Old 04-30-2008, 08:20 AM   #15
Originally Posted by Minnie's Mate
My brother-in-law was going to have a hitch put on his Camry to tow the horse trailer and the hitch shop refused because the Camry was not rated to tow even that small amount of weight. However, if the Solara can do it, that would be a beautiful site: the gentle curves of the Solara and the smooth lines of the Airstream...just made for each other.
Heh! I was joking, but I do love that Solara-- it's my wife's car but she lets me drive it occasionally.
And I agree, the Solara would look fantastic pulling an Airstream, but perhaps a Bambi rather than the Overlander that I'm currently seeking.
To be honest, what I REALLY want is to figure out some way to have a '65 Mustang convertible set-up for towing a vintage early-60s Overlander, because I had a love affair with the Mustang even before I realized how much I like Airstreams. But, I don't think it's a very wise or practical towing solution.
Old 04-30-2008, 10:49 AM   #16
cameront120's Avatar
1972 25' Tradewind
Originally Posted by Road Ruler
There sure are. We see many modern sedans towing Airstreams in these parts.
Can you tell us what sorts of sedans you're seeing? And what sizes of trailers? I'm very interested in this. I'd mostly be curious to see if any Volvo 850 wagons are successfuly and safely towing these trailers.
North Vancouver, BC
Old 04-30-2008, 10:50 AM   #17
Road Ruler's Avatar
Images: 38
Buddy, one of the forum members is already living your dream.
Old 04-30-2008, 11:08 AM   #18
Road Ruler's Avatar
Images: 38
Cameront.. This is Can Am country...
Can-Am RV Centre (London, Ontario) – Canada’s RV dealer for Airstream, Crossroads, DoubleTree, Forest River, Keystone, R-Vision, Nu-Wa, and SunnyBrook.
so we see lots of interesting sedan set ups. Just a few are PT Cruiser, Jetta (diesel), Camaro Convertible, Jaguar sedan, BMW convertible, Crown Vics, older Ford LTDs, many Chrysler FWD sedans, Mercedes sedan, many FWD GM sedans. Do a search on form member "Andrew T". He is the man with the info about towing with sedans.
Old 04-30-2008, 11:21 AM   #19
Absolutely beautiful.
I wonder how it would do with an O'lander???
Old 04-30-2008, 11:24 AM   #20
1972 25' Tradewind
My particular Volvo would likely be underpowered to tow my trailer, but I often wonder how it would fare with a vintage bambi or Caravel. When it comes time to purchase a tow vehicle for my Tradewind, I'd prefer to avoid the pickup truck option, if at all possible.
North Vancouver, BC
Old 04-30-2008, 12:12 PM   #21
1975 27' Overlander
High River , Alberta
The 850 has a solid rear axle and a relatively narrow rear track (57.5"). The P2 platform cars (S80, S60, newer V70) have independent rear suspension and a track of about 61". I'd expect better stability with a newer model, but a lightweight trailer like a Caravel would be fine with your car. A friction sway control is a good idea.
The 5 cylinder engines/drivetrains are similar in capability.
A Caravel is 2300 to 2500 lbs empty, with a tongue weight of about 300 lbs. A loaded weight of 3000 to 3500 lbs would be no problem at all. A Class 2 hitch would work, but you will want weight distribution unless you have no weight at all in the back of the car. A custom Class 3 is the solution - email Andrew T. Of course, you would need a suitable brake controller and wiring. Volvo offers a plug-in 4 wire harness that you can start with.
You will need to use 3rd gear with an automatic/4th with a manual transmission to deal with wind resistance at highway speeds. The non-turbo 5 cylinder works fine with an aerodynamic travel trailer, but a conventional square box trailer is likely to be a bit more than it could handle. Long grades shouldn't be a problem at all with 3500 lbs in tow; you will easily outpull the tractor trailers and old gas-engine motorhomes.
An auxiliary transmission fluid cooler is recommended if you have an automatic. If the radiator is in good shape, engine coolant temperature should be a non-issue.
In my personal experience, Volvos are superb cars and a great value if they are well-maintained. They are also excellent tow vehicles.
If you will be in the market for a new car, the 2008 V70 with the 3.2 inline six would have very good pulling power, and should have even better stability. I'm also wondering if Volvo will bring the D5 to North America; 300 lbs ft of torque would make for an impressively strong package. I would tend to avoid the XC70 - it has a higher centre of gravity and taller, soft-sidewall tires.
AlbertF is offline   Reply With Quote
Old 04-30-2008, 12:17 PM   #22
1972 25' Tradewind
Interesting information Albert. Thank you for taking the time to write it. I wonder if the V70 would work well with my Tradewind, or would that be pushing things? I've never been a real fan of the XC70 models. May as well go with the XC90 if I want an suv.
North Vancouver, BC
Old 04-30-2008, 02:05 PM   #23
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Tow ratings for non-SUV, Trucks is a dart throw and something I think they should stop publishing. There are so many factors to consider as we all know when towing. Of course power is one, trans, suspension, wheel-base, frame and receiver set-up, braking, and so on. If we always believed everything in car makers specs we would all be towing 31 foot Airstreams with Mini's getting 28 MPG.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 04-30-2008, 04:15 PM   #24
59tradewind's Avatar
1959 24' Tradewind
BREA , California
what a nice looking combo
my first tow vehicle was a 74 cadillac eldorado convertible.
i will try and find pics to post.
nothing like a classic towing a classic!!!!
1959 Airstream TradeWind
1959 Cadillac Coupe DeVille
59tradewind is offline   Reply With Quote
Old 07-01-2008, 09:18 PM   #25
What do you all think about a Cadillac SRX as a tow vehicle for a 19" Bambi (newer model)?
rjohnston is offline   Reply With Quote
Old 07-02-2008, 07:49 AM   #26
1959 24' Tradewind
BREA , California
I dont think that would be an issue at all
but of course many people will tell you just to check the tow ratings. but with airstreams being so light and having such low tongue weights, i wouldnt hesitate to do it.
Hooking up a WD hitch jwilson Hitches, Couplers & Balls 3 04-08-2008 05:09 PM
Towing behind an A/S Neophyte Towing, Tow Vehicles & Hitches 13 02-21-2006 08:57 PM
Towing..? phibbs All Argosy Trailers 6 10-19-2005 01:44 PM
Towing perfuse2004 Tow Vehicles 5 10-01-2004 04:51 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
