Old 07-03-2006, 12:24 PM   #15
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
The LB7 Duramax has a water cooled turbo, so the cool down period is not necessary. I am not sure if the LLY and LBZ are water cooled as they have the variable vane turbo.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-03-2006, 01:36 PM   #16
TIMEMACHINE's Avatar
Huntington Beach , California
Turbo cool down
Every manufacturer is a little different regarding turbo cool down periods, Ford recommends 7 to 10 minutes " after extended high speed or maximum GVW operation". Unless I am running real hard, I usually shut down in about 3 to 5 minutes. I know you are looking at buying a D/A, but who knows, maybe you will defect.
TIMEMACHINE is offline   Reply With Quote
Old 07-03-2006, 09:30 PM   #17
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
LB7 experience
I do a cooldown on my LB7 anyway after a major climb such as up Kimichi Mountain in eastern Oklahoma. We like to stop at the crest and enjoy the view for a while anyway.
Any other time, I figure that by the time I get the trailer parked, my LB7 turbo should be cooled enough.
I never do a cooldown when not towing or when towing on relatively flat terrrain.
I get 14-15 mpg towing my Classic 28 at 60-62 mph; even better when in a caravan rolling along at 55.
John W. Irwin
WBCCI #9632
How long is your Airstream Trailer? InsideOut Community Polls 106 07-31-2008 02:42 PM
Break Away Switch and Lanyard Question RBolton Brakes & Brake Controllers 6 01-10-2007 02:10 PM
period (70) fabrics NewStreamer Upholstery, Blinds, Walls & Interior Finishes 1 10-30-2002 10:00 AM
period (72) fabric NewStreamer Upholstery, Blinds, Walls & Interior Finishes 1 10-27-2002 10:27 AM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
