Old 02-24-2014, 05:30 PM   #141
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Originally Posted by mstephens View Post
2012 Chrysler 300S with the 3.6L and the 8-speed. It has about 34000 miles.
Dealers repairing Chrysler V6 engines - Autoweek
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 02-24-2014, 06:09 PM   #142
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Originally Posted by newroswell View Post
Interesting information. I am still waiting to hear the service report. I called earlier and they did get it to overheat (yea! no more argument about that!), so they now are deciding what is the cause.
mstephens is offline   Reply With Quote
Old 02-25-2014, 06:07 AM   #143
Gainesville , Florida
That is a start! Get the service records? Jim
Old 02-25-2014, 11:06 AM   #144
mstephens's Avatar
They are pulling the heads off to inspect the block. Possibly a whole motor will be installed.
Old 02-25-2014, 11:25 AM   #145
K.C. , Missouri
That is interesting they feel they are willing to go the labor hours to pull the heads to determine if they are going to replace the entire engine. I would have guessed a complete enough diagnosis could have been made already to say, "yep, replace engine", or "no, just pull heads, replace head gaskets".
I would certainly look very closely at potential transmission damage. That got very hot too, so the question is, will just a fluid change be sufficient, or does it need to go deeper.
Sorry....but I HATE automatic transmissions....but that's just me.....
gmw photos is offline   Reply With Quote
Old 02-25-2014, 11:39 AM   #146
Wise Elder
Jammer's Avatar
2010 30' Classic
I'm not sure I follow. The transmission generates far more heat internally than it absorbs from the air flowing through the engine compartment or from conduction across the bellhousing. Surely the OP has an oil-to-air auxiliary transmission cooler that would keep transmission temperatures low.
..shrug.. not sure why you're dispensing advice on how to save them, then.
Old 02-25-2014, 12:06 PM   #147
K.C. , Missouri
The transmission was subjected to abnormally high heat during the two failed towing attempts. Added heat was likely applied to the transmission fluid from both the fact the factory transmission cooling passes thru the engine radiator and the fact the transmission housing is mechanically bolted to the engine block. Auto transmission fluid degrades rapidly when overheated. Some parts in the transmission can also be degraded due to overheat. The OP is near the end of the warranty on this vehicle, so if there is any damage done to the trans because of the overheat problem, then obviously it's in the best interest of his pocketbook to get this remedied while it is under warranty.
I'm not sure why you question my comments regarding the use of automatic transmissions just because I state that I hate them ? I have now, and have owned over my 45 years of driving, many automatic transmissions. Also many manual transmissions.
Maybe this will be more palatable to you: I personally prefer a manual transmission for my driving needs, because they do not suffer the issues of overheating fluid, added heat from a torque converter, etc.
Old 02-25-2014, 01:12 PM   #148
mstephens's Avatar
Well, so far I have only talked with service advisor, who functions as a clerk. But, it looks like I will sell this car after getting it back. New heads or new engine both would be reason to unload. Lemon is lemon.
I clearly made a mistake. It happens in life. I did not do enough research into the V6 inherent design flaws. I was too focused on the towing add-ons to search the reliability issues. My bad. All that head failure data was available. My enthusiasm got me burned. Funny, I considered the Hemi, but then figured the gas mileage was too low.
Not sure what we will do from here, as it might take time to unload this car. I am not seeing too much camping in the near future.
Old 02-25-2014, 01:50 PM   #149
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
My brand new 1989 Jeep Cherokee developed a knock in one of its pistons at 3000 k. The dealer fixed it. I (along with my kids) then proceeded to put about 500,000 k on the thing before I gave it to the Kidney Foundation about 20 years later. It looks like you may not be alone with the issue and that a solution has been engineered. I would not be inclined to throw out the baby with the bath water. But then I like the adventure. Wife, not so much. We can find other stuff to agree on. Jim
Jim Flower is offline   Reply With Quote
Old 02-25-2014, 02:07 PM   #150
SteveH's Avatar
Common Sense , Texas
Your frustration is understandable, but if I were in your situation, I'd wait and see what all is damaged, why it was damaged (there might have been something like a casting flaw), and how it does after the repair.
Like has been said many times in this thread, given the faulty recovery tank and cap, any vehicle would have overheated.
But, that's just my opinion, and if were still working, I'd be looking for a good dual use vehicle also.
Regards,
Steve
Old 02-25-2014, 02:11 PM   #151
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Don't be too hard on yourself. You bought a used car from a dealer that had been traded in, probably because it had leaking head gasket. They only get worse with time and your initial tow pushed it over the edge. Wait till you get it back to test. I blew engines and transmissions in my early off-roading days and just rebuilt them better and stronger. A new engine is better than what you started with.
Anyway thanks for sharing your your experiences. Many here will fault you for trying. But you can modify vehicles to perform better than OEM. Over 6000 SEMA companies have proven that.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-25-2014, 03:12 PM   #152
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I don't think I'd blame you for letting it go after that, and if they put a new engine in it, that probably won't be too hard to sell.
It's a shame because I don't think you really did anything to it, it sounds like it was ready to break when you got it As we say with the old cars, if it broke it needed to be replaced anyway.
Buying a V6 AWD Charger was at the top of our list for tow vehicles as well just a couple months ago, and I never read anything about problems with the V6 engine, and I was researching my options pretty heavily.
Stephanie
Old 02-25-2014, 04:38 PM   #153
jcl
Vancouver , British Columbia
I would encourage you to let them fix it and see what the service report says. If it says there was a faulty cylinder head or block, fine. What you want to know then is what is different about the new one they put in. If it is exactly the same, then you can decide what to do. But if they have addressed the problem (as they claim to have done) with a revised casting or design or manufacturing process, then that should be evaluated before throwing in the towel.
jcl is offline   Reply With Quote
Old 02-25-2014, 04:48 PM   #154
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
Chrysler has "revised" the new replacement cylinder heads SEVERAL times now...and the problem persists, MUCH more common in the vehicles that run hotter (such as the Jeep Wrangler). As a matter of fact, Chrysler's "fix" in part on such hotter-running vehicles involves a thinner viscosity oil as well as reprogramming the computer for the fans to come on sooner. But, it's all just a stop-gap patch fix, prolonging the inevitable on the Pentastar. The latest heads released (just read the nearly 200 page thread on the Wrangler forum linked above) still don't solve the problem. The exhaust valves fail under excessive workload and heat. The Pentastar has an integrated exhaust manifold in the head itself which is thought to cause the failure. But, so far...Chrysler blames poor gas, "driving habits" (whatever that is), and is replacing heads on an hourly basis...for the last TWO YEARS with no end in sight.
Avoid the Pentastar.
ggoat!!! is offline   Reply With Quote
chrysler hub caps? sawdawg1 Wheels, Hubs & Bearings 4 09-17-2011 07:11 PM
Chrysler 300c AWD: What can I tow? CrashInBlack Tow Vehicles 12 03-08-2011 04:23 PM
