09-23-2016, 02:30 AM
#61
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Originally Posted by dasams
Newbie here with a question about engine braking. Since the trailer brakes aren't activated, isn't the hitch in compression instead of tension? How might this affect handling?
On dry roads you should be fine. Just watch curves and especially wet or slick roads. You'll want to use your brakes for those so the tires don't lose traction. Even if the road is straight.
@living.somewhere.yonder | Instagram
09-23-2016, 03:15 AM
#62
2018 27' International
Southeastern MI
, Michigan
Originally Posted by avionstream
As far as big trucks being hard to park, I also had a Mitsubishi Eclypse for years. Couldn't get that thing in a parking space straight any better than the one ton. Sold the mits, kept the truck. If you can't park, you can't park. I need lots of space.
My 3/4 ton and half ton had the same body style. Neither was any more or less difficult to park than the other. Trick I learned was to always back in. I got real good at backing up; wouldn't let my kids drive until they could demonstrate backing up with mirrors only. (Also required them to demonstrate that they could merge at freeway speed without making anyone move over).
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
09-23-2016, 08:27 AM
#63
1994 30' Excella
alexandria
, Kentucky
Originally Posted by ejritz
My 2500 5.9 Cummins is five speed manual. I heard various recommendations regarding the use of an exhaust brake for travel in the mountains. What has been the experience of people on this forum? Is it worth retrofitting an exhaust brake onto an older vehicle with a manual, or is this only a benefit when using automatics?
Yes it is absolutely worth the effort and expense to have an older diesel pickup retrofitted with an exhaust brake. The exhaust brake helps you to control the load behind the truck on while descending steep grades. The drive is much safer when the vehicle can control the load. I have the integrated exhaust brake on my truck and it works fabulously!
To answer the OP question:
I would have no trouble driving my truck daily but I would rather sacrifice my econobox car (hate it) to the winter salt when I drive to work. The truck gets used after work for hauling duties, recreation duties, traveling duties (it is comfortable) and driving to church on Sunday because I like it!
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
09-23-2016, 09:40 AM
#64
2016 28' Flying Cloud
Dover
, Pennsylvania
We are scheduled to pick up our Flying Cloud 28A next Friday. I currently have a 2011 GMC Sierra 1500 with the 6.2 motor. I think I will have plenty of motor, but the suspension will be within a couple hundred pounds of gvwr. I really enjoy driving the truck, but my daily driver is a Yamaha Tenere. I only use the truck in bad weather or towing. We are considering A GMC Savana 3/4 or 1 ton van as a new tow vehicle, but I doubt I would enjoy driving it as much as the Sierra pickup.
09-23-2016, 09:42 AM
#65
2013 30' Classic
Greenwood
, Mississippi
I would try towing with the truck before trading it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-25-2016, 07:06 PM
#66
Vintage Kin
Fort Worth
Daily Driver and / or Tow Vehicle options
That's the problem. The Dodge Upfitter Guide only recommends an EB when the trailer exceeds 10,000-lbs. I've driven these commercially and with a 20K trailer on the back it is well worth having. But that's in a gooseneck configuration. And loads that didn't catch much wind.
Being passed on the downslope by big trucks, or hitting a crosswind, is what screws things up for conventional hitched travel trailers. Vulnerability is at its highest. One NEEDS to be using the servic brake and have the controller adjusted to have the TT brakes at a higher total percentage of available pressure.
A 10 or 11k pound AS doesnt "justify" an EB. Speed on the descent and transmission gear choice are where it's at for making an easy descent.
If anything, disc brakes on the TT pay for themselves in this. Antilock only makes that better.
09-26-2016, 07:30 AM
#67
Palm Desert
Your comments make a lot sense.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
09-26-2016, 07:41 AM
#68
N/A
, N/A
GMC Canyon/Chevy Colorado diesels have exhaust brakes and are rated to tow around 7500#. Apparently, exhaust brake is not something meant only for super heavy loads, and moderate loads can benefit from it as well.
