This is especially a problem in Northern climes, as well as areas near the ocean. Another item that needs to be checked is the wheel cylinders, they can become corroded, and stick in place, causing the rear brakes to not work, but you still have a good feeling pedal. It would be a really good idea to check them, if you have rear drum brakes, when you replace the lines.
