Old 03-15-2011, 11:13 AM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Diesel Engine Programmers
As I have been shopping a new tow vehicle for Lucy, and have decided on a Diesel, I have also been researching Diesel engine programmers. My research has disclosed that these devices are also called performance management tools.
I have determined that these devices range in price from $300 to $1,000+. In reading numerous reviews of these devices, most people claim to significantly enhance power and improve fuel mileage. The fuel mileage improvement claim is most often in the 2 to 3 mpg range.
Accordingly, I have crunched some numbers and have come up with the following:
100,000 miles at 15 mpg at $4.00/gal= $26,666 fuel cost
100,000 miles at 17 mpg at $4.00/gal= $23,529 fuel cost
If these figures are realistic, I would realize a $3,000 fuel savings over 100,000 miles. This would more than justify a $1,000 investment in one of these units. Any improvement in power would further sweeten the pot.
That brings me to the big question. Are any of our members using these devices?
If so, which ones, and what are the results?
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 03-15-2011, 11:16 AM   #2
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
I don't but would be interested to know what type of results people are getting.
Before installing one of these you should check to see if your factory warranty will be invalidated.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-15-2011, 11:38 AM   #3
Naper's Avatar
Loretto , Ontario
2 to 3 MPG improvment is 15 to 20%. Sounds too good to be true. If a simple program change makes that much difference why dont the truck manufactures do it?
Naper is offline   Reply With Quote
Old 03-15-2011, 12:00 PM   #4
Freeheel's Avatar
2009 19' International
Calgary , Alberta
Images: 13
Hi - I'm new to diesel ownership, and no expert by any means, but one thing I quickly discovered in my own research regarding reprogrammers and other such devices, is that there is a good possibility the use of them could void your engine warranty. Obviously this would be true only for newer diesels where the warranty hadn't already expired from age, mileage, etc. Also, I believe it's up to the dealership to prove that the engine mods lead to a failure, but it's definitely worth further consideration depending on the unit and vehicle you're thinking about.
Freeheel is offline   Reply With Quote
Old 03-15-2011, 12:02 PM   #5
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
There are lots of companies that offer various types of devices 'chips' and 'tuners'.I am using the Quadzilla brand tuner on my current and previous truck, there are multiple 'tunes' available from 40 to 130 added hp on the device. Mostly I leave it on the 40 hp 'towing' tune. These work by temporarly modifying the ECM to change the fueling pulses and timing. No hardware on the engine and easily reversable. Some devices can read and clear codes and input larger non-stock tire sizes along with modifing other parameters as you like.
The companies usually reccomend a pyrometer be added to monitor exaust temps on those long climbs out west.
You will get the most benefit by upgrading the intake and exhaust systems to allow the engine to breathe better, but they work without also.
With a K&N filter and the 40 HP tune (not towing!) town mpg is around 16-17 and highway 22-23-24 in the flatlands. Towing the 10k triple axle is a avg 12.7 mpg at 65-70 mph. I've gotten better mileage and worse sometimes due to terrain and wind. The higher hp "tunes" can really put some life in a 8000 lb truck and you will never be stuck in the 'slower vehicles keep right lane' unless you want to be. It's nice to have the reserve torque and power for situations that need it. I'm a fan.
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 03-15-2011, 12:18 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I use the K&N filter and it seems to slightly increase gas mileage. It saves on replacement standard filters, so I figure you can't lose.
Would the tow/haul setting on automatic transmissions be a form of "programmer"? I've never compared mileage with and without.
Gene
Old 03-15-2011, 12:38 PM   #7
ebair's Avatar
2000 34' Limited
Miamisburg , Ohio
In a strict sense the tow haul setting on my Allison changes (lowers) the shift points in the trans and restricts the top gear when it is engaged. It also allows the downshift (trans brake) to function on the downhills (great feature). I havent compared mileage either, but I would bet on flat ground, 6th gear would give a slight increase in fuel mileage along with a reduction in available torque.
AIR #12881
TAC OH-10
Old 03-15-2011, 02:54 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I run a Dodge diesel and I do not run a programmer. I spend a lot of time on the Dodge diesel website and read many posts about the programmers.
There can be some downsides to using them. One is that the automatic transmission in the Doge does not seem to handle the extra power towing (most of the programmers provide about a 50 hp boost at the minimum and can go up from there. another downside is that it seems like the programmer might adversly affect the fuel injector life span. The extra power is achieved by chaging the injection interval. I have the 2007 5.9. The new dodge has a purge cycle in place of the urea injection that ford uses. People get increased milage on the newer (6.7) engines by doing a "emission delete". not something I would want to do.
I get pretty good milage on my rig now (14-17) towing. I doubt if it would improve much with the programmer. I also run in tow haul, but could get a little milage improvement by running in standard, but I hate to load the transmission the extra. what affects my milage is wind direction and how fast I run. I can save 2 mpg my slowing down if I need to. (Maybe will on the caravan next month).
The new ford with the urea injection gets pretty good milage stock.
I do not see many people claiming large fuel savings for the programmers on the Dodge. They all buy them for the power.
