Old 02-26-2008, 08:16 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Diesel cool weather starting
I wonder if someone can explain this one for me. I have a 97 F250 PSD with the 7.3. It starts fine in COLD weather (20's and lower), but in the 30-40 degree range it can be a bear to get started. Below 30 the glow plugs seem to do the trick with no problems. I would have thought that it should start easier in the cool weather range than in the colder temps. Any ideas?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-26-2008, 08:22 AM   #2
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Hey GD, i have not had any issues with cold weather (down to -25F). I did a post a while ago about what I learned about cold weather and diesel. In short; should be a non-issue with todays glo plugs and formulated fuels.
I am thinking you might have a problem with moisture (humidity)?
Any trouble codes?
Wish I could offer more....
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 02-26-2008, 08:42 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Your thermotimer switch (glow plug controller) may have a problem. Try cycling the ignition key twice before trying to start the engine.
Old 02-26-2008, 09:42 AM   #4
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I just spoke with a friend at work who has a 95 PSD and he thinks it may be a moisture issue getting into the solenoid.
He states that the thermotimer is controlled by the computer.
He replaced the solenoid on his truck for $53 and has no starting issues.
crispyboy is offline   Reply With Quote
Old 02-26-2008, 10:07 AM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
So between relacing the glow plug controller and the solenoid which is the place to start? It just really boggles me that it starts fine when its cold out but not when its in the 30s
Rodney
and the
My Blog
Old 02-26-2008, 10:52 AM   #6
crispyboy's Avatar
1994 30' Excella
My friends truck did not have a relay but only a solenoid. He said that some trucks had a relay and some did not.
I would take all the connections apart and clean them and put some dielectric grease on the terminals. (could be lots of dirt or corrosion which hold moisture).
If that doesn't work you may want to find a Ford Truck forum to find out how to test the components or you could just throw some new parts at the problem and hope you hit the target.
Sorry I can't be of more help.
Old 02-26-2008, 10:55 AM   #7
Trailerite
TwinkytheKid's Avatar
1971 23' Safari
Riverton , Missouri
Could be the coolant temp sensor is bad. When open, it reads -32, and when shorted it reads 250+.
Michael.
TwinkytheKid is offline   Reply With Quote
Just Starting To Look SnowGypsy Full-Timing 4 02-12-2008 12:42 PM
Just Starting rick zigler Member Introductions 12 12-29-2006 06:08 AM
Starting over? propstrike Airstream Motorhome Forums 29 08-06-2006 06:14 PM
Just starting to look! Fogducker Our Community 4 01-25-2004 11:52 AM
