Old 07-26-2005, 07:57 PM   #43
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I think pwrstrk had the same problem on their past trip.
Old 07-26-2005, 08:54 PM   #44
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
Our just completed a 2500 mile trip with our Ford E-350 Power Stroke got 11.77 MPG using the ac half of the time. We were at the max combined vehicle towing weight. There was not a hiccup or glitch during the entire trip with the Ford. With 40,000 miles on it the diesel mileage has improved somewhat. I use Amsoil heavy duty diesel marine 15-40 oil in the engine with the Amsoil bypass filter. Tranny has Mobile 1 ATF and the differential has Amsoil synthetic gear lube. I replaced the OEM air filters with the foam oiled type. I thought I needed a 4.10 differential but the 3.55 appears to work fine. Towing the steepest grades it slows to about 37 MPH and the cooling fan kicked in only twice just before the top of the grades. When that fan kicks in you know it because it sounds like there is a jet flying right above you. It must take a lot of horse power to turn that fan, but then it pulls a tremendous amount of air through those three radiators.
Tinsel Loaf is offline   Reply With Quote
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 11:28 PM
1981 Airstream Excella Diesel dienst1 Airstream Motorhome Forums 6 10-02-2003 05:45 PM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 02:23 PM
Isuzu Diesel islandvu3@cox.net Mechanics Corner - Engines, Transmission & More... 7 10-28-2002 12:53 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 07:47 PM
