Old 10-18-2013, 09:17 PM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Diesel/DEF mileage.
Hi, in all fairness in comparing fuel mileage, DEF should be included in fuel mileage calculations; Therefore reducing the actual fuel mileage of these newer trucks. Has anyone included the cost per mile, or miles per gallon of DEF with their mileage of Diesel fuel?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-18-2013, 09:27 PM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Def
We just spent $7.99/2.5gal. and the truck goes 3500 mi. before it tells us to add more. $.0023/mile. Not much to worry about.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 10-18-2013, 09:53 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I find the Regens use a lot more fuel. When in Regen I get a 3-5mpg hit according to the dash gauges. These cycles run for 15-30 minutes at least. So yeah, not 'efficient ' as expected.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-19-2013, 12:04 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
My new Duramax only regens about half as many times as my old Duramax and for about the same duration, thus the regen fuel hit is about half as much as the old truck. I haven't needed to add DEF yet, but the 3.5 gallon tank is supposed to last about 5,000 miles. I have about 2,500 miles on the truck so far.
John W. Irwin
WBCCI #9632
Old 10-19-2013, 12:08 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I think that's about right - maybe a little more than 5000 miles in our experience.
I'm cynical though. Isn't it just distilled cow pee? I'm sure that's not 100% accurate but I may not be far off. Seems like a bit of a racket to me.
More first world problems :-)
Old 10-19-2013, 02:14 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have only added DEF to my 2013 Dodge once. Assuming it was delivered with a full tank I used 3.44 gallons in 2100 miles at a cost $9.44 at the pilot pump ($2.79 gal)
That works out to about half a cent a mile. Less if I didn't start with a full tank.
Fairly insignificant in the scheme of things
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-19-2013, 02:41 PM   #7
Pahaska's Avatar
Hays County , Texas
I must be using a lot less than that. I'm supposed to get a warning with about 1000 miles of DEF remaining. At about 2500 miles on the truck, I haven't received the warning yet. I wonder whether your tank was initially totally full.
John W. Irwin
WBCCI #9632
Old 10-19-2013, 02:50 PM   #8
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I still had 1/2 a tank when I filled it. Had not got to the point of any warnings the tank is over 7 gallons. I have heard higher mileage numbers and of course I may not have started at full
I worked to out to about 600 miles per gallon assuming I started full. It very well may not have been
13 Ram 2500 TD
Old 10-19-2013, 08:40 PM   #9
dznf0g's Avatar
Oswego , Illinois
DEF usage is a direct function, or correlation to, fuel consumption. For example, while towing at 11 MPG you may get 5000 miles before refilling. If you drove completely without towing at 18 MPG, you may get 7500 between refills. The system looks at the amount of NOx in the exhaust stream through an algorithm, and injects enough DEF to neutralize the NOx to the inert gasses (nitrogen and oxygen). The more exhaust (more fuel burned at a given moment), the more DEF injected.
Bottom line, you will use more while loaded than empty.
-Rich-
Old 10-19-2013, 08:57 PM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have a bit of a DEF consumption track record to share. I have a 2011 Chevrolet 3500 Dmax that now has 60,000 miles on it. I am carrying a 3,000# truck camper in the bed almost all of the time. I am also towing a 7,400# Airstream about 50% of the time.
I have been consistently using about a gallon of DEF every 1,000 miles. The cost per mile factor is negligible, but the pain in the butt factor is an issue.
Brian
SuEllyn & Brian McCabe
Old 10-19-2013, 09:12 PM   #11
dznf0g's Avatar
Oswego , Illinois
Brian, I would expect that, given your duty cycle. That's about the norm over the long haul, while loaded. On my company trucks (2500 duramax), I get more than that unloaded....of course. At oil change time, by the oil life monitor, at about 7500 t0 8000 miles, I need about 4.5 gallons of DEF.....but that's empty. Loaded at your level, I'd expect the "change oil soon light at 4500 - 5000 miles, and a near empty DEF tank.
-Rich-
Old 10-19-2013, 09:39 PM   #12
moosetags's Avatar
Hi Rich. I have been getting oil life monitor change signal at about the same intervals, between 7 and 8 thousand miles. The DEF tank in the 2011's holds 5.5 gallons according to the spec sheet. I have been doing my own DEF monitoring with a log book as the DEF range warning system on the 2011's is notoriously squirrelly.
Brian
Old 10-20-2013, 02:48 AM   #13
2008 31' Classic
Lake Charles , Louisiana
I just drive my 2012 F-250 Power Stroke and love every minute of it :-) I agree with Rich. We purchased the truck and did a lot of heavy towing and DEF had to be topped once. Since then it has been light loads and a year later I just now got the 500 mile warning to add. I don't see the DEF as being a big issue. But we are still a year away from retirement and I'm sure once we retire and start doing a lot more travel, I'll be much more concerned over the expenses :-) ........ steve
Steve & Mary is offline   Reply With Quote
Old 02-27-2014, 06:36 PM   #14
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
From what I have read the DEF consumption is about 1% to 2% of fuel consumption. Put in another way, for every 100 gallons of fuel you will use about 1 to 2 gallons of DEF. GM claims that the 5.3 gallon DEF tank should last between oil changes, therefore that is why they didn't put a DEF gauge on the instrument cluster.
DEF is 33% urea and 67% deionized water. When a fine mist of DEF is sprayed in the SCR it converts to ammonia and this breaks down the exhaust to water vapor and nitrogen.
Did you know that the Chevy 2500 qualifies as a ULEV (Ultra Low Emission Vehicle)?
TSchleff is offline   Reply With Quote
