Looking for some input from those who use a Ford Excursion diesel as a tow vehicle.
My current TV is fine for my needs (Nissan Aramda), but I stumbled across a 2004 Ford Excursion Ltd with the 6.0 TD at a very reasonable cost.
My concerns are on the 6.0 TD, and some of the "new motor" issues and recall Ford has had, as well as the suppoed horrable OEM shocks on the Excursion itself. I have no idea how well it will handle my 28' Safari (7300#).
My reasons for looking at this beast are as follows:
Diesel - 6.0 is quiter and better milage than the older 7.3
Better milelage both with or without the A/S.
More Margin of weight on the TV than I have on the Nissan Armada.
Diesel - Keep the engine idling to keep the 2 dogs in back cool in the texas heat and warm in the texas winter.
Flexability to get a bigger A/S later???
Can anyone with Diesel Excursions chime in on their thoughts? or Mods they felt they needed? Happy with it as a TV or should I wait until GM ever gets a diesel back into their suburbans?
Wow, that's some hefty TV for a Bambi. Sounds good for a 25' and above, but I think you're going with too big iron for that Bambi. This may be your last chance to get an X, but gee, you could just hoist the Bambi on the roof and give it a softer ride.
AYRSTRM2Wow, that's some hefty TV for a Bambi. Sounds good for a 25' and above, but I think you're going with too big iron for that Bambi. This may be your last chance to get an X, but gee, you could just hoist the Bambi on the roof and give it a softer ride.
You DO tow a Bambi, right?
John
John,
No, I had a 2005 Bambi CCD for 10 months until aluminumitis struck again, and I got a 2006 28' Safari....
I can't find the option for a 2006 28' in the model listings for my avatar, and I've just kept my screen name...
My 2003 has been terrific and as you know, this was the first year for the 6.0L. At 65MPH without the Airstream and without the AC running, I get 21 MPG!!! Towing I get about 16-17MPGs. I've had no problems with the engine and the torqshift tranny is fantasic on the 6% grades. Tap the brake as you're going downhill and the tranny maintains your present speed. No need to brake anymore!!!
The shocks are OK, but I put Bilsteins on mine and will soon go with the Rancho 9000s. The only problem I've had is with the A/C. It crapped out after the warranty.
I can honestly say this is the best truck/vehicle I've ever owned. A pleasure to drive and tow with.
__________________ 2003 Ford Excursion (6.0L PSD) Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10 U.S. Navy (Retired) Airstream Life Contributor Air#5661 / WBCCI#--
Thanks for your comment. was the MPG calculation based on the on board trip computer, or your calculation based on miles / gallons at the filling station?
Did you have any other mods than the shocks? I hear many people with the 2003 did not have rear sway bars, and had to add those, or the ones that came OEM on the later models were undersized, and so people were using aftermarket or a rear swaybar from a F350.
The only issue I has was "porpoising" on a very rough road in Memphis TN. Other than that, I've had no issue with the current TV.
This could be your last opportunity to get a good Excursion. The one your looking at will tow anything. I have bought 5 Excursions since they came out and wouldn't have anything else (if I have the choice).
I prefer the gas engine but also have had the diesel units (7.3). 'sarmimi' on the Forum is towing a similar rig around the country with that vehicle and apparently he is quite pleased.
By-the-way, I lock & idle my V-10's to keep the dog cool and haven't ever had any problems doing it. I have never had overheating problems, idling or towing, even when the outside temp displays at 114 F (towing through Las Vegas & the desert in July).
If you want to research a Forum about the Diesel & Excursions you can go here:
There are other diesel threads that are referred to within this Forum. Further, you could go the extra upgrading with sway bars, traction controls, upgrade brakes, etc., although in my opinion the Excursion does just fine stock. Maybe after 100K and the warranty is expired or maintenance requires replacement, upgrades could be considered.
BUY AMERICAN !
__________________ NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
Kevin
The MPGs were hand-calculated and verified by the computer. Yes, I got rid of the OEM rear sway bar and upgraded to one which made a significant improvement on turns.
certainly when there is a good price on a near new tow rig.....well it becomes hard to cross shop. so many variables to consider........but
have you considered the f-250 super crew with the psd?
some of the reasons i like it over the excursion.....
