Old 03-08-2014, 06:27 AM   #29
SteveH's Avatar
Common Sense , Texas
One last story from me about this overheating subject, and then I'm off the thread....in the early 60's my dad bought a new Dodge pickup, 1/2 ton, standard cab, long bed. Sort of a sport truck for the day, came with black racing stripes down the hood, bucket seats and a console (which he promptly had the dealer change for a standard seat), and a great big 426 cu. in. engine. He bought the truck to pull his 31' Airstream.
Well, the truck was great. Pulled like no body's business, all except when pulling long grades in high country, it would overheat. So, my dad tried all sorts of magic coolant system addatives, recovery systems, special fans, but none of them worked. So, he sold the truck to a friend.
The friend and new owner of the truck took it to a radiator shop, and had a larger radiator core installed in the same tanks. The guy drove the truck several more years pulling all sorts of trailers with it, and it never overheated again.
mstephens, sorry this did not work out for you.
Regards,
Steve
Old 03-08-2014, 07:54 AM   #30
Denis4x4's Avatar
Durango , Colorado
Been following this thread and have come to the conclusion that your 300 in particular was the culprit. I've walked away from projects on several occasions and it appears that you made a good decision in moving on.
Once there is a mechanical issue, it's difficult to put trust in that vehicle even when it was "fixed". Took a $10,000 beating on a 2012 Silverado with transmission issues and traded it in with 2500 miles on the odometer.
The caption for this photo should be: "New Trucks Break Too!"
Denis4x4 is offline   Reply With Quote
Old 03-08-2014, 08:29 AM   #31
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
D4x4, I come from a long line of sailors where not fixing stuff is not an option unless you can swim forever. Probably helps to explain why I keep my Jeeps for 20 years. In my mind, all things can be fixed. I have just not figured out how to keep the things from rusting away. Also, when it is practical to give up. My wife found me in the garage last week end after spending 2 hours trying to fix a plastic ice scrapper. A new one costs .99 cents. But a cooling issue? Surely that must be in "fixin 101" at the Chrysler school of Customer Service. Or maybe they just run hot when working and every thing is actually ok? Jim
Jim Flower is offline   Reply With Quote
Old 03-08-2014, 09:43 AM   #32
Denis4x4's Avatar
Durango , Colorado
Jim, I too was a sailor for 40 years and agree with you on fix its. However, the technology and hourly rate to address issues like the ones on the 300 don't always make sense. GM's policy on the transmission that became suspect with less than a 1000 miles was to replace it with a rebuilt unit. The fact that it came flawed from the factory made no difference. I have three Model A's and a '60 Thunderbird and have no problems digging into the bowels of the engine compartment. The engine bay on the '13 Grand Cherokee is such that it's difficult to find the dip stick!
I suspect that 20 years hence, there will be fewer AS owners "restoring" models built in the first 10 years of this century due to the fact that they are much more complex then those Airstreams built 30 years ago.
Again, I'm sorry to see the 300 Project come to an end.
Old 03-08-2014, 11:17 AM   #33
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
D4x4. Sometimes it's just hard to accept that it's time to press the emergency locator button. Jim
Old 03-08-2014, 06:48 PM   #34
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I never had a Chrysler passenger vehicle that didn't overheat towing over 6,000' on upgrades in extreme temps, and sometimes less and sometimes not towing. This is with all the recommended extras. It's like they design them with minimal cooling.
Ahab is offline   Reply With Quote
Old 03-08-2014, 09:38 PM   #35
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Just a note to advise that may be your passenger car experience but may not be universal. We have no such problem with out 2012 Ram 1500 Hemi towing grades at high altitude in hot weather.
Doug and Cheryl
Old 03-08-2014, 11:23 PM   #36
Portland , Oregon
I just found this thread, and have also considered a 300/Magnum/Charger as a tow vehicle. Our first TV was a 2000 BMW 540it wagon, with the 4.4L V8. It towed our little 13' trailer just fine, but I was always afraid the cooling system would explode as they aren't robust to begin with.
So we sold it and bought a 2004 Tahoe with the 5.3L V8. It tows our 26' Countess just fine, but was losing coolant the whole time we owned it. Until I figured out some of them came with porous heads. Yup, ours has them. A bottle of stop leak fixed it (the factory recommended fix btw) but it shook my confidence until I had a few hundred miles on the car.
So a Tahoe would likely serve you fine, just watch out for the swiss cheese heads.
Ian Lomax
1966 Streamline Countess 26'
JeweloJalopy is offline   Reply With Quote
Old 03-09-2014, 07:28 AM   #37
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I've followed this thread and related. Damned sorry to see this conclusion, but agree with ditching this particular car. Until this iteration (this latest engine and 8-speed) I'd have gone with the Hemi powered versions. That choice may need to stay in place.
Expedition over Suburban if you go that route. Fully independent suspension always trumps live rear axle. Stick a PRO-PRIDE on the back and work the numbers.
Old 03-09-2014, 08:03 AM   #38
Road Ruler's Avatar
Images: 38
Originally Posted by mstephens View Post
Our experiment ended very quickly today in the 90 degree heat of the desert.
That is a bummer ms. I too truly believe that car has an lurking defect.
PS..... Years ago my cousin bought a new diesel pick up. He was in the fishing industry in the Maritimes and when he got the call to get out on the water he had to drive to the boat ASAP. He bought the diesel because he thought it would be the most reliable. Instead it too was a lemon. Always blowing head gaskets. The dealer had the head off it many times to no avail. They just couldn't fix it. Not sure of the outcome but it goes to show it doesn't mater what you buy there is a risk of disappointment.
Best of luck with your next steps.
Old 03-09-2014, 08:03 AM   #39
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Read my post again. I said passenger car.
Old 03-09-2014, 10:50 AM   #40
K.C. , Missouri
Well Mark, you gave it the old college try. Good luck moving forward, and enjoy whatever tow vehicle you settle on. Time to go camping....without worrying.
gmw photos is offline   Reply With Quote
Old 03-09-2014, 11:36 AM   #41
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Yeah George, that's our plan. More camping, less wrenching.
We're out looking for TVs yesterday and today.
mstephens is offline   Reply With Quote
Old 03-09-2014, 01:04 PM   #42
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Can you still get a brand new regular cab Ram 5.7 for $25,000?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Chrysler 300 - The Saga Continues mstephens Tow Vehicles 319 11-06-2015 12:25 PM
Removing dents from Argosy steel end cap VtTim Ribs, Skins & Rivets 7 01-28-2014 08:15 PM
Gaucho plastic support end caps, under sink tambour '79 Argosy threedjane Airstream Classifieds 0 01-28-2014 07:11 AM
Chrysler 300c AWD: What can I tow? CrashInBlack Tow Vehicles 12 03-08-2011 04:23 PM