Old 03-15-2011, 03:06 PM   #9
let's play's Avatar
1970 31' Sovereign
round lake , Illinois
if you are looking at ford, DP Tunner is the way to go, check out the ford diesel forums and google this tuner. i have a 2000 excursion and tow 31 ft airstream and a 12,500lb boat. Average 14 miles per gallon towing. can easily see 22-25 mpg on the highway when not towing. this is not a chip, it is a tuner, you specify what your towing weight wise and the vehicle, they "tune" to your parameters. the "tune" takes into consideration the wieght of the truck, axle ratio, transmission and your expectations, you get a custom tune. A 4 inch exhaust upgrade to get rid of the heat, a pyrometer to measure exhaust gas temp (important) and tranny temp. my set up was about $1200 i think. money well spent. the ex flies!
let's play is offline   Reply With Quote
Old 03-15-2011, 03:12 PM   #10
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Mooses - I use the BullyDog
When I was on my way home from Albuquerque with my "new" rig in 2007 I had to stop in AR for a umbilical repair. So I had about 800 miles with the new rig, pulled by my 2004 Duramax. The shop owner asked if I was interested in a free trial; after doing a little research, I agreed. He installed the BullyDog; it has 4 settings: Stock, Tow/Haul, Performance and Crazy Larry. I set it to Tow/Haul and felt the difference as soon as I pulled out of the lot. The Duramax was already plenty powerful but the difference was felt in the pedal and in the seat of my pants.
As I still had another 1000 miles to go, I had plenty of time to note the difference in fuel mileage as well. I was so satisfied I purchased the BullyDog TripleDog for $300 and change. I remain very satisfied. (The TripleDog can be set to Chev,Dodge or Ford, so if you decide to trade to another brand, you can uninstall your old truck and get it reset to your new, different brand if you want to.)
One thing you must do is set the tuner to Stock before you take it to the dealer; if you do not, and they reset your computer for any reason, the BullyDog will be out of synch and you will have to send it back to the factory to be reset. It will cost $100.
I was getting about 10-11 with the new trailer until I installed the BD. Now I get 13 reliably when I am pulling. I get close to 19 when not. I just keep it at Tow/Haul all the time.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 03-15-2011, 03:24 PM   #11
Master of Universe
Gene's Avatar
Pat, could have mileage increased after the first 800 miles of "break in" and not because of the 'Dog?
The OEM tow/haul setting simply changes (lowers) the shifting points on the auto transmission as I understand it. One of these programmers wouldn't be needed if you have a tow/haul setting in your truck I presume.
I am skeptical about these things. It would cost a manufacturer next to nothing to modify their software to accomplish the same things. Then they would have a big advantage over competitors.
So what is the cost of changing what the OEM computer does? More wear on the engine? Something happens to some other parts? Just what do these things actually do? If they reduce the effect of anti-pollution parts and software, that breaks a lot of laws. Some places (Denver was first I think) have equipment that can measure tailpipe emissions as you drive by and if the programmer has changed it, there will be a ticket in the mail.
There was another thread about these issues several months back where the same questions were raised. It appeared there was no free lunch (beyond the cost of item itself) from what I read.
Gene
Old 03-15-2011, 03:32 PM   #12
Ready-to-Travel
pmclemore's Avatar
The trailer was new, not the truck...the trailer was my "new" 98 31' Limited. My previous trailer was a 25-footer, and I was already sad about the lower mileage when pulling the heavier 31 footer. When I installed the test unit, the power and mileage both increased markedly.
I also use the tow/haul setting on the Allison; the bullydog setting is different...
I hope we can camp together sometime; the difference is remarkable.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 03-15-2011, 06:08 PM   #13
2008 27' Safari FB SE
Mesquite , Texas
Brian -
Call me a "Nervous Nellie" but I would be very reluctant to put a tuner of any kind on a late model GM product while it is still in warranty. My understanding is that GM has become pretty aggressive about denying warranty claims where a tuner could have possibly caused the issue. That would affect nearly everything in the power-train. Duramax diesels and Allison transmissions are great products. They can also be very expensive to repair and/or replace if something goes wrong.
I would check some of the GM diesel forums and see what others have gone through. I have been told that the LMM's and up will store a significant history of changes that were flashed to the different systems. Simply setting the thing back to stock and taking the tuner out before a dealer visit doesn't work anymore like it did in the old days...
Of course this, like anything else is somewhat dependent on your dealer and their willingness to argue in your favor. You also have to consider the benefit side of the risk equation. Money saved on fuel can be significant over a 100,000 mile run. I just have never seen anything that I felt was sufficient proof that the mileage claims are truly valid and repeatable. The added driver satisfaction due to higher performance is probably worth something as well.
I am really interested in what you decide and what other's on this board have experienced. I only have another 60K or so on my warranty. Maybe then I won't be so "Nervous" once that's done.
Wayne
wayner61 is offline   Reply With Quote
Old 03-15-2011, 06:12 PM   #14
Where is the answer...
I agree with Gene. If it were a no brainer, Detroit would do it (cost being always an object - sales with better claims may vastly overshadow minor costs).
That said, I hear some say the older diesels may get the best results. What say you. I have the reliable (but somewhat slow and heavy 7.3 L.)
I don't have the chip - it was removed for whatever reason when the owner traded it in after selling his unit. Maybe I should get one. Would go for the $300 unit if I did get one. My '03 F250 pulls fine w/o it but doesn't have the get up and go unless I pour in the fuel, and then not like the gas engine response would be.
I'm still interested though. Thoughts??
Sav'h Steve is offline   Reply With Quote
1998 airstream cutter 35' diesel pusher slide out eBay Watch Airstreams on eBay 0 03-06-2011 08:00 PM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 02-20-2011 07:30 PM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 01-24-2011 07:40 PM
2010 Ram 3500 MegaCab - Took the Diesel Plunge! Freeheel Tow Vehicles 9 01-18-2011 07:19 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