-it hasn't been discontinued
-the truck version has a higher tow rating/ncc. either would be fine for the safari but you did mention potential trailer upgrades.....
-new ones have coil instead of leaf springs up front for a tighter turning radius...excursion uses the older version of the front end.
-with the s crew cab there plenty of room for dogs but lots less space to cool
-camping supplies stored in the back......stay in the back during sudden stopping.
-if you carry dirty or smelly (gas can) stuff....putting items in the truck bed is more isolating
-the truck bed has more space than the excursion
-turns out there is more space in the engine compartment too so mods are easier (like turbos or banks power pack)...i think the truck may have higher performance figures because some larger exhaust bits are used on the trucks
-with the truck in long wheel base version you get a bigger fuel tank and even better towing characteristics because of the long wheel base
while i went with a 4x4, given you live in texas the 2wd has an independent front suspension and weighs less so it has greater towing capacity, better mileage, better handling and looks cooler...
i haven't posted pics of the 250 but with the bed shell it looks like a reallllllly long excursion......cool.
lastly if you are thinking about any ford with the psd, join the yahoo group for powerstrokediesels. it is an amazing forum with a true mastermechanic that answers questions better than any mechanic i've ever met!
Good points on the F250. I looked at them for those exact reasons, and I know they redsigend the front end of them this year. I would get one in a heartbeat if I knew of a way to cap the bed and heat / cool it.
I thought about putting my 2 dogs in the back seat of the crew cab, but experience tells me from a 3/4 ext cab GMC I had before, it doesn't take a long trip for the siberian husky hair to float on forward on any breeze or movement!
I'd love to get the p/u, but with the dogs, - oh yeah, can't forget about the wife, and the remote possiblity of future kids, I just think the Excursion is the only choice I have in a newer diesel SUV (not counting the Hummer H1 wagon).
Part of me is kicking myself for getting my Nissan armada in the first place. Got that new last year, all before the airstream bug bit my wife and I. It was more of a toy, so I didn't really need it. But in retrospect, if I still would of had my 2001 Tahoe, it would have been a very borderline situation in towing the 28' Safari, so at least I can do that with more margin on the Armada than the Tahoe. It has plenty of power, but now I "want" more margin and "dog space".
With all the road trips/trailer travels now, keeping the dogs cool or warm is a new issue for us. That diesel excursion is the only thing I know that I can feel comfortable in both towing and idiling.
well don't kick yourself too hard.....the nissan is a fine rig; well made and stylish with a touch of brute.....it's just that once the airstream bug bites our rating system for cars and trucks changes.
figured you had debated the truck/suv issue with the dogs, wifey, future bandits and trailer in mind, but it always helps to bounce it around before spending the cash.
good luck with the challenge of buying an american built vehicle. this truck is my first us auto in 30+ years and on balance it's just right for the task....but i kept my euro wagon and asian roadster too! driving a truck/big suv everyday in a metro area is a lot of work.
there still isn't really an asian/euro competor for the big 3 when it comes to towing or building condo sized suvs.
as for the hummer, i drive a real h-1 several times a month out on the prairie ranch and they are perfect for herding cattle, crossing creeks, ravines and so on.......and amazingly agile. BUT they are slow and have too short of wheel base for towing a big trailer like yours or mine.
I know that the Diesel Place Forums will do a free VIN check on DuraMax diesels to see if there have been any service issues... Is there one for Fords? Am I limited to only a CarFax history?
Take the VIN to a cooperative Ford dealer service department. Get one of the service attendants to plug the VIN into the computer and run an OASIS RESULT. Print it - take it home and study.
The OASIS will provide you with the basic build spec's of that vehicle and it's warranty repair history; which dealer did the repairs and what they were. It will tell you if any outstanding field service actions (recalls) exsist and what, if any, extended warranty is placed on that vehicle.
For more basic TSB (Technical Service Bulletins) info on that VIN go to: http://www.alldata.com/recalls/index.html. Here you can get a hint of what issues that year vehicle has had & pay for the detailed information.
The Diesel Stop DS is a good place to see other peoples issues.
For special upgrades to suspension, etc. try this: SM Find 'LANDYOT' submissions to their Forum ... A little over the top, but that what some people do.
For a simple install and adequate sway bar go to: Helw
