This has been discussed many times, but out of pure curiosity, I would like to know. What exactly happens if your tow truck and A/S unit are sorely mismatched? What's the first thing that happens? Transmission overheats? High RPMs? Slow speed? Inability to stop?
(My tow vehicle is a full 1 ton exceeding A/S ratings, so I feel comfortable with it)
1986 Excella, 32' - FOR SALE ON EBAY, AUCTION # 160034864277
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
I am not one to go trough things one point at a time, so it's time I let Mike talk... sort of.
He wrote a long essay a while back to someone asking his advice, here is the short version:
"Hi,
Something too many people overlook is the towing capability of the tow vehicle. I'll go right to real-world experience.
I've towed a 29ft 7,000 lb Airstream about 9,000 miles a year over the last 12 years or so. When we decided to enter the ranks of tailer enthusiasts we devoted quite a bit of thought to the tow vehicle. There was no question that for our purposes we needed a Van with lots of payload capacity. We decided to get nothing less than a one-ton van.
A vehicle rated for greater weight will come equipped with a sturdier suspension and more powerful brakes. In our 12 years of pulling a travel trailer we never ran into any of the people who stopped suddenly in from of us, but there were plenty of times when I had both feet on the brake pedal, my fingers crossed, and my teeth clenched. And again, on a downhill, brakes tend to warm up. If they can't cool adequately between applications, they get quite hot. Brake Fade is the effect of overheating the brakes to the point that they lose their ability to produce the friction you need to slow the vehicle. Most passenger vehicles are designed to make two or three severe stops. After that you're on you own.
And the last item I can think of at the moment: The drive train. You will be moving at least twice the weight of the vehicle. Regardless of what your engine and transmission *can* do, you should be concerned with how long it can do it. Vehicles designed for heavy duty service will have engines and transmissions designed from the ground up for the job. Transmissions get hot in the mountains or even in stop and go traffic. Engines run hotter pulling a trailer - will the radiator be up to it?
We found that our one-ton Chevy van fell short of every point, in spite of the fact that it had the heavyest of everything. It's brakes weren't powerful enough and as a result required constant and expensive attention. The transmission had to be replaced, as did water pumps, and a radiator. The front suspension collapsed, and we blew tires. I will say, I have NO Complaint about the Engine. It is a monster and it seems to be eternal.
To be fair, we we're very hard on the equipment. We carried the maxium load the vehicle was rated for. We had schedules to keep and didn't always have the option of choosing the easiest route. Our business is in the North-East where highways often look like they were carpet bombed. It isn't likely that you will stress your equipment as badly as we did, but you must choose it wisely.
We now use a commercial duty truck and are delighted with it.
When we first got our Airstream, we had a Jeep Cherokee. Being that our trailer is only 19' long and under 3000 lbs dry weight we were within the "towing limits" set by Jeep (5000 lbs). However, in reality...they were sorely mis-matched, especially at altitude. We would overheat (boil over!) at the slightest incline, hills that we never even noticed before became very noticable. We towed in 3rd, instead of overdrive and still had problems if we tried to go over 50 mph on the flats or 30 mph on mountain roads. Needless to say, there were no freeways in our travels and we were soon shopping for a new tow vehicle. We now have a 1/2 ton GMC Yukon & it is much more pleasant when towing...we can even run the A/C and travel at highway speeds 55-60 mph
We also had some problems with the brakes overheating coming down out of the mountains.
Here's a link to a previous thread in which these experiences were discussed by myself & others. You may also want to perform a search using "SUV" or "Jeep" as keywords.
Shari
Unless something mechanically was already marginal, I think the first thing you would notice is a total lack of control. The steering tires would be very light from overloaded tongue weight. Most of the braking would come from the trailer. The tow vehicle would accelerate, the larger mass of the trailer would take control.
So a 1 ton isn't heavy duty enough? Maybe the answer to the question depends on the expected use. I think a Jeep is ok to tow a trailer SLOWLY 15 miles down the road. Maybe a 1/2 truck isn't big enough to go on long distance trips up and down the Rockies. But I can't see for the life of me how a F-350, or similar other makes, isn't heavy duty enough to pull an Airstream.
Put all these together and it is reasonable that a 1 ton won't be heavy enough. But most people won't subject equipment to these conditions a couple of weeks and a few weekends a year. Whenever you work equipment at it's maximum it will require more maintenance and have more breakdowns.
actually, it did a pretty good job for about 7 or 8 years.
We weighed the rig several times, and yes, it was just under the limit.
And the van can stop the whole rig, and it did .... the times Mike forgot to set back the brake controller (we are still debating who was at fault). But we stopped. A very, very steep down hill. We needed new brakes after that. But we stopped OK.
We had the heaviest duty brake pads that we could get. I cannot imagine a 1/2 ton pick-up being able to stop.
As far as stability is concerned, it is a long wheel base Chevy, no overhang like Ford & Dodge. It is heavy in the first place, and even more when loaded. But we never had a time over the years when we felt the van was not up to the job. With Reese dual cam, it was as stable as you can hope. And it could climb hills faster than our truck. Had to run the heater sometimes..... It now has about 170,000 miles and still doing OK.
In the end, Mike destroyed the brakes one too many times, and we needed more cargo space. So we got a truck.
I have been hauling a 10.5 ft slide in camper on my 1500 Chevy Silverado shortbed , 10000 miles a year for past 4 years, and it handles like a dream. The camper is 2500 lbs , and the truck has Airlift helpers.
The steering is perfect and doesn't feel light. I refrain from going down steep mountains & all is 100 % OK
Actual trucks can handle much more than the rating set by the manufacturers LAWYERS...
Hart
ps: now feel free to flame me and tell me how unsafe I am, and where will I be driving, so you can stay far away. bla bla bla....
I think a good rule of thumb for the hardware is simply to use the tow vehichles specs and try to stay below them.
I work in technology and I never get three complaints--EVER.
1) The machine is too fast
2) The machine has too much RAM
3) The machine has too large of a hard drive
The same holds true for tow vehicles:
1) It has too much horsepower and torque
2) The cooling system keeps it too cool (being that there isn't a problem)
3) It has too much towing capacity
In the first computer senario, I figure if I ever get one of these, I can retire.
The longer the wheelbase of the tow vehicle, the better. Having the correct gears and cooling is a must. A bit of overkill is NOT a bad idea.
I feel if you follow the basic gen rules, you should be fine. Keep in mind condition of vehicle, driving habbits also play a crucial role as well.
Speaking strickly from years of exp with a '77 Ford 400ci station wagon and a bit more than 2 decades using GMs to tow, I can say that there have been ZERO issues following these guidelines. The lest weight of all has been the current Bambi with a 4500-4600 GVWR fully loaded. We've had thousands upon thousands of uneventful pulling as a result of proper planning, vehicle maintence and driving habbits.
Regards,
Eric
Thanks to all who shared their towing experiences in the above threads. For a newbie like myself, who is trying to figure out which A/S trailer is within the limits of my Toyota Tundra V8's towing capabilities, these are sobering thoughts you've posted. I was trying to find the most trailer I could tow within my Tundra's 7100 GVWR limit. I was thinking about the Safari 25C, rated at 6300 GVWR. Now, I'm having misgivings about pushing the limit. Better to have misgivings now, than when careening down a mountain side while wildly pumping the brakes.
