Old 03-09-2014, 09:34 AM   #1
SteveH's Avatar
Common Sense , Texas
Dodge 3/4 Ton Truck Brake Dust
My '12 3/4 ton Dodge Ram truck is real bad about producing copious amount of brake dust on the front wheels only, even though it has disc brakes in the rear also.
Wondering if a different type of brake pad would possibly help remedy the problem and maybe even improve the braking performance. Anyone have any thoughts on this?
Regards,
Steve
Old 03-09-2014, 09:43 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I'm not an expert, but since front brakes work harder than rear brakes, this is probably completely normal.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 03-09-2014, 09:46 AM   #3
r carl's Avatar
Lin , Ne
I'm thinking ur driving style as you can wear out Michelins in 38k miles.
Old 03-09-2014, 09:50 AM   #4
SteveH's Avatar
Actually, the truck had 20+K miles on it when I got it, the tires had never been rotated, and were rounded badly in the front. So, the tire wear is mostly not my fault, and contrary to some people's beliefs on here, I do need to use the brakes to stop from time to time.
Regards,
Steve
Old 03-09-2014, 11:10 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Steve,
I've owned my 2500 Cummins since new '07. Brakes are original. I have about 170K on it and almost zero brake dust. I bet we have different pad material.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-09-2014, 11:37 AM   #6
jcl
Vancouver , British Columbia
I have changed pads on several new vehicles to reduce brake dust. The manufacturer chooses pad composition based on initial bite, stopping power, fade resistance, pad life, cost, pad noise, and dust. There are probably more factors, but those are on the list. Dust may have come in last in their analysis, but it might count for more in yours. See if they have changed pads and have two part numbers. If not, consider aftermarket pads but consider the other factors as well. Aftermarket suppliers that offer multiple pad compositions will compare them on the above factors. Not sure what is available for your specific vehicle.
Jeff
jcl is offline   Reply With Quote
Old 03-09-2014, 11:40 AM   #7
GCinSC2's Avatar
My bad, truck is a 2005 not '07 bought in 2005.
S/OS #001
Old 03-09-2014, 12:37 PM   #8
1981 31' Excella II
New Market , Alabama
Ceramic pads will produce the least dust.
Perry
Old 03-09-2014, 01:55 PM   #9
jcl
Steve H:
Here is an example comparison of the performance of various pad compounds, with all pads from the same manufacturer (Centric, in this case). The metrics are relative, not absolute, but provide some insight into the sorts of trade-offs you can make. I know Centric produces pads for the RAM 2500 in at least four of these compositions, but not sure about your specific model year.
Centric Parts Brake Pads - Comparison
I had great results with Axxis Deluxe Advanced pads (pads which Axxis called ceramic) used on several cars to reduce black dust, but I traded off some pad noise (first stop of the day, then they were quiet). No increased fade, change in pedal feel, or lack of bite, in that case. Centric say that their ceramic pads have less dust than their long life fleet pads, but less fade resistance.
I would say the pads with less tendency to produce visible dust are the ones that don't use carbon black as a filler material.
Jeff
Old 03-23-2014, 09:30 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Stick with MOPAR Premium linings. My first set went 120k, and there is yet no need to replace at 197k. Dust is unremarkable.
None of these trucks should be going through brakes or tires prior to 70k miles. Stick with factory original, not "value" MOPAR parts (as most dealers push).
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
No 3/4 ton SUVs on the market anymore? coastal Tow Vehicles 46 03-15-2014 02:09 PM
Brake Resistor??? Aviator Brakes & Brake Controllers 5 01-30-2012 12:35 PM
Anyone have a Thule Xsporter Truck Rack? bike_addict Tow Vehicles 8 10-20-2011 04:59 AM
