Old 03-10-2011, 06:38 PM   #1
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Dodge Power Wagon
Okay you Ram heads, I am considering a Dodge Ram 2500 Power Wagon as a tow vehicle for my 25FB. I have been towing with a Touareg V8 and I like being able to unhook and go 4 wheeling in to the back country. But sometimes I would like to take more stuff along. The Power Wagon has locking front and rear differentials and sway bar disconnect. But I am wondering about the stiffness of the ride when towing. Anyone out there towing with a PW? Give me some feedback...
mojo is offline   Reply With Quote
Old 03-10-2011, 07:14 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I don't know if anyone on this forum tows with a new PowerWagon, but Paul Cook, owner of the Kempner Power Wagon Museum in Texas, has a 2005 and his article on the truck is here: My 2005 POWER WAGON
Bill
Just my personal opinion
Old 03-10-2011, 07:47 PM   #3
JFScheck's Avatar
Rockville , Maryland
Images: 33
Mojo - Ford Super Duty diesel - hands down favorite with FX4 package...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 03-11-2011, 05:32 AM   #4
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Mojo,
I tow with a Dodge 2500. No problems with the suspension - not too harsh. Take some time to dial in the your hitch and the ride will be good in the driver seat and for the trailer. I would recommend light duty weight distribution bars unless you have the HAHA or Propride.
Pay not attention to JFSheck - he's still excited about his new truck
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-11-2011, 07:31 AM   #5
Lost in America
mojo's Avatar
Oak Creek , Arizona
I understand that the Power Wagon is built on a different frame than the 2500 with different suspension. So is it comparably more harsh?
Scheck, you're just a super duty maniac now...you need a 32 Classic to tow around.
Old 03-11-2011, 09:10 AM   #6
crispyboy's Avatar
1994 30' Excella
I don't know what the exact changes would be but common sense would tell me that purpose built off road vehicle will have more articulation built into the spring rates. I would reason that the truck could potentially have softer springs than a convention 3/4 ton (consider it a light 3/4 ton). Maybe look at the GVW ratings would tell the difference. Also I believe the sway bars disconnect on this vehicle which also give it the needed off road articulation.
check out this thread on pw's.
http://www.airforums.com/forums/f463...-38681-15.html
WBCCI # 3072
Old 03-11-2011, 01:02 PM   #7
JFScheck's Avatar
Images: 33
Yea - but my "T-Rex" is still loved, more so then my "Pepper ever was"....
Power Wagon (like the F-150 Raptor) does have a different suspension setup for off-road adventures - I would think it would be a bit more pushing on the ole' Airstream.
BUT - for us "T-Rex" folks used to the Sport Suspension of our SUV's - my Super Duty rides the same (granted 200lbs of A.R.E topper help)...
**I Love U.S.A.**
Old 03-11-2011, 02:07 PM   #8
crispyboy's Avatar
1994 30' Excella
I found a little info on a 2005 model.
New Dodge Power Wagon - Off-Road Adventures Magazine
Copied from an off road thread on another website.
"What, you ask, is the difference between a Dodge Ram and a PowerWagon ??
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1. "
WBCCI # 3072
Old 03-11-2011, 06:48 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I have a 2WD 3/4T [2004]. IFS, rack & pinion steering, manual transmission, highway rib tires. Diesel engine. A different beast. But what I read elsewhere about the gasoline engine in a 3/4T is encouraging. Taller, offroad tires, etc, make for being more careful on the highway. That said, the rear springs may not be so different. In fact The Dodge Towing Guide makes it look as if the rear axle and spring capacity are the same on a 2009 model Po-W as the diesel.
If so, yes, it is a stiff combination. I towed a trailer with a real frame (Silver Streak) and the question didn't concern me about flex and such. The one that did (relatively) was that I was quickly against my payload "limit" with the heavy TW of an 8k GVWR trailer.
I towed that about 100 miles one day w/o a WDH to see how it felt and the truck was as stable as could be. Once I had my Hensley installed I was never able to get the weight distribution correct (lousy "stinger"; no tilt feature to induce extra leverage) but the anti-sway was, of course, perfect.
My concern would be getting the hitch rigging just right. Each vehicle level. Proper leverage via weight scale readings. After that I would think that tire pressures according to load (and manufacturer) would allay the worst of it.
There are others around here towing with 3rd and 4th Generation Dodge diesel trucks; might do a search. I think the rear axle (if the above proves correct) will cross-reference your search adequately for comparison. (The axle is an AAM 11.5").
Old 03-11-2011, 07:23 PM   #10
Valrico , Florida
The Power Wagon is an incredible 3/4 ton 4x4 Ram. With 4.56 gears, 5.7 Hemi, Locking Ft & Rear Diff's, Factory Warn Winch, Electronic Disconnect Sway Bar, Bilstein Shocks, 33" BFG All Terrain Tires on Forged Aluminum 8 Lug Wheels. The Springs are set on the Softer Side for better Articulation resulting in a superior Hwy Ride compared to the Regular Ram 2500. The Tow rating is less the the standard Ram 2500 4x4 because of the softer sprung Rear Leaf Springs. A set of Airbags will assist in any Drop in the Rear when Hitched..Towing up to 10,000 lbs would be very comfortable.
stufarmer is offline   Reply With Quote
Old 03-11-2011, 08:03 PM   #11
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
I am...I am
My 1973 Powerwagon does great!!! So the new ones have got to be good?!
mopariac is offline   Reply With Quote
Old 03-11-2011, 10:27 PM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
So does my 1973 W200.
Bill
Old 10-09-2011, 01:11 PM   #13
AirConditioner's Avatar
just starting to tow here with a '66 WM300 power wagon, has plenty of power but brakes are scary until I do s disk conversion. Towing my 72 overlander just for vintage meets close to home!
AirConditioner is offline   Reply With Quote
Old 10-09-2011, 06:44 PM   #14
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
We need some pictures.
Bill
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Break-AWAY Power. raebaker06 All Argosy Trailers 11 05-25-2011 10:15 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
Progressive Dynamics Inteli-Power 4060 Power Center 68 Overlander Commercial Listings 0 01-21-2011 11:24 PM
