Old 02-01-2011, 09:12 AM   #1
2007 25' Safari SS SE
St. Louis , Missouri
Correct Tire Pressure on Tow Vehicle
Greetings All,
I am looking for guidance on the proper tire pressure for our truck when pulling a 2007 Safari SS SE. (The trailer has a GWVR of 7,300 lbs and I inflate its tires to 65 lbs.)
The weight of the truck (an '07 F150 5.4 L) is about 6,700 lbs including truck, passengers, cargo, and weight on the hitch. The maximum allowable pressure shown on the walls of the truck's P235/70R17 BF Goodrich tires is 50 lbs. So the question is, what is the proper tire pressure to get the best safety, handling, and tire longevity. Appreciate any insight!
Hi Ho Silver
Jim Pona is offline   Reply With Quote
Old 02-01-2011, 09:13 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
50 Lbs. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 02-01-2011, 09:25 AM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
My tire installer says never exceed the max tire pressure. If you are using a WDH correctly the trailer tongue weight will be evenly distributed front and back on your TV. I check the tires temperature after a 'few miles and if say the rear tires are are appreciably warmer than the front tires I will redistribute the 'load' in the trailer. If not I'll increase the TV rear tires 5 lbs without exceeding the max pressure.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-01-2011, 10:13 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I have E rated tires on my 3/4 van and full load inflation recommendations from GM are 55 psi. front and 80 in the rears. Since the higher pressure on the rear tires is directly related to load that the van carries, you adjust according to that weight load and the load capacity of those tires. In my specific case I'll normally will carry about 75 psi on the rears. My Classic adds about 600 lbs or so of weight to the rear axle.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-01-2011, 10:37 AM   #5
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
If you are running OEM or equivalent tires, and not exceeding tow capacities, including tongue weight, the auto maker of your TV has the proper pressure posted on a tag in drivers door. The pressure marked on tire is the maximum the tire can be at, however the tires are also marked with load limits for that tire on any truck, which does relate to what your towing and should be at a minimum OEM or more. If you increase your tires rating, it is not likely that you need to inflate to max. tire shops know very little, dealer may be better if you want to get exact for your tires.
lahrfarm is offline   Reply With Quote
Tow Vehicle, new-vs-used??? batman Tow Vehicles 26 02-10-2011 10:51 AM
tow vehicle too heavy? Beverly II Tow Vehicles 40 01-31-2011 04:21 PM
Good Durable Tire Inflator? Jim Pona Tires 22 01-26-2011 07:40 PM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 01:50 PM
New Tow Vehicle - 2010 Dodge 2500 sgray Tow Vehicles 13 01-11-2011 07:41 AM
