Old 07-28-2016, 08:56 PM   #29
2014 16' Sport
Walnut Creek , California
From my 35 years working on trucks with Cummins motors I have found out that if you have a problem with the engine and you have not used what Cummins recommends then you are out of luck on the warranty. Whether its a Peterbuilt, Kenworth, Mac or a Dodge Ram. So good luck if it is Def is Def is Def. Try and sell Cummins on that.
Elbo is offline   Reply With Quote
Old 07-28-2016, 09:34 PM   #30
Llando88's Avatar
2016 30' Flying Cloud
Right.
So here is what is in my owner's manual. Basically, FCA specifies MOPAR DEF, or anything API certified to ISO 22241.
As I said. DEF is DEF is DEF. As long as it is 22241, you are good to go.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is online now   Reply With Quote
Old 07-28-2016, 10:27 PM   #31
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
I've had good luck with Loves and Pilot DEF in my '15 Ram 3500. I also bought a 2.5 gallon container from NAPA which I keep in the tool box for those trips away from the interstates. I may have to toss the remainder of that jug after reading this, inasmuch as I bought it last year and it has been simmering in the heat of our Mississippi summer...
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 07-31-2016, 07:22 PM   #32
Shreveport , Louisiana
2.5 gal Blue DEF 10.95 at SAM's today
Endodoc is offline   Reply With Quote
Old 08-01-2016, 10:09 AM   #33
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
We just got back from the Lewisburg, WV rally with a day thereafter in Glacier Park as part of the Kalispell, MT rally.
My experience with DEF. First of all, DEF is DEF --- it's a water solution of urea: CO(NH2)2. Nothing fancy at all.
In cartons, such as with Blue DEF, 2.5 gallons typically costs around $12.50 --- around $5/gallon, and you've got to mess with opening the carton, attaching the nozzle, & filling.
At a truck stop, DEF at the pump typically cost around $2.75/gallon, and all it takes is putting the nozzle in & filling however much you need. You're right, the DEF nozzles have high flow rates. So the answer is to squeeze the nozzle handle ever so slightly so the DEF just starts flowing. Yes, the first time I did it, I put DEF all over the side of my truck. Lesson learned. Don't crank the handle down all the way, pull it lightly, fill as much as you need, & save approx 50% of the price. The only problem I've had is finding truck stops with DEF at the pump --- not all truck stops have it. And some truck stops that have DEF at the pump don't have them at all of their pumps.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 08-01-2016, 10:45 AM   #34
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I looked at a 2 1/2 gallon carton at my local O'Reilly's auto parts store. They had the Peak and the O'Reilly's brand. They both had the goofy date stamp code.
The one I kinda remember had two alpha characters then 17 then 237.
My understanding is you subtract 1 from the first so the year produced is 2016 and the next set of digits you subtract from 365. So the code means it was produced about a month ago?
So if DEF shelf life is reduced by high temperatures can retail DEF shelf life be reduced if it was shipped by truck in hot weather. The truck could sit travel in 100F heat while in transport.
How is bulk DEF transported to a truck stop?
Kelvin
Old 08-01-2016, 06:35 PM   #35
Tincampers's Avatar
Sneedville , Tennessee
I buy the cheapest stuff I can in the 2.5 gallon jugs. I carry one with me. The warning has come on anywhere from 200 miles to 950 miles remaining. When using these jugs pay very close attention to the filler spout. That sucker will pop off at the most inconvenient time...like right when you tip the jug over to start pouring. In the Chevy/GM the fill port is located very conveniently under the hood by the firewall. Good thing I am 6'1" tall.
Tincampers is offline   Reply With Quote
Old 08-01-2016, 08:22 PM   #36
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Blue DEF
For five years I have been buying Blue DEF at WalMart. Usually about $11.99 for the 2 1/2 gallon container. There is a manufacture date on the carton. I rarely find containers more than 2 months old.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 08-04-2016, 10:49 PM   #37
2014 16' Sport
Def is def
Oil is oil also. It comes out of the ground and it basically refined the same at the big refineries, but still some charge more then others. Why?? Because of different additives. So if the Chrysler dealer selling the Ram Dodge with a Cummins and they recommend a certain brand that Cummins says you should be using then there is some reason Cummins is doing that. So good luck if you have to deal with Cummins on an injector or motor problem.
Newbie looking for airstream to convert to retail store Cowdeevas Dollars & Cents 1 03-25-2011 08:57 AM
Airstream converted to Studio guesthouse retail store eBay Watch Airstreams on eBay 0 07-24-2009 06:20 PM
Airstream converted to Studio guesthouse retail store eBay Watch Airstreams on eBay 0 07-23-2009 09:10 PM
1989 Excella 29' rear twin Retail? Hhthorny Trailer Values 1 04-13-2008 09:02 PM
Reasonable Retail Price Range for 25-28' Excellas Streamer1 Trailer Values 2 08-30-2006 04:53 PM
