Old 10-29-2014, 10:27 AM   #29
z , North Carolina
Okay, so the MB or Jeep can PULL IT, what about
Morning folks. I have been a lurker here for awhile, and have consumed plenty of knowledge form this great board. AS are a cult if ya ask me, and I want to join the cult. We are looking, but looking with confidence after finding this board.
I own a cult boat (Shamrock) and am the admin of the web page for them. I want to thank the numerous good folks on here that will bend over backwards to help a fellow ASer with any ?'s they have. That kind of help is priceless. We do the same on my board.
Okay, so I have been around boats all of my life. My grandmother had me fishing on the Chesapeake bay when I was only one month old. I didn't catch anything obviously, but I was gettin me sealegs. I have owned boats for years, and almost all of them have been on a trailer. I know the AS's come with brakes. Pads are pitiful, discs rule I might add, but let me ask you guys that are towing with a MB or a Jeep/small SUV with a 30'er. Do you feel confident that you could stop that rig in time when you HAD to stop it? I understand you can make modifications to your hitch to help your vehicle with the weight, (WDH & others) but one thing I fail to see with this post in particular, is anyone asking the very simple question: How do you stop it? Sure that MB & Jeep/small SUV might be able to pull that 30'er, but can you stop it quickly? With the political correctness going around these days, and the lawsuits that go with them, aren't you guys a little fearful of having your butts sued if you got into an accident and some smart lawyer proved that your vehicle was @ or beyond it's towing capacity? I don't know guys & gals, I'm not trying to stir the pot, but I have always preferred to have a bigger horse than trailer. If I need to stop my rig quickly, I don't want to be worried about how well it can do it, or watch what I put in my vehicle before setting out on my journey. I have a Chevy 3/4 ton PU, and the brakes on this beast are massive.
We are looking at 25's & 27's, and I have no doubt my truck could pull AND STOP either of them quickly & efficiently. I'm just the newbie here, so please feel free to chime in. I'm by no means a rookie to pulling large loads, and have seen my fair share of accidents with vehicles that simply could not stop or properly control the load they were dragging. Under duress braking can be very tricky. If you don't know how to do it, the easiest way to learn is with a tow vehicle that can handle the job/load it's been given.
Again, not trying to stir the pot, and certainly not out to ruffle anyones feathers, just looking at this from the many years of towing that I have under me belt. Placing a piece of equipment under the maximum load, or close to it, is never good for ANY piece of equipment.
FishinHatteras is offline   Reply With Quote
Old 10-29-2014, 11:02 AM   #30
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Diesel SUV for 23' or 25' FC
The question about brakes is two fold. One a heavy truck needs more to stop itself. Those larger brakes aren't really going to make that much difference.
Antilock disc brakes (see TUSON) on the trailer will make a real difference as drums are almost constantly out of adjustment in themselves and with each other. Plus they fade rapidly
Disc will help bring the combined rig to a full stop sooner than the tow vehicle when solo If one is painstaking
A ProPride hitch and discs is pretty well state of the art and worth your investigation. A pickup may also benefit from upgrades to shocks and suspension as it is generally the worst tow vehicle. An AS can get through a slalom faster than can a truck while solo
Take your time
slowmover is online now   Reply With Quote
Old 10-29-2014, 11:22 AM   #31
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
My "undersized" vehicle has large vented rotors, 4 piston Brembo calipers and stops its own weight more than 30ft sooner from 60mph than a typical pickup truck.... with much more control and using tires with more grip. It's actually more like 35ft...yes, 35ft sooner. Does the large truck miraculously gain braking force when you strap on a trailer? So to answer your question, yes, I have confidence that I can bring my combination to a controlled stop under emergency conditions. I've tested it and it may surprise you . Perhaps I should ask you if your 6500lbs+ truck has enough braking force to not pile through 2 or 3 cars on the highway if an emergency stop would occur (even without towing a load) or if you could maintain control while doing so.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 10-29-2014, 11:28 AM   #32
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Sham' welcome to the forums and I think you will enjoy an Airstream. As for stirring the pot, all tow and hitch threads descend into junk sooner or later and the mod's wisely shut it down.
But here's a couple of thoughts on towing and brakes. Airstreams now come with drum brakes only, but the factory service or other shops can convert them to disc brakes. Either will stop the airstream. Our drums will stop the trailer and our 5400# truck.
Heavy duty trucks have larger brakes than 1/2 ton trucks, good thing because they often have 2,000# more to stop. Here's one test, for what it's worth, of light and heavy duty trucks of the same make. The light truck, with smaller brakes, stops in a shorter distance. With equal Airstreams, I don't see a reason to believe that would change and have seen no tests to show it would.
2014 Ram 1500 EcoDiesel vs. 2014 Ram 2500 - Sibling Rivalry - Diesel Power Magazine
As for handling, Can-Am Airstream in London, Ontario has tested these different rigs in handling tests and the full independent suspension SUV's, vans, and passenger cars outperformed the heavy duty trucks. They are the only Airstream dealer who has recently compared these different vehicles in actual road tests that I am aware of.
As for durability, yes I would think the heavy duty vehicle may last longer. But they should costing much more to buy, service, repair, and in many cases fuel. And many, perhaps most recreational Airstream users trade either one long before either wears out.
