Old 07-08-2008, 12:05 PM   #1
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Diesel Oil change over fill?
Brought in the DuraMax for annual service last week. I always bring my own synthetic as the dealer does NOT have syn for diesel (so I was told). I buy syn in gallon containers; 3 gal= 12 quarts.
I always ask the dealer to place the remaining two quart back in the truck. Sometimes they do, sometimes they don’t (no big deal). Last week, they did not.
Preparing for an upcoming trip, I checked the dipstick, it is over the “Full” mark. I am now concerned that they dumped the entire 12 quarts in. The DuraMax is rated for 10 qts w/filter change.
Will over filling a diesel cause any harm?
Will it just burn off?
Truck is running fine, no visible smoke, etc.
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-08-2008, 12:42 PM   #2
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Diesels are similar to gas engines when it comes to the lubricating oil. I believe the problem comes from the crankshaft dipping into the oil pool since it is too high, causing splashing and sloshing, adding air to the oil. I believe this is referred to as "foaming" the oil. Pull the dipstick while it is running and check for bubbles.
I would get that 2 quarts back out.
The easiest way might be to use one of those oil change pumps where you snake a tube down the dipstick tube and pump it out with an electric drill powered pump. That way you don't have to deal with the drain plug and trying to get it back in after only 2 quarts.
Good luck!
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 07-08-2008, 12:53 PM   #3
2007 25' Classic
Hydes
Add one of these . It will be easy to change your oil or drain off any over fill FUMOTO ENGINEERING I installed one on my F350 and it makes oil changes easier and withno mess.
craftsman is offline   Reply With Quote
Old 07-08-2008, 01:12 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
That will only work the Next Time the dumb dealer over fills you.
Use the tube down the dip stick method and get the extra oil out ASAP as foaming will occur every time you drive.
If they did not give you the extra 2 quarts they either dumped it in the engine or kept it. In either case I would lok for a new place to get the oil changed.
2004 Excursion 4x4
Old 07-08-2008, 01:35 PM   #5
_
hi billtex...
how much OVER the fill line...
engine hot, and a tad over isn't unusual.
however i agree with the advice to SUCK a quart or 2 out the top and recheck...
i've had the same issue, when providing 4 gallons of syn to the dealer.
now i keep a spare empty gallon jug and provide the service guys with the 3 full jugs and exact partially filled 4th...
which means any OVER filling by the service folks takes a LOT more effort...
cheers
2air'
Old 07-08-2008, 02:15 PM   #6
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
You also chance the engine crankcase not breathing properly and causing oil leaks around the seals. I would just get a drain pan, wear a short sleeve shirt, have a rag or two handy and pull the plug. It is not hard to do this procedure, just a little messy. Make sure the engine has cooled off overnight.
crispyboy is offline   Reply With Quote
Old 07-08-2008, 02:47 PM   #7
HowieE's Avatar
Images: 12
Please do not try this at home as a means of draining off 2 quarts of oil. Once you open the drain you will not be able to insert the plug while the oil is draining without making a real mess. Diesel engine oil stain does not come out so anything you are wearing will be toast if you spill on it.
2004 Excursion 4x4
Old 07-08-2008, 02:57 PM   #8
richinny's Avatar
2011 34' Classic
how hard would it be and how much oil would come out when removing the filter?
Ricky
Old 07-08-2008, 03:45 PM   #9
HowieE's Avatar
Images: 12
This would be a long drawn out process. The filter holds less than a quart and you can not just drain it once removed because of the back flow valve built into the filter.
If you had an old filter and were willing to punch a hole in it just inside the O ring you could put it on, start the engine then remove it and drain the oil, replace it for another pass.
If I remember the oil filter in a D Max is not located in the best place for this.
2004 Excursion 4x4
Old 07-08-2008, 03:49 PM   #10
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Bill Tex...I have a 2006 GMC with the Duramax diesel. In GM's Duramax Manual it states the following: "Notice: Do not add too much oil. If the engine has so much oil that the oil level gets above the cross-hatched area that shows the proper range, the engine could be damaged." I would drain the oil down to the correct level.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 07-08-2008, 04:27 PM   #11
1976 25' Caravanner
Campton , New Hampshire
You could also bring it back and demand that they do it correctly with your choice of oil , and also ask them to return the two extra quarts that you supplied . Then find another place. They have no excuse , they're the professionals .
ticki2 is offline   Reply With Quote
Old 07-08-2008, 06:05 PM   #12
HowieE's Avatar
Images: 12
Sure wish it was that easy. Last summer a Chevy dealer in Ct destroyed my diesel engine against my requested orders. I ask they NOT to START the engine. but to remove the converter cover and if that was OK remove the pan and check things out. 2 days later they called me and said I needed a new engine. I asked how they determined that. They said the started the engine. In doing so they broke the crank in 2 places. I had no recourse, they are "Professionals".
Thats is why I often suggest that you never trust a "Stealer"
2004 Excursion 4x4
Old 07-08-2008, 06:45 PM   #13
1976 25' Caravanner
I hear you , it should have read " suppose to be the professionals"
Old 07-09-2008, 06:23 AM   #14
1 Rivet Short
1989 25' Excella
Hi Bob, I did call them and they were very accomodating. Problem is; they are an hour from here, I am leaving Saturday, and don't really have the time to go there/back, etc.
They offered to drain and replace as needed. Of course, over the phone, they could not verify if this actually happened.
I just know, the dipstick is over the x-hatch marks. I did NOT get the extra 2 qts returned and yes, the manual of course, says “do not over fill”. It is difficult to say how much over it really is without having any “evidence”.
I will drain it down myself tonight, just don’t have the time to get back to the dealer.
In truth, they are a pretty good dealership to work with. In this case, I can’t really say there is a problem…there is potential…I have no proof…just a bit paranoid I guess! They offered to make good, that’s all I can ask.
Thanx All, Bill
Duramax oil change BillTex Tow Vehicles 35 04-23-2009 11:50 AM
Oil and Filter Change gypsychris Mechanics Corner - Engines, Transmission & More... 6 05-24-2008 08:30 PM
Honda oil change question 63air Off Topic Forum 11 05-12-2008 07:34 AM
Oil Change Fear and Woes Chaplain Kent Classic Motorhomes 14 04-09-2006 07:09 PM
Should I change my oil? Turtle Mechanics Corner - Engines, Transmission & More... 18 07-07-2004 12:18 PM
