02-19-2014, 07:25 AM
#21
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Low coolant. Bad radiator cap. That will stop any TV on a hill.
02-19-2014, 07:59 AM
#22
N/A
, N/A
Originally Posted by Road Ruler
What I like about your selection of the 300 is the fact that platform has been towing a variety of Airstreams for many 1,000's of miles and many years with great success. That kind of track record is a good thing.
Are those, with successful experience on 300, users on Airforum? Maybe we can ask them to chime in.
02-19-2014, 08:02 AM
#23
1994 30' Excella
alexandria
, Kentucky
Originally Posted by mstephens
Anti-freeze on a hot engine does have a distinct smell
Crispy,
You are so right. I really should have investigated this the first time I smelled it. It was odd, and instead of just going to the shop, I "kept thinking about it." My wife smelled it once and blamed it on the dog (you have to own a dog to understand that one).
I try to let the dog outside before he starts "smelling funny"
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
02-19-2014, 08:08 AM
#24
2013 25' Flying Cloud
Cat City
Originally Posted by r carl
Pay attention to the oil level. Sometimes engines start consuming oil after being overheated.
I'm gonna have the oil changed today.
02-19-2014, 08:19 AM
#25
1984 34' International
Toronto
, Ontario
If you've got access to an Android phone, you can install a $5.00 OBDII reader. You'll also need a $10 bluetooth connector to send data to the phone.
I would not be too worried about the capabilities of the vehicle. Our V6 never even got close to overheating and now that your engine has been fixed it should be just fine.
I've said this before, but I've measured hp output at the wheel when towing. I could not get it to more than 148hp, and that was accelerating up a hill from a standing start.
I too would be nervous in your situation, and my wife would have similar opinions, but I am still confident that you're doing all the right things and that this will work out for you.
02-19-2014, 09:08 AM
#26
K.C.
, Missouri
Mark,
Well that's a bummer for the first pull. One thing I would watch real close for the next several months is the coolant level. How I would do it is this: with the car on a nice level place, maybe in the garage and the engine totally cooled off ( overnight ), pop the rad cap off and make sure it's full. Make a mark with a sharpie or a piece of tape on the side of the res tank so you know exactly where the level is. With that as a starting reference point, watch it like a hawk over the next month or so, checking it the same each time....totally cooled overnight, parked in the same spot. If it is "consuming" antifreeze, even a little....lean on the dealership to find out where it's going.
Worst case scenario is that when you got it hot, a head could have warped and breached the seal at the head gasket. Depending on "where" the breach is of a head gasket, coolant can go into the crankcase ( into the oil, you see the oil turn to something that looks like a chocolate shake ), out the exhaust ( if there is enough, you'll see white steam out the tailpipe ) or just out of the engine as a leak.
Hopefully, ( and likely ) you did not warp a head, but I would not rule it out. Aluminum heads and blocks do not like to be over-heated. Aluminum tweaks and twists around much more quickly than iron.
I'm not trying to scare-monger, nor am I "guessing" that you damaged it. Just trying to say I would watch it, and since it's still in warranty ( ? ) make the dealer fix anything on their nickel, since this went into overheat mode due to faulty factory parts.
That's my $.02 on the deal. Good luck with it.
02-19-2014, 09:42 AM
#27
1995 30' Excella
Bowie
, Maryland
That sucks. It doesn't matter what vehicle you're using: If, the first time you go out and tow with it, it breaks down, it's going to be a while before you fully trust it! Especially if your spouse wasn't entirely convinced on the idea in the first place.
It would've broken down on you sooner or later without towing (or you would have had to keep adding coolant), which may be some comfort.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
02-19-2014, 09:49 AM
#28
Oswego
You guys may be overlooking one scenario. There could be a combustion pressure leak into the cooling jacket through a head gasket or cracked head/block. This can cause an over pressurization of the system and crack an overflow tank. In theory, the cap should prevent this, but it does happen. I wonder why a tank of a reasonably new vehicle would be brittle enough to crack of its own accord. Also, though I am not too familiar with Chrysler products, many of the newer systems' overflow (or reservoir more accurately) are under cooling system pressure and not at atmospheric pressure. These are the ones which would be susceptible to combustion pressures.
-Rich-
02-19-2014, 09:59 AM
#29
1995 30' Excella
Bowie
, Maryland
It happened in my Cougar! The engine ran for another 100,000 miles. It doesn't have to be brittle: A slight weakness in the plastic; an overtightened nut when it was being bolted in; any little thing.
02-19-2014, 10:21 AM
#30
Wise Elder
2010 30' Classic
South of the river
The thing missing from this conversation is that, for any vehicle but especially for a tow vehicle of any kind, the cooling system should be pressure tested regularly as part of preventative maintenance.
The 300 has a pressurized plastic cooling tank, not a "recovery tank." Any cracking or leaking will cause problems under load. There is no way to identify these problems in advance without testing for them.
Better shops will a pressure test at every oil change without being asked. Or you can buy a tester for $70 and the adapter that the 300 needs for $30 from any of a number of sources on line and do it yourself. It only takes a few minutes to test the cap and then pressurize the system, then you can go do something else for a while and come back and check the gauge.