09-26-2016, 01:11 PM
#69
Vintage Kin
Fort Worth
You missed the part about the hitch being in compression?
Vehicle size, type or engine is irrelevant.
09-26-2016, 01:52 PM
#70
N/A
, N/A
I trust the GM engineers and am sure all your concerns are taken into account by them.
09-26-2016, 09:50 PM
#71
2006 31' Classic
DuBois
, Pennsylvania
The only thing I can add to the discussion is that I have pulled my Airstream with the Jacobs brake and the Hensley since 06 when I purchased the trailer. Interstate driving, winding two lane roads and the scenarios mentioned in these posts.
I've had the car trailer to Florida and back, even driving through the outer squall line of a hurricane as it was coming in...yeah, great timing. Trips into the midwest...etc without the sway bars hooked up.
Compression, tension, heavy loads, light loads all I can say is that I feel safe with my family in the vehicle with the set-up I have.
I would disagree that " vehicle type,size and engine are irrelevant". They have a huge impact on towing. I wouldn't want to hook a small SUV into my 31 footer just like it would be overkill to hook a Bambi to a 3/4 or 1 ton. But, if you had a F350 and wanted to pull a Bambi ,at least you would have the chassis, engine and brakes to handle the tow(and a factory EB and brake controller would be nice).
I bought my truck first, engine brake, then the hitch and then selected my trailer. Whatever direction you go, choose well, have fun and travel safe.
Peace.
09-26-2016, 11:43 PM
#72
Vintage Kin
Fort Worth
Quote them, then.
And, what's the procedure with brakes and throttle to correct a swaying trailer? To put the hitch into compression or tension?
09-27-2016, 06:49 AM
#73
K.C.
, Missouri
Quote them, then.
From the 2016 Chevy Canyon manual, page 46:
"Downshifts may be automatically selected to increase engine speed, which increases the effectiveness of the exhaust brake. The number of downshifts selected is determined by the length of time the brakes are applied and the rate the vehicle is slowing. The system delivers the correct amount of braking to assist in vehicle control. The heavier the vehicle load, the more active the engine exhaust brake will be. Use of the exhaust brake will help maintain vehicle speed when used with cruise control."
No place in the manual even mentions weight when talking about the exhaust brake. Sounds to me like they are in effect saying use of the exhaust brake is approved when towing any load the truck is rated for.
my badge of honor here:
"a genius nanny boy that drools in public"
....this according to a "slow-moving" poster here on the forum.... ( thanks )
09-27-2016, 07:30 AM
#74
St. Louis
, Missouri
Standard operation for steep/long descent is downshifting. How is an exhaust brake less safe than downshifting?
The Morgans
1989 Avion 34VB
09-28-2016, 07:07 PM
#75
Vintage Kin
Fort Worth
Use of the EB without corresponding TT brake activation means hitch is in compression the entire descent.
TT is pretty much ALWAYS traveling faster than TV in a descent.
Takes little wind or other problem to upset the apple cart
Descent without EB -- and using service brake intermittently -- keeps tension applied. Choose the right gear. Choose a lower speed.
Sure as hell won't change anyones day to travel at a more cautious speed.
Emergency procedure in event of sway (usually noticed TOO LATE and especially so with the lack of feedback in a solid axle 4WD with worm sector steering) is to slam throttle open and slam TT brakes on full.
There's no time for less. Hammer it.
EB use will LIKELY correspond with descent speed that is too fast to have adequate room to follow that procedure.
It's not at all a safety aid. An EB isn't even a convenience with one of these trailers.
A 16k fiver? Yeah, now one is into that territory. But it still isn't necessary. If it had disc brakes, even less so.
Even in a 79,000-lb Class 8 on the Interstate it's a convenience. As the hitch compression problem doesn't exist, on a dry day it's damned nice to have.
But one is still choosing gear and speed target to obtain a safe descent.
09-29-2016, 01:24 PM
#76
K.C.