We use a half-ton truck for our Airstream. The only disadvantage to heavy duty I see is less payload capability, which we manage without difficulty. The short (120") wheelbase disadvantage of our particular truck is managed effortlessly with a ProPride hitch which allows no sway or push from heavy winds or semis on Interstate highways. It's a pleasure to drive with or without the Airstream attached.
Doug and Cheryl
Old 10-29-2014, 11:30 AM   #33
ericpeltier's Avatar
Superior , Colorado
Originally Posted by mje View Post
- It's sibling, Porsche Cayenne Diesel, has a payload of 1,676#.
Wow, that's ~125 lbs more capacity than my Armada!
ericpeltier is offline   Reply With Quote
Old 10-29-2014, 12:13 PM   #34
Road Ruler's Avatar
Images: 38
Originally Posted by rostam View Post
Speaking of payload,
You need to check the numbers... Most folks are surprised to learn our 93 Nissan Mini Van had a 1,425lb payload rating. From that era Dodge posted the payload for one of their Ram pick ups at a pinch over 1,300 Ibs.
Note our car has a payload rating of under 1,000lbs. Connected ready for travel the CAT scale shows we are at that max rating but not over. No problem.
Old 10-29-2014, 12:36 PM   #35
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Payload is an interesting topic. A family member had a Highlander and complained of the payload....it was ~1500lbs.
He traded in the Highlander and decided that a Tundra 4x4 Crewmax with a ginormous V8 would be better....he could put his whole family in the cab, pull his trailer with ease, fill the bed with "whatever" he wants and still put kayaks on the roof with a custom metal rack. He also bought a MUCH bigger 36' SOB trailer (7K dry)....no problem, a huge truck can hold/pull it all....after all it has a 9K towing capacity.
His Tundra payload is ~1300lbs .
He didn't/doesn't want to listen.
'15 Classic
Instagram: cory_can
Old 10-29-2014, 01:45 PM   #36
mje
2013 30' Flying Cloud
- Yea, like I mentioned before, payload capacities is pretty confusing. Just do it right, listen to the experts, and stay within reasonable limits (weight, speed, distance between you and others), check your tire pressures, and repair anything that requires it, and respect weather.
- VW Touaregs and their siblings have very good braking system -- Porsche is strong on this arena and uses Brembo brakes on Touaregs, Cayennes, Q7's as well as number of other cars. This was one of the factors of my decision going with them. I had to tow 20' FC AS for a few hours without any trailer brakes (I hate that, but I had to deliver it under pressure of time) but not once I feel unsafe stopping the whole rig. So, based on that experience, I know that I can comfortably stop 30'er with proper braking setup.
I used to own Jeep Commander V8 before VW and it's towing and braking capabilities were also great. But that experience was limited to only bass boats and 20' FC. If I had to stick with Commander, I will not be afraid to use it to tow 30'er (non-Classic).
What you need varies, but never hurt to ask this expert --> Andy at Can-Am!!! He will tell you directly if your requested set up is possible and what is needed to be done safely.
mje is offline   Reply With Quote
Old 10-29-2014, 02:52 PM   #37
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Payload has to do with brake capacity. Real limit is axle wheel tire ratings
Old 10-30-2014, 05:26 PM   #38
Los Gatos , California
Can anyone post the full specs on the Mercedes gl 350?
Mercedes website doesn't show much
Estoniankid is offline   Reply With Quote
Old 10-30-2014, 06:01 PM   #39
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
Last month came back from Alaska trip of over 9,000 miles with my 2012 GL350 Blue Tech (diesel). To my surprise I drove 98% of the time on Cruise without any problem including uphill and downhill, the car automatically changed gear by itself. To change the speed I just had to move the cruise lever up and down as needed. In the process never had to use the brakes. Pulling 23 FB with lots of luggage in trunk I got over 15 mpg. Personally I do not like to use high profile vehicles such as Airstream in combination with Mercedes.
I did consider VW diesel SUV, the MB won due to the fact I always drove MB,s and are very familiar with them.
Good luck on your decision I am sure all other SUV are capable as well.
Zia is offline   Reply With Quote
Old 01-10-2015, 01:51 PM   #40
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
RCLOUD9: I have a 2007 Diesel GC and tow a 2013 20'FC. It is as if nothing is behind you and the torque up the hills is amazing. I am thinking of trading up to either the FC or Int't 23' FB. It sounds like you have no problems with your diesel GC towing the 23FB. Any engine heat issues on mountain climbs?
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 01-11-2015, 01:06 PM   #41
Zia
2007 20' Safari
Irvine , California
No heating problem what so ever during climbing up to 7,200 ft,
The only issue with the GL diesel is that it does not have a spare. For Alaskan trip I took a spare in the trunk made up of off market spare and used dire both from ebay. Normal travel in US with the no flat tires are good enough. Good luck.
SUV to pull an Airstream MarilynPerlm Tow Vehicles 41 06-08-2015 01:03 PM
SUV's and generators Don Cook Generators & Solar Power 21 03-23-2007 10:01 PM
suv & airstream trailer photoshoot valeria Our Community 4 03-25-2003 03:51 PM
Volvo SUV & Bambi?? Roxie On The Road... 5 11-05-2002 07:09 AM
Towing a small 60s trailer with a SUV... Andy R Tow Vehicles 15 03-30-2002 07:57 PM
