Old 05-26-2011, 03:34 AM   #1
Be Calm, Have a Cupcake
Secguru's Avatar
Houston , Texas
Diesel Gauges
I have a red 2006 Dodge Ram 2500 4x4 Laramie Crew Cab "The Tomato" that gets wonderful fuel economy. I tow a 1998 34' Airstream.
I want to equip the Tomato with a full set of gauges (3) on the A-Frame Pillar. I'm thinking about:
- Transmission Temp
- Exhaust Temp
- A third gauge to be determined
What gauge would you recommend for the third?
Secguru
Would you rather have a mansion full of money or a trailer full of love?
Secguru is offline   Reply With Quote
Old 05-26-2011, 04:15 AM   #2
FLMarine's Avatar
2009 27' FB International
_ , Florida
I have a 2005 Dodge Ram 2500 and have have the Issopro gauges for 5 years. I have Exhaust Temp, Turbo Boost, and Transmission Temp. I'd recommend getting the Turbo Boost because you're able to see how much boost you're using aka more boost means more fuel being used. You're also able to see if something is not working right such as there isn't enough boost.
I have my gauges mounted below the air conditioning controls and I like how they don't take up any more of my line of sight which is bad enough with the A pillar as it is. I'll post some pictures of my gauges this afternoon. One other good thing about the Issopro gauges is that they are matched to the background of the Dodges instrument panel.
FLMarine is offline   Reply With Quote
Old 05-26-2011, 07:20 AM   #3
Secguru's Avatar
Houston , Texas
FLMarine I'm very interested in seeing a photo of your gauge setup. I looked at the ISSOPRO Website. I assume you are talking about the EV2 Gauges. The idea sounds good.
I was also thinking about Boost being the third gauge and I share your concern about the A-Pillar visibility, but I didn't know where else to mount them so that they would look good.
Thanks for your suggestion. I'm looking forward to seeing the pix.
Secguru
Old 05-26-2011, 07:42 AM   #4
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
A boost gauge would be good but I would recommend a fuel pressure gauge tapped in between the last filter and the injection pump. I also highly recommend a 2 micron filter on a remote filter head after the factory filter. Bosch recommends less than 3 microns for the injectors and no one makes a 3 mic for the factory fuel filter. My fuel psi gauge is tapped into the "out" port of the remote filter head. This gauge will tell you when the filter is getting plugged and needs changed.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 05-26-2011, 10:11 AM   #5
FLMarine's Avatar
_ , Florida
Here's the only one I have right now, I'm actually picking up my truck from getting the air conditioning fixed and will take another pic this afternoon.
Old 05-26-2011, 10:16 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Direct Read Oil Temp or Direct read Oil Pressure.
Michelle TAC MT-0
Sarah, Snowball
Old 05-26-2011, 01:15 PM   #7
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Excellent gauges! We have all the AS originals replaced with them.
www.isspro.com
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-26-2011, 02:08 PM   #8
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
You may want to check out Edge Insight. They have a single digital gauge that does much more monitoring.
Autometer makes some gauges that match the factory Dodge gauges.
I would be mostly concerned with Exhaust Temp, Trans temp and boost.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 05-26-2011, 02:30 PM   #9
x
XXXX , XXXX
Secguru my old TV a 1995 Ford f-350 crew cab dually diesel had the a pillar triple guage setup. I never found that it was a problem seeing around them. The three guages were:
1) Trans Oil Temp
2) Exhaust Temp
3) Turbo Boost Pressure
Here is a picture of them.
wasagachris is offline   Reply With Quote
Old 05-26-2011, 03:05 PM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I don't like the pillar gauge mounts on a Dodge. They interfere -- widening an already wide A-pillar.
The first two gauges I would have would be:
Pyrometer
Manifold Pressure
The combination is best for determining overall economy of operation (fuel burn), and the info needed to stay out of bad situations.
After that:
Transmission (auto)
Fuel Pressure
to also stay out of trouble.
FYI, best fuel economy can be read by the 600-60-6 rule:
600F (or lower)
60-mph (or lower)
6-psi (or lower)
when you want to run the farthest.
Pulling your trailer will generate somewhat different numbers, so make some records, IMO, and do comparisons.
I had quite a time recently making it from Laredo to Corpus Christi in a 30-mph headwind (gusts past 40) in a 1T and 40' gooseneck, and was speed varying the truck depending on the angle to the wind (road curves) to help offset "driving 85-90 mph". Just made it to a station that accepted a big truck fuel card. The gauges were a help in seeing how the truck was maintaining speed.
Old 05-26-2011, 03:17 PM   #11
FLMarine's Avatar
_ , Florida
More pictures. The gauge mount is an autometer, I forget what model but it's unpainted and looks stock.
Old 05-26-2011, 03:52 PM   #12
Mike Leary's Avatar
Images: 11
How about some links when you guys suggest stuff?
Old 05-26-2011, 05:13 PM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
EDGE Insight
These things only appear expensive compared to standard gauges until one totes up the final cost. Not to mention mounting space.
Old 05-26-2011, 06:11 PM   #14
Mike Leary's Avatar
Images: 11
NO gauge is too expensive if it tells you what's happening before the fun begins. Thanks for the link.
Diesel Engine Programmers moosetags Tow Vehicles 34 05-23-2011 09:49 AM
Advice on a 95 360 diesel pusher Rosie39j Classic Motorhomes 4 05-16-2011 03:45 PM
Gas, Diesel, 6-speeds r carl Tow Vehicles 51 04-01-2011 10:03 AM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 03-15-2011 01:50 PM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 01-24-2011 07:40 PM
