Old 07-19-2012, 10:59 AM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Do you have an integrated brake controller?
How's it working out for you?
There were some early reports of compatibility problems particularly with hydraulic brakes. Aside from that, how are these products working out there out in the real world?
Old 07-19-2012, 12:21 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Mine works very well. The newest latest and greatest integratedcontrollers give the option of electric, or eletric bydraulic.
Old 07-19-2012, 12:28 PM   #3
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I've got one on my '08 GMC Duramax pickup. I have several trailers - only one here relevant is a '99 Safari 23'. All my trailers have electric drum brakes. All work very well indeed.
The onboard brake controller reads actual brake master cylinder pressure ... that is, it reads how hard you are pressing on the brake pedal (including power assist). Thus there is not the lag that can accompany controllers that read tow vehicle deceleration. No lag, right-now response. I'm quite pleased with my setup. I do understand that if you have a Kodiak or similar disc brake system, you have to do a little "trickery" to make the brake controller "see" the trailer brakes, inasmuch as it is looking for inductive impedance, and as I understand it, the Kodiak type system does not present a sufficient load to the controller to be recognized. This is my understanding only, no actual experience.
Others may have had other experiences, but I'll never go back to an aftermarket controller ... this is just too simple and reliable.
AirsDream is offline   Reply With Quote
Old 07-19-2012, 02:13 PM   #4
SteveH's Avatar
Common Sense , Texas
I also have an '08 GMC Duramax, and the integrated brake controller is the best I've had.
Old 07-19-2012, 05:53 PM   #5
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
My 2010 Ford F-150 has an integrated brake controller. It works seamlessly in general, and can be adjusted for long downgrades, to shift more of the braking burden to the trailer brakes, if necessary.
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 07-19-2012, 06:16 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have a 2011 Silverado. The integrated trailer brake controller works great with our Airstream's electric brakes.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 09-23-2012, 10:49 AM   #7
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Brian
Brian,
Did you do anything to your factory integrated brake controller on your 2011 GMC for it to work with your AS?. Mine on 2012 Denali Duramax is not working on my 2006 Classic with hydraulic ActiBrake / Disc brakes. Any help will be heatedly appreciated . Thanks
F450Harley is offline   Reply With Quote
Old 09-23-2012, 02:06 PM   #8
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
My 2008 F-250 has integrated brake and it has always worked no matter which trailer I am pulling. That pluss the up-fitter switches, are a really neat item. My '08 could have ordered the backup camera and I chose not to order it, in retrospect, I should have.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 09-23-2012, 02:25 PM   #9
2006 30' Classic
Milton , Florida
2010 Ford ITBC
Our 2010 FORD ITBC works flawlessly on our Dexter hydraulic disc brake system.
F. A. Meloy
2006 30' Classic
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 10-06-2012, 08:37 AM   #10
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We had one on our F150 and have one now on our F250 Diesel, both worked and work fine without issue. As noted in another post one can adjust while moving simply by pushing a + of - button.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-06-2012, 10:20 AM   #11
2005 28' Safari
saline , Michigan
Our 2011 Silverado's controller works great and is easily accessible to the driver. One thing important about the integrated ones on GM's is that they have "stabiltrak" or whatever it's called. It allows the truck's computer to apply brakes on one side of both the tow vehicle and trailer when one encounters an unstable condition such as sway. I questioned a friend of mine who is an engineer at GM and who works on that system and he says it works pretty well. You can't get that with an after market controller, I don't believe.
Kosm1o is offline   Reply With Quote
Old 10-07-2012, 09:07 AM   #12
2006 30' Classic
Milton , Florida
How Does this Work?
Originally Posted by Kosm1o View Post
... It allows the truck's computer to apply brakes on one side of both the tow vehicle and trailer when one encounters an unstable condition such as sway. ...
I do not understand how this would be possible on my 2006 Classic with hydraulic disc brakes. The E/H hydraulic actuator powers all four wheel brakes simultaneously, and there is no provision for selecting individual wheels.
How is this possible on electric brakes? Are there two seperate signal wires going from the tow vehicle to the trailer?
F. A. Meloy
2006 30' Classic
Old 10-07-2012, 09:38 AM   #13
2005 28' Safari
saline , Michigan
I will have to ask when I see him next time.
Old 10-07-2012, 12:33 PM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our 2012 (Dodge) Ram Express has the ITBC, which also displays operation on the instrument panel vehicle info center. It has settings for light and heavy trailer electric, and electric-hydraulic brakes. Operation is convenient and so far works nicely.
I doubt the electronic sway control operates trailer brakes, but it does reduce engine speed and apply separate brake pressure as needed. If these were applied with some strength, the reduction in vehicle speed would activate the inertia-based brake controller proportionally to apply trailer braking, thereby also reducing trailer sway.
Good system to have for extensive trailer use.
doug k
