Old 02-22-2014, 08:02 PM   #85
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It kind of does sound like a t-stat or something, it should cool when not under load.
Old 02-22-2014, 08:18 PM   #86
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Surprising that the dealer didn't replace the thermostat when you were last in. Probably a 40 dollar part and a half hour labour.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-22-2014, 09:25 PM   #87
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
mstephens,
We you driving around north Palm Springs about 11 this morning?
We saw a white 300 towing a wide body Airstream on our way to the Vintage Trailer Show.
Bill
Just my personal opinion
Old 02-22-2014, 11:10 PM   #88
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Yes, that was us. I am pretty sure there are no other C300 TVs nearby. We limped it home slowly and then went to the antique trailer show after lunch.
mstephens is offline   Reply With Quote
Old 02-23-2014, 06:26 AM   #89
Gainesville , Florida
Get the system flushed, new tstat and insist on a full test drive by tech if at all possible. Has to be something with this particular car. Any service records available from the selling dealer? Warranty work should be documented by Chrysler. Good luck. Jim
Old 02-23-2014, 06:37 AM   #90
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
I would go back to your dealer and pay them to remove the thermostat and put new coolant liquid in. I think that a lot of question will be answer running the car in that condition...
Don't give up!!
1998 Safari 25' SS
2015 Toyota Sequoia Limited
Buck944 is offline   Reply With Quote
Old 02-23-2014, 06:41 AM   #91
dznf0g's Avatar
Oswego , Illinois
When it is hot, have you looked under the hood to see if there are any bubbles appearing in the surge tank? I still feel like there are combustion gasses escaping from the combustion chambers into the cooling system. Is the level in the surge tank dropping at all after an overheat cycle, when it is completely cooled down?
-Rich-
Old 02-23-2014, 07:06 AM   #92
mstephens's Avatar
Yesterday it did not appear that ANY coolant was being lost. I looked very closely everywhere under the hood while running. Coolant level is on the HOT mark. Slight gurgling sound from the reservoir. This am I will check the COLD level. I marked it carefully before we left yesterday.
If the dealer won't change the t-stat under warranty, I'll go to my mechanic and pay to have him do it.
You know, in a modern dealer service situation you can't get to the mechanic. A "service writer" intercepts you to do paper work and they have no car knowledge. It's hard to get across the fine points of what the car is doing. So, I am going to type up a description that can be handed to the mechanic. Otherwise, the service writer puts down "over heating" and the mechanic does a basic test and if it doesn't show a problem, he's done.
Old 02-23-2014, 07:14 AM   #93
dznf0g's Avatar
Oswego , Illinois
The gurgling makes me believe there are gasses in the cooling system. So does the very rapid rise in coolant temp...form hot to very hot in short time described above. It's a long distance, sight unseen diagnosis, but I really think it's a head gasket or cracked head/block. You should see some lowering of cold coolant level though....and smell coolant at the exhaust.
-Rich-
Old 02-23-2014, 07:27 AM   #94
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
At the very least I would change the thermostat and the radiator hoses. I have had a hose that would collapse at intervals.
Are you running an add on transmission cooler?
I would also look at getting rid of it unless I found a clear, definitive cause and could assure it is fixed. My experience was you could run around town and idle it in parking lots at 100 degrees and it was fine. But drive it on the interstate and stop for a rest area or gas and it overheated and spewed fluid everywhere. But not everytime.
Bill M. is online now   Reply With Quote
Old 02-23-2014, 07:29 AM   #95
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Rich,
Aren't there shop tests for combustion gases in the coolant?
Jut did a QUICK search and this Autozone info Product & HowTo Info | | | INSPECT | AutoZone.com came up, scroll down the page a bit. Might offer a little insight.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-23-2014, 08:33 AM   #96
dznf0g's Avatar
Oswego , Illinois
Yes, but I wouldn't assume they did it...or properly. I have seen instances where a head gasket seals pretty well cold and opens up hot. Didn't show on a couple hour cold pressure test. Might show overnight.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 02-23-2014, 08:49 AM   #97
Man, what a pain in the butt. Document everything and like I said the service dept. should be able to pull up all warranty work done by vin number no matter what dealer did the work. Past history could be your salvation if the worst case scenario comes true. Jim
Old 02-23-2014, 08:58 AM   #98
mstephens's Avatar
New Info
I checked the levels. It was down about 1 Qt of coolant.
I plugged in my ODBII reader, started the car and immediately got this message:
P0117 - Engine Coolant Temperature Circuit Low Input
chrysler hub caps? sawdawg1 Wheels, Hubs & Bearings 4 09-17-2011 07:11 PM
Chrysler 300c AWD: What can I tow? CrashInBlack Tow Vehicles 12 03-08-2011 04:23 PM