02-19-2014, 10:22 AM
#31
K.C.
, Missouri
Possible.
If it were mine ( but then I am pedantic ! ) I would do a compression check and a leak-down test, if for no other reason than to have some baseline numbers.
02-19-2014, 10:25 AM
#32
2007 30' Classic S/O
Somewhere
, South Carolina
Mstephens,
Sorry to hear of your troubles. I think both gmw photos and dznf0g have offered some real good tips.
I'd like to add one more that gets you DATA about you engines health.
Engine oil analysis.
A sample is taken an a lab gives you a report for wear metals and contaminates in the sample.
Independent and defined. It actually does not cost very much either. I get one for my Cummins every so often.
Good luck.
Gary
02-19-2014, 11:13 AM
#33
K.C.
, Missouri
Originally Posted by GCinSC2
Mstephens,
Good luck.
Gary
Good point. I use blackstone labs. Go to their website and request a sample container, they will mail it to you.
02-19-2014, 12:55 PM
#34
2012 25' Flying Cloud
Battle Lake
Don't make too much of this. It's not a failed experiment, it's a part that was already broken screwing up your test of an already proven concept.
Doug and Cheryl
02-19-2014, 01:10 PM
#35
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
fwiw, I had a Ford Taurus that suffered the same cracked-tank issue. (and it was the "pressurized" type, too). The car wasn't as "new" as your 300, but it wasn't terribly old, either. (don't remember exactly). My mechanic told me that it was an extremely common problem with this vehicle.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
02-19-2014, 01:41 PM
#36
Cat City
There's so much plastic under the hood, that I suppose I wasn't terribly surprised to hear "cracked tank." It doesn't look robust. Also, the way things are jammed in a modern car, there's a LOT of heat under the hood. You know?
I am trying not to panic. I think this was a fault that existed when I bought the car and not related to my conversion to a TV. It just happened to blow when I was road testing the tow up the first grade. Although it looks related, it probably isn't. The tank is a two piece molded affair which means it is glued together.
Apparently it IS under pressure because they installed a new pressure cap. I liked the idea of making marks on the tank for cold, hot, and so on, to track the level. I will do that beginning today.
Can anyone say why they run cars at 205F as normal? I would have thought 150 or so would be normal.
BTW, I have a regular ODBII instrument. I'll connect it and see what gauges it will display. I really haet fumbling with arrow keys to select one instrument at a time. It's the feature I hate the most about the car. The little screen on dash would be able to display at least 10 lines of info if the programmers had used common sense. Instead, they wasted their tiem programming silly graphics on the screen instead of important information. Absurd.
Thanks for all the idea and info!
02-19-2014, 01:48 PM
#37
Common Sense
Emissions control. They get a more complete fuel burn at higher temps., and better fuel economy, up to that point. As you already know, the problem is it's right close to the "too hot" point, and if you loose pressure on the system, it will boil over any time it's under load.
Regards,
Steve
02-19-2014, 01:56 PM
#38
K.C.
, Missouri
150 degrees F would be considered too cool. For many years, 180 had been considered normal. Once we moved into the modern emissions era, somewhat higher temps were found to help in getting engines to burn more cleanly, and likely in a more fuel efficient manner.
Example, my Nissan specs the thermostat to "begin opening" at approx 174 and be "fully open" at 204. My scangauge shows normal op temp to be between 193 and around 202, virtually all the time. No matter whether empty or towing, cold day or hot day, sea level or in the mountains of Colorado. So apparently Nissan has figured this is the "correct" range.
I have seen it hit close to 220 a few times on a long hard pull though.
One problem with running an engine too cool is the oil also ends up running cool, and never gets hot enough to boil off any water that has condensed in the crankcase, which can lead to corrosion.
EDIT: Steve typed faster than me....and as usual, said what we needed with fewer words !
EDIT_2: An example of an exception to these operating temps would be a methanol powered engine. Back in my days of getting to do grunt/simple work on a sprint car team, I remember those engines typically ran at 160 degrees or a little less
02-19-2014, 02:23 PM
#39
Alamo Heights
My F150 normally runs at 195F with an older-tech engine. Newer direct-injection engines can run higher temps and manage detonation with precise control, and the higher temps help them with efficiency and emissions.
One of the reasons that overheating/boil-overs is more rare than it used to be is the higher-pressure cooling systems, tolerating much higher temps and pressures before it becomes a problem than older vehicles could.
— David
02-19-2014, 04:03 PM
#40
Salem
, Oregon
Hi, most modern engines, including Chrysler products, will shut down the engine before any damage is done to it. I've been a mechanic most of my life and never smelled a dog who smelled like coolant; Bad yes, but not like coolant. Some newer cars don't actually have a radiator cap; [on the radiator] They use the cap on the recovery tank for filling and holding pressure. You shouldn't have to check every/any/thing on a new car. A cracked coolant recovery tank is more than likely a factory defect, not something that you did. Also your recovery tank should already have cold and hot level marks on it. [mine does]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
