a new D was parked in my G on day 1. Now I have twice the R after TO. I have trouble understanding the 1or 2 etc mileage debate when pulling a HE AS. I think each person should determined their own need's an act accordingly.Myself I want more rather than less, should the need arise.Mel
woppa 4 is offline   Reply With Quote
Old 12-12-2009, 08:48 PM   #34
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Jim,
Steve, what we are trying to tell you is something is wrong with your diesel...get it checked...injectors, fuel filter...
You are the anomoly, which would indicate some problem.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 12-13-2009, 05:10 AM   #35
SteveH's Avatar
Bill
Bill,
At first I thought the same thing. Not knowing much about them, I went to a Diesel forum, Dieselplace.com , and started reading. Seems everyone with the late 07's, 08's, and 09's are getting virtually the same mileage.
Then, the people who have gone to the trouble of removing the Diesel particulate filter, blocked off the EGR system, and bought a reprogrammer to clear the error codes, are getting better mileage. However, this could void the warranty, and is against the law because you are removing emissions control equipment.
Old 12-13-2009, 09:33 AM   #36
1 Rivet Short
1989 25' Excella
Steve, keep in mind; a lot of those Folks on the diesel forum are chipped out, tire smokin' gear heads...they are all about hp/tq and a lot of them drag race their Durmax powered trucks. Literally.
Seems to me the Folks here, who are using their diesel trucks in a more sane manner, are reporting different performance figures. So again, a complete diagnosis from a Chev dealer may be in order.
Having said that, the reason I pulled the trigger in 06 was that was the last year with none of the new emmissions, and the first year with the 6 spd Alli.
Many would argue, this is the best year DA to purchase.
I would think the next gen of diesels will have all this emissions/ efficiency figured out even better. This urea thing seems...1/2 a#$ed? We'll see how the new Ford does...haven't heard any reports yet. OTH, Ford has never been as efficient as Cummins and Duramax....but let's see if someone with a new Ford chimes in after break-in.
I hate to play Monday morning QB...but if you purchased your truck used (I think you did?) perhaps you should have looked in to this first...and looked for an 06 if efficiency was you major objective...
Many Folks will go as far back as a 98 Cummins to get the 12 valve (no longer made), the most efficent of pick me up deezuls.
I guess my point is; research before you buy..
A couple of things you might do now to improve mileage (you sure won't need any more power!);
  • Bio diesel...many Folks report much better mileage with bio.
  • A free flowing exhaust.
  • I would stay away from chips...most do nothing for efficiency, but profit the chip seller.
I don't believe either of these will effect your 100k mile warranty (read first!). IIRC I looked in to running bio and it was allowed up to a certain %...just not readily avaliable in the NE. As noted; one good pull with a heavy load, and you will know you made the right choice.
Keep us posted, this is an interesting topic.
Bill
07 Tundra vs F250 vs Dodge 2500 vs Chevy 2500 outthere Tow Vehicles 248 01-13-2011 08:48 AM
Dodge Ram 1500 Tow Vehicle UK-Airstream On The Road... 6 06-07-2008 12:54 PM
New Dodge Ram henw Tow Vehicles 20 03-06-2008 10:05 AM
Dodge Ram 2500 Diesel Foiled Again Tow Vehicles 23 10-18-2007 09:01 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
