02-18-2014, 07:23 PM
2013 25' Flying Cloud
Cat City
Chrysler 300 - The Saga Continues
The saga continues with a big FAIL on the first hill climb. After getting the WD right, the anti-sway bar mounted, and everything cleaned up on the hitch, we wanted to get out on a grade, in the heat, and make sure the rig will get us over these California mountains. It turned into an afternoon in hell.
We chose the medium grade from I-10 up to Yucca Valley on CA 62. This is maybe a 12 mile climb from 400 feet to about 3400 feet and very average for around here. It was about 85F outside. We hustled up about 9 miles at 55MPH in 3rd gear. I had the trans temp gauge selected and was watching it like a hawk. An easy drive. Suddenly in 30-seconds everything changed. I first smelled a foul smell, then alarms went off on the dash for overheating. Dash lights were warning, buzzers going, I slowed immediately and moved to the very skinny 8 foot shoulder and hoped I could climb to a straight part of the road. No luck. The car died on a hard right uphill turn. I could now see steam and smell coolant. The trailer wheels were against the asphalt berm on the right. I didn't dare open my driver door as cars were whizzing by at 65MPH or more.
I was able to get out the passenger side and raise the hood. A mess of blown coolant under the hood. We waited 30 minutes. Two Airstreams motored by and honked (a little disappointing actually). A big commercial tow rig stopped and he was very helpful. He knew the road and told me a big flat spot 1/4 mile ahead had 30 feet of shoulder. If only I could start the car. We took water from the TT and eventually filled the radiator and moved the rig up to the big flat spot, where it was at least safe. We waited another hour then crippled to the next possible place to turn back and go downhill. That was a mile up. We coasted downhill with the temp reading 225F, got home at 245F and unhitched and put the car in the garage.
Took it to the dealer. Turned out the coolant reservoir was cracked and had been leaking coolant (I had smelled a weird smell a few times before in the weeks before. I didn't know it was coolant hitting the exhaust manifold). Also, the rad cap was bad and only holding 10# when 17# was the spec. All warranty repairs. I tried to insist they thoroughly road test the car and look for any other cooling issues. They said they did.
I now have the car back and frankly, I am quite nervous. I will first try the car alone up that same grade. Then I will try the trailer on a smaller, shorter grade somewhere to see if there is any sign of heating. What worries me is that we went from "green light to China Syndrome" in like 30-seconds with basically no warning, no time to do much.
I dunno.
02-18-2014, 07:28 PM
1986 32' Excella
Canton
, Georgia
That's terrible! What a horrifying situation. I am so glad no one hit you when you were stranded. just awful. Has your blood pressure recovered yet?
02-18-2014, 07:50 PM
asbury park
, New Jersey
Airstream Life's latest edition featured an article by Andy Thompson , who wrote about why the 300 is a better TV than an F150 or 1/2 ton truck.
Do you believe the cooling system problems you are experiencing are related to towing? What modifications were made to your transmission to tow your rig? Thanks.
02-18-2014, 07:53 PM
2012 25' Flying Cloud
Battle Lake
The first nine miles sound encouraging but a cracked coolant reservoir or faulty radiator cap can't hold the pressure so overheating is sure to happen sooner or later. In spite of the bad situation, you found the faulty components and got it fixed.
Keep us posted next time out.
Doug and Cheryl
02-18-2014, 08:26 PM
Cat City
The article was my inspiration for going to the 300. It's been a long haul and process so far. Transmission is stock. The areas of change were the custom receiver mount and the air shocks in the rear suspension. Everything else is stock.
02-18-2014, 08:27 PM
Common Sense
Yea, a bad radiator cap will let the coolant boil, and then the engine will overheat.
But, one of the things that automotive engineers consider when deciding on a vehicle's towing capacity is the capacity of the cooling system.
Regards,
Steve
02-18-2014, 08:33 PM
2011 28' International
Chatham
, Ontario
I'm sure pulling the load hastened the failure on the 300 but it doesn't sound like the cause. I'm glad you managed to get back in one piece and have the problem sorted under warranty.
For what it's worth we've not had any overheating issues with the Sienna in our three seasons traveling, and the engine cooling is stock. Sure, we don't have the hills in this part of the world but we can end up driving into a 40 mph headwind for hours at a time, which certainly puts some stress on the whole set up. The temperatures do climb but never go into the red and, comfortingly, will return to normal very quickly as soon as the conditions alter.
Thanks for sharing this with us
02-18-2014, 08:38 PM
2012 27' Flying Cloud
W
, New England
Frustrating. Did you have a transmission cooler added to the stock setup?
02-18-2014, 09:10 PM
Battle Lake
Was there any indication of transmission overheating?
Doug and Cheryl
02-18-2014, 09:57 PM
Alamo Heights
Put a similarly bad radiator cap on a pickup and punch a hole in the coolant reservoir and you'd probably get similar results.
