Old 12-06-2007, 03:33 PM   #1
1999 30' Excella 1000
rio rancho , New Mexico
Question dodge dakota towing 27'
have a 2006 dodge dakota 4wd v8 hd. book sez 6800 lbs towing cap.planning to move 27' airstream 500 miles two or three times a year. is this possible+safe? thanks
airmac is offline   Reply With Quote
Old 12-06-2007, 03:38 PM   #2
Send a message via Yahoo to dhe9
dakota hauling
hello,
i would think your motor will have the power but wonder if the wheel base is too short on that truck. if it is then your trailer may be controling your truck. this is not good, also wonder about the braking?
i plan on following this thread.
david
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 12-06-2007, 03:45 PM   #3
Druupy's Avatar
2005 28' Safari
Port Orchard , Washington
Possible, yes.
Will you enjoy the trip? Probably not.
Safe, maybe, up to the operator.
That trailer is at or above the limit of a dakota.
There is enough horsepower, if you have the 5.7 liter, but there is not really enough truck(length-width-weight).
On the flat with no wind, you will be fine.
Going downhill and arround a corner, you will wish for more truck.
Druupy is offline   Reply With Quote
Old 12-06-2007, 04:23 PM   #4
RBolton's Avatar
Belington , West Virginia
What cab configuration do you have? Regular, Club or Quad? Gear ratio? 3:55 or 3:90? V-8 would be 4.7 but I'm not aware of an HD version. Factory tow pkg? I pulled my 26" Argosy with a Dodge 1500 Reg Cab short bed 4WD, 4.7, 3:55 and tow pkg and felt that I was right at its' limit.
RBolton is offline   Reply With Quote
Old 12-06-2007, 04:28 PM   #5
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I wouldn't want to pull that trailer with a Dakota. I have a 22'CCD and pulled it with a Nissan Titan for 1 year. I now have a 1 ton Dodge and enjoy pulling it much more.Bigger truck makes for a better pull
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 12-06-2007, 04:50 PM   #6
Smile dakota
move is only empty trailer +light weight in truck. hd is 9.25 tranny#. gear is 3.55. v8 is 4.7. truck is rated 6800 towing + trailer is 5400 unloaded. it's just to relocate empty trailer. not real rving. if i start real regular rving i'll go 1 ton.
thanks for the input
Old 12-06-2007, 05:06 PM   #7
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Airmac
Have the same trailer as you. We used to use a 3/4 ton Sububan with the 454 and it worked fine. Went to 2008 Ford F250 CC with the turbo diesel. What a HUGE difference that made in towing. I cannot tell the AS is behind me and the acceleration on hills is amazing. Others do not lie-the difference is in the enjoyment of towing your new baby.
altamont is offline   Reply With Quote
Old 12-06-2007, 05:21 PM   #8
RBolton's Avatar
airmac,
Welcome to the forum. I just saw this is your first post. You'll appreciate everyones help but it is very easy for us to stray off topic. I'm sure we'll all agree that bigger is better. Your question was about your own truck and not about what we are towing with.
I think the majority of us will agree that you don't have quite enough truck. If you could make one modification to your Dakota to make it more suitable to the task it would be to make it longer. I'm certain you could make the move with your truck and not be aware of its shortcomings until you made the same trip with a bigger more powerful truck.
Old 12-06-2007, 05:55 PM   #9
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
We have a 2002 Dakota quad cab RWD with fiberglass topper and the small V8. We bought it to tow my 1500 lb racecar on a flatbed trailer. The rolling weight (including the truck toolbox on the front of the trailer and all of the race gear/tools stuffed in it and the back of the truck) not counting the truck/gas is probably about 3500 lbs total and it handles it just fine. We almost don't know it's there. That is one darn good truck.
We have also towed our 1984 Chevy dually on a bigger metal flatbed trailer (maybe 6000 lbs total?) and it definitely worked hard for that. Stopping was the issue there, but we didn't have any choice. Brad had broken down in the dually and the Dakota was the only thing we had at the time to go get him with.
If I were you I probably would not use the Dakota for the everyday camping TV, but to move your unladen trailer a couple times a year I wouldn't have any qualms at all. Just be careful going down inclines and in winds.
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 12-06-2007, 06:21 PM   #10
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Try it one time and see how you like it. If you don't, consider renting one for future moves. Let us know how it feels to you.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 12-06-2007, 06:27 PM   #11
RBolton's Avatar
Alumatube, I agree they are great trucks... for their size. We still don't know what wheelbase airmacs' truck is. A long wheelbase 2wd towing 3500 pounds is not the same as a 4wd towing almost 6000 pounds. If airmac has a short wheelbase Dakota then he does not have the proper tow vehicle and if he has the long wheelbase he is close to being maxed out. It sounds like you're saying it's ok to be a little unsafe if it's only evey once in a while. Along with inclines and wind don't forget panic stops and sudden avoidance maneuvers.
Old 12-06-2007, 06:41 PM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
RBolton,
From what I can find, the Dakotas come in one wheelbase 131" the same as my 1973 Dodge PowerWagon and 4" longer than my 1977 Lincoln. The Dakota is not a mini truck.
Bill
Just my personal opinion
Old 12-06-2007, 06:48 PM   #13
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Probably not in my comfort zone, but to each his own.
SuEllyn & Brian McCabe
Old 12-06-2007, 06:55 PM   #14
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Don't do what I did, but...
While I don't recommend this, and I wouldn't do it again, here's how I got into Airstreaming.
I bought a '98 25' Safari a couple of hours away. My only TV was a '88 Toyota 4-Runner. Didn't know any better, brought it home and had no handling issues at all.
So far so good, so I decided to take it on vacation. To Yellowstone.
That combo was rock solid in spite of everything I have since been told and read here. My only issue - and it was a huge one - was that it was way underpowered.
You will get lots of opinions here on the size needed for a TV. While I don't recommend the set-up that I used above, I highly discount the bigger is better mantra that is so often given here. From folks that are merely passing on what they have read/heard from others.
Dave
Fyrzowt is offline   Reply With Quote
Towing a 27' Overlander with a Jeep Liberty Silver Threads Tow Vehicles 14 04-25-2013 05:38 AM
Towing a '69 Tradewind-Dakota? shinybean Tow Vehicles 4 11-16-2006 04:01 PM
Dodge Dakota + Safari 23' Widgeon Tow Vehicles 6 11-20-2005 02:50 PM
Towing Excella 34' 1000 w/Dodge Ram pscottn Tow Vehicles 5 02-28-2004 05:49 PM
Dodge Dakota Sport Towing Mirrors (2002 model) Paul and Sue Tow Vehicles 1 05-15-2003 10:25 AM
