Originally Posted by pappy19
I had a 2002 Ford F-350 Crew Cab-long bed and I needed a Walmart parking lot to turn it around and backing up was a nightmare...
in 02 they still had leaf spring up front, greatly increasing the turning radius.
since 05 they've had coil fronts, which reduced the turning radius significantly.
the new 450s actually have a smaller turning radius than a 250.
Originally Posted by HiHoAgRV
...If the Mirrors clear...drive straight and the duallys will also...so will the 'stream!
just think of them as whiskers...
and that is actually with them IN and not extended.
fully extended and the mirrors might be a tiny bit wider than the buttisimo...
cheers
2air'