— David
02-18-2014, 10:27 PM
Cat City
The tow wasnt the cause of the cracked reservoir. It was cracked before. But the tow did put the system to work, amd once the leak and bad cap couldnt hold, she blew sky high.
The trans was the only thing that did not overheat. For the first 9 miles, the car performed very well. 55 mph in 3rd at 3200 rpm was very comfortable.
Many grades out here run for 12 - 15 miles at 6%. Temps hit 110F regularly all summer long. I have one report from an Arizona man witj a 300 that has towed these conditions all summer with no problems. Thats my reference point. Fingers crossed.
Typing on a pad, sorry!
02-18-2014, 10:58 PM
Salem
, Oregon
Hi, a leaking recovery tank is not a good thing. As you probably already know, Coolant expands with heat and goes into the recovery tank. As the coolant cools, it is sucked back into the radiator. This system is designed to keep the radiator full at all times. This helps with cooling and reduces rust/corrosion. With coolant going into the recovery tank and leaking out, it will be less than full and overheat. Because of the recovery type system, radiators and their tanks can be, and are, smaller. Smaller radiator tanks allow for more pressure and can contain the coolant to a higher temp.
212 degrees, water boils. 212
3 degrees more per pound on cap/system. 15lb cap= 45
30 more degrees with proper mixture of coolant.** 30
Max temp before boil over 287 degrees.
**Note: the coolant increase only works under pressure.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-19-2014, 04:43 AM
Common Sense
And so would a Kenworth, but that doesn't make my statement untrue.
mstephens lives in the desert Southwest, and his test at 85 degrees is nothing. If he does the same test in the same area in the summer, the temperature will likely be 15 to 20 degrees hotter.
Regards,
Steve
02-19-2014, 05:12 AM
Mantua
, Ohio
Towing did not cause the leak, but I wonder what did.? I would be absolutely sure the whole cooling system is flushed a pressurized to insure no leaks. Once the system is checked you should be okay, although paranoid the first time out. Good luck you have a fine tow combo. Jim
02-19-2014, 05:27 AM
Common Sense
You are right, towing did not cause the leak. Who knows what caused the leak in the recovery tank, and that may have even not been an issue if there was still enough coolant in the tank to keep the radiator full when it previously cooled.
However, towing did cause the temps to rise and increase pressure on the system to the point that the weak radiator cap released the pressure causing the loss of coolant, and then the resulting overheating.
The lesson to be learned here is any time you stress a vehicle with additional loads, especially in warmer weather, everything needs to be in good condition, especially the cooling system, and even more especially if that system may be marginal in excess capacity.
Regards,
Steve
02-19-2014, 05:57 AM
St. Catharines
, South Western Ontario
That is bad luck Mstep, sorry to hear..
In my mind it reinforces the idea that checking the condition of our TV's, whatever they are, to be sure they are in top mechanical condition. Our 11 years old car has 230,000klm's on it and I have not changed the water pump or rad hoses yet. I plan to do that in the spring before our next trip.
What I like about your selection of the 300 is the fact that platform has been towing a variety of Airstreams for many 1,000's of miles and many years with great success. That kind of track record is a good thing.
Agree with zigzag. You have a fine combo and wishing you many successful travel years in the future.
02-19-2014, 06:40 AM
1994 30' Excella
alexandria
, Kentucky
This sounds like every "used" car that I have purchased. There was always some maintenance/repairs to do before it is up to MY LEVEL OF MAINTENANCE!
Anti-freeze on a hot engine does have a distinct smell as do other fluids when they leak. Every once in a while you should pop the hood, crawl underneath and look for things out of the ordinary. Even if your not mechanically inclined or don't want to be you will learn about your vehicle and be more confident in taking it on trips. When you change fluids replace them with OEM or better (synthetic).
I wouldn't fret about it too much. Take some time an make sure all areas are up to spec and it should do the job as it has for others.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
02-19-2014, 06:53 AM
Cat City
They replaced the coolant, reservoir and cap and road tested the car. They also cleaned up everything under the hood where all the coolant spewed over everything. The mechanic told me the normal running temp is 205F.
I'll be taking it back out Friday for another try. Smaller grade with more exits for the first time out. I think now I'll have to build confidence slowly. I would never want to be stuck like that again. But as the wife says, "that was a nothing grade compared to others we have to climb." She's beginning to give me the stink eye about this Chrysler 300 idea. So, it really has to pass a pretty tough test to be viable. I'd be lying if I said I wasn't nervous now.
02-19-2014, 06:59 AM
Cat City
Crispy,
You are so right. I really should have investigated this the first time I smelled it. It was odd, and instead of just going to the shop, I "kept thinking about it." My wife smelled it once and blamed it on the dog (you have to own a dog to understand that one).
02-19-2014, 07:08 AM
Lin
, Ne
Pay attention to the oil level. Sometimes engines start consuming oil after being overheated.
