Old 01-18-2008, 06:46 PM   #1
cobra93
Profile:  1979 31' Sovereign
Baton Rouge , Louisiana
Images: 42
Dodge Ram 1500 Tow rating HELP!!!
Guys,
Please help me out. My father has a 1996 Dodge Ram 1500 Short Bed, Xtended cab with the 5.9L engine and full towing package and I assume the 3.73 rear axle based on the gas mileage. Can anyone tell me the max towing weight for this truck? I have looked everywhere and can't find it. Thanks!
-Don
cobra93 is offline   Reply With Quote
Old 01-18-2008, 07:14 PM   #2
Kajtek1
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
For new mega cab it is 7800 towing, 8510 gross Dodge - Vehicle Lineup
For Quad cab, short bed towing is only 2900 lb, long bed 6900.
Kajtek1 is offline   Reply With Quote
Old 01-18-2008, 07:33 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
The best place to get these numbers would be from the owners manual or a plate inside the door, if they did that 10+ years ago.
I found this:
1996 Dodge Ram 1500 Specifications, Data, and Car Specs at Autobuyguide.com
It says that the tow limit is 2109 kg which is about 4640 pounds.
Richard
Charter Member Four Corners Unit
Old 01-18-2008, 09:00 PM   #4
Motoman
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside , California
Cobra, don't assume on the rear end ratio. The mileage for mid 1990's truck was not always good. The 318 were pretty thrifty until the switched to fuel injection and increased the horse power. The 360s (5.9) were thirsty also. 3.73 is awful low for a stock mid nineties 1500. Get underneath and look for a tag attached to the rear cover of the rear housing. It should have the ratio stamped in. If its not on the back see if it is attached to the front near the input shaft. Another solution is to look in the glove compartment or in the engine compartment; they sometimes had a sticker attached that listed some of the options. Lastly, write down the VIN number and either talk with a dealer nearby or search the internet for 1996 Dodge VIN codes. You should be able to find out the ratio from the VIN also.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 01-18-2008, 09:02 PM   #5
Motoman
Motoman's Avatar
1960 18' "Footer"
Found this web site on decoding the Dodge Ram VIN.
How to read the vehicle identification number VIN on your Ram truck
SNU #157
FCU #004
Old 01-19-2008, 08:17 AM   #6
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
I can check my owner's manual later on...I have a 2000 ram, and it should be very similar to the '96.
What I can tell you from memory is that about the only feature that affects the tow rating significantly is the tranny. all combinations of half-tons have the same gcwr...so, its just that, minus the curb weight. (which isn't published anywhere). bigger bodies (long bed, extended cab) weigh more, so that comes off the tow rating. 4x4 weighs more. Engine and rear-end doesn't make a difference in their "rating"; the limiting factor must be something else...frame/wheels/brakes/suspension.
Oh, and 3.55 is a very common rear-end for these, so don't be surprised. It should be listed on a sticker inside the engine compartment.
anyway, the TR on mine (quad cab, short bed, 4x4) is 7200. Yours probably isn't alot different, if its an automatic.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 01-19-2008, 09:38 AM   #7
wbrownrr
wbrownrr's Avatar
Profile:  2002 22' International CCD
San Luis Obispo , California
Our 1997 Ram 1500 came stock with a 3.55 rear end, which we've swapped out for a 4.10. Follow the suggestions already posted for locating the ratio either on the door frame or in the engine compartment... it should be there someplace.
Wayne
2002 22' CCD
1997 Dodge Ram 1500 5.9L
wbrownrr is offline   Reply With Quote
Old 01-19-2008, 09:38 AM   #8
RBolton
RBolton's Avatar
Profile:  Belington , West Virginia
From 96 Owners manual. the manual does not differentiate between cab and bed configurations
2 Wheel Drive 5.9 Auto All Ratios Max Trailer Wt. 8,100# GCWR 12,500#
4 Wheel Drive 5.9 Auto All Ratios Max Trailer Wt. 7,700# GCWR 12,500#
Max Tongue Wt. All 1500s 700#
If you can give me your VIN, I can tell you the axle ratio.
Roger
RBolton is offline   Reply With Quote
Old 01-19-2008, 10:22 AM   #9
azflycaster
Phoenix , Arizona
Images: 58
Roger
Interesting that the Max Tongue weight is less then 10% of the Max Trailer weights.
Richard
Old 01-19-2008, 11:07 AM   #10
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
Send your VIN to customerassistre@daimlerchrysler.com They will completely decode it and send you a build sheet. If that email doesn't work try this link: DCAnswers
Incidently, my '99 (quad cab, short bed)
has the 3.55 Rear
Max Towing 7400
1999 Dodge Ram 1500 - Features & Specs - Engines & Performance - MSN Autos
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 01-19-2008, 11:16 AM   #11
RBolton
RBolton's Avatar
That figure was taken from a chart in the owners' manual labeled "Allowance Tongue Weights." This chart shows 900# for 2500s and 1200# for 3500s. Still at just less than 10% of their respective max trailer weights.
The text reads "Always load a trailer with 60% to 65% of the weight in the front of the trailer. This places 10% to 15% of the GTW on the tow hitch of your vehicle." It also states that trailer sway control and equalizing hitch are required for tongue weights above 350lbs.
Old 02-05-2008, 07:20 PM   #12
dodgeramv10
Profile:  Mitchell , Indiana
hmm
idk if this helps or not but i got a 97 dodge ram long bed 5.9 that the rear end ratio is 4:10 i think the manual said max pulling weight was about 7500 so i dk but but gl on the rest
dodgeramv10 is offline   Reply With Quote
New Dodge Ram henw Tow Vehicles 20 03-06-2008 10:05 AM
Tow 1985 Limited 31' with Dodge 1500? cobra93 Tow Vehicles 11 01-15-2008 11:36 AM
Dodge RAM 1500 SLT 5.9 liter tow vehicle abridges01 Tow Vehicles 10 08-17-2006 08:25 AM
2000 Bambi and 2000 Dodge 1500 Ram dbowren For Sale & Wanted 3 08-31-2004 07:40 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
