Old 07-26-2019, 06:38 PM   #1
TinyTin
TinyTin's Avatar
2006 25' Safari
San Antonio , Texas
Cold Air Intake for gas Silverado Truck
Has anyone ever put a cold air intake on your truck and did it help in towing? I have a 2019 Chevy Silverado 2500 HD gas. Just wondering if it helps on hill climbs?
TinyTin is offline   Reply With Quote
Old 07-26-2019, 07:05 PM   #2
2007 27' Safari FB SE
Forest Grove , Oregon
I put a S&B on a 2011 F250 diesel and noticed no change in performance except a decrease in fuel mileage. Changed it back to stock and saw a 1 mpg bump up. Maybe the factory engineers have some insight into how things work best......
Now I know there are those out there that do deletes, chip, etc. who will tell you I am wrong. So be prepared for some significant discussion and a variety of opinions.
bweybright is offline   Reply With Quote
Old 07-26-2019, 07:32 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I guess it depends on what is considered cold air.
Our '06 Burb 2500 takes it's air from right front, down low, well away from the engine compartment heat.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 07-26-2019, 11:28 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You will see no difference.
L5P turbo diesel is another story....
wulfraat is online now   Reply With Quote
Old 07-26-2019, 11:49 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, yes you will; It will be noisier and that's all.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-26-2019, 11:55 PM   #6
2007 22' International CCD
One of the more interesting ODB outputs on my Tacoma is intake air temp. Usually 10-15 over ambient air temp.
Old 07-27-2019, 12:27 AM   #7
TinyTin
TinyTin's Avatar
2006 25' Safari
San Antonio , Texas
Thanks for the input
Old 07-28-2019, 06:59 PM   #8
Louisville , Alabama
It will sound cool that’s all
tmeyer10 is offline   Reply With Quote
Old 07-28-2019, 07:07 PM   #9
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I have an S&B on my 6.6 Duramax no difference noted
Dept of “OverKill”
Old 07-29-2019, 09:07 AM   #10
1976 31' Excella 500
Chappell Hill , Texas
MOST late model vehicles already have cold air intake from the factory so adding an aftermarket kit won't help. If you have an older model it may not already have cold air set up so it may help.
tbashin is offline   Reply With Quote
No gas from gas tank to generator intake line jraglow Mechanics Corner - Engines, Transmission & More... 15 08-12-2018 07:31 AM
Cold air intake and air filter Jim Keaty General Motorhome Topics 7 06-27-2017 06:57 AM
Ford 460 Air Intake noiva Mechanics Corner - Engines, Transmission & More... 5 04-15-2006 07:19 PM
More intake air GlenCoombe Mechanics Corner - Engines, Transmission & More... 7 02-04-2006 07:15 PM
will atwood drain from cold intake 63air Water Heaters, Filters & Pumps 2 09-14-2005 04:50 AM