, Missouri
At the risk of also being called a troll, I'd say they reading comprehension is fine around here. It's perhaps the engineering comprehension that may be lacking by some.
Example: it's very common strategy in trailering, and always has been to drive down hills in the mountains, using lower gears, and therefore using the engine as a "braking force" for the combined rig, without needing to use any brakes at all ( tow vehicle or trailer ).
Guess what: is the hitch connection in compression, or tension ? Hmmm....you got it...it's in compression.
I've towed bumper pull trailers countless miles down twisty mountain roads since the late 1960's, using this procedure. Not once, not one single time, have I had an issue with this.
I would suggest, the real key here is a properly engineered trailer, correctly loaded and hitched to an adequate tow vehicle piloted by a skilled driver.
Some may want to brush up on their engineering comprehension. Or failing that, I'm thinking the poster rostam has it right: just rely on what the the manufacturer says in their manual, such as the quote I posted earlier from the GM manual.
09-29-2016, 03:08 PM
#77
Palm Desert
Engineer here. PhD in fact, not that it matters.
The issue for me is that using an EB or downshifting on downhills means that all of the brake traction is down by the four tires of the TV. Meanwhile, the four tires of the TT are just going along for the ride.
EB and downshifting were important back in the day when brake failure was a real concern. But with modern equipment on a dry road in good condition, I have no doubt that a person could go a lifetime without incident.
But anytime I'm descending on the road under difficult conditions, i.e., rain, grease, sand, snow, etc, there's no way I'd rely on four tires for braking when I have brakes on eight. And I'll do everything I can to keep the hitch in tension which means have the TT brake controller should be set a bit more aggressive than the TV. YMMV, Dave
2018 FC 27 FB
2017 FC 25 RB Gone
#78
2012 25' Flying Cloud
Battle Lake
Depending on engine/exhaust braking of the truck's rear wheels to hold your Airstream while it is pushing you down the hill is terrific. Until you hit a patch of ice or loose gravel on a curve.
We'll stay with our method of reduced speed, engine compression braking through low axle gears and a downshifted transmission, combined with truck and trailer service brakes and the brake controller set to favor the trailer's brakes. If the road surface is unsure, I would reduce speed further and move my hand near the brake controller on the curve.
I believe the weak link in a heavy duty pickup/Airstream combo near truck GCWR is traction of the truck's rear tires on steep downhill grades using engine exhaust braking alone. A dually would help some, maybe we'll start seeing more of them as the next progression towards overkill.
Doug and Cheryl
09-29-2016, 04:00 PM
#79
K.C.
, Missouri
Dave, you said:
"And I'll do everything I can to keep the hitch in tension which means have the TT brake controller should be set a bit more aggressive than the TV. YMMV, Dave"
And the only problem I have with that theory is that in order to keep the hitch in tension, you would have to be on the brakes the entire descent.
All of it.
Because the instant you let off the brakes, the trailer is going to once again be "pushing" on the trailer. Gravity will ensure that.
EDIT: ps.... I reckon I will conclude that if a truck and trailer combo cannot safely descend a curvy mountain road without keeping the hitch in tension the entire way, then the owner needs to seriously re-think their whole combo of truck/trailer/hitch/driving skills.
EDIT 2: Doug, I would suggest if a person does not have enough sense and skills to get through a curve with ice/snow/gravel etc, then they probably should not be hitching a trailer to a truck to go traveling. I guess common sense is not so common anymore.
09-29-2016, 06:19 PM
#80
Palm Desert
The shape of a tire's contact patch greatly affects braking performance.
Back in the day of skinny tires, the contact patch was long and thin which didn't do much for braking. Reason is that the leading edge of the contact patch is the most effective.
The size of a contact patch is directly related to the vehicle weight. Ignoring the weight supported by the side walls, the size of the contact patch is simply the weight divided by the tire air pressure.
So a dually, with four tires in the back, will have four contact patches that are short and wide. Great for straight line braking and acceleration but not so good for cornering traction.
2018 FC 27 FB
2017 FC 25 RB Gone
