Old 03-16-2015, 11:18 AM   #15
2018 33' Classic
Newport , Pennsylvania
I also would recommend leaving it in tow haul mode when towing and don't worry about gas mileage there are too many variables, ethanol v/s no ethanol, 87 grade fuel vs's higher octanes.
enjoy the ride the difference is not significant. just spend your kids inheritance and have fun
I like to run 70 mph
earl
EarlM is offline   Reply With Quote
Old 03-16-2015, 11:20 AM   #16
johncook's Avatar
2007 27' Safari FB SE
Mesa , Arizona
11 is about what to expect at 60 MPH
I have a silverado 2500 HD with the 6.0
Puresilver
johncook is offline   Reply With Quote
Old 03-16-2015, 02:14 PM   #17
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
Originally Posted by FishinHatteras View Post
Fellow AS'ers,
I wanted to ask fellow folks what they are getting mpg wise when towing their rig with the 6.0L? I have never checked what kind of gas mileage I was getting while towing but decided to check it y-day. In a 92.8 mile span of use, I managed to get a lousy 8.5 MPG. That just seems too low. I was expecting closer to ten, more like 11.
My specifics: All tires inflated on the tow vehicle to 60lbs. I have not taken the time to check the tire pressure on the TT in about three weeks. That was pretty stupid on my part, and I should have checked it before we left. Going to go check them right now. I had no water in my tank, and hardly anything in the TV. Wife & two dogs, with minimal cargo besides my tool box & socket set. TT is a 28' Int'l Ocean Breeze. Tow vehicle is a 2012 Chevy 2500 Crew Cab with a camper top.
I have several questions:
Did I drive far enough to even GET a good average? We were coming back from Myrtle Beach, so we were steadily increasing above sea level.
What are you guys getting towing a similar rig? I have the 3.73 rear thankfully. I was trying to stay just under 70mph, and keep it in O/D as long as possible. I was trying not to fall below 65mph, unless on a steep hill. I wasn't getting into the throttle, but I wasn't trying to baby it either.
The only engine modification I have made was installing a K&N air filter. All else is stock.
What can I do to increase that MPG w/o spending a great deal of $?
We are trip planning to Phoenix, AZ this May, with stops in UT, CO & others. I am trying to determine what my fuel expenses are going to be. I was figuring around 11 MPG, but this sure increase the bill significantly.
Thank you for taking the time to respond to my questions.
Gavin
You did not say what your TT weighs. I pulled a 34' TT, 8200lbs, 62 to 65 mph, with a 2003 1500HD, 6L. I averaged 8.5 to 9.6. A K&N Filter did not help mine any. I bought the truck new, I use it most for towing. It only has 33k miles now.
The only way I found to help MPG is to park it.
1Boyscout is offline   Reply With Quote
Old 03-16-2015, 02:56 PM   #18
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Keep it out of overdrive and don't get over 60 and SHAZAM ! you just might get that elusive 11
dannydimitt is offline   Reply With Quote
Old 03-16-2015, 03:52 PM   #19
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I have a 2014 Silverado 5.3 with 3.09 or so high speed rear end and pull a 2014 30' Classic. I do not use Tow Haul and drive 55 to 60. On a 5,000 mile trip from Iowa to the Pacific NW I got 11.5. Yes, it shifts more and is slower up the hills, but I like the mileage.
larryglarson is offline   Reply With Quote
Old 03-16-2015, 04:09 PM   #20
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Used to tow with a 2012 2500 Suburban. Your numbers seem about right given your speed and elevation change. The way that vehicle is geared, there's a huge difference between 60 and 70mph.
phbarnhart is offline   Reply With Quote
Old 03-16-2015, 04:54 PM   #21
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I have an '09 2500HD/3.73 and I am towing a '97 Excella. Trailer weighs in at around 7900# I avg about 8.5-10.5 depending on conditions. I leave it in tow/haul and run about 60-65.
My toughts are that you don't buy the 6.0L for the fuel mileage, you buy it for the torque. I pulled a friends '54 Cruiser and avg 11.5-12.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 03-16-2015, 05:53 PM   #22
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Along with the K&N, Royal Purple HPS Motor oil and Lucas fuel conditioner. It will give you about 1.8 to 2.5 more mpg. The lucas fuel additive is cheaper by the gallon(around 30). I prefill my own 1/2 pint bottles for use during refills. Love the stuff.
Try it once and see for yourself.
NavyCorpsman is offline   Reply With Quote
Old 03-16-2015, 06:26 PM   #23
r carl's Avatar
Lin , Ne
Fellow AS'ers,
Gavin
I have a 2500HD with the 6.0 and 4:11 rear. When I bought the truck my research showed people were getting better mileage with the 4:11.
I will lose 1 mile per gal for every 5mph over 55mph I drive. Also I will lose 1mpg if I use 10% ethanol. You wont gain anything if you use premium gas as the 6.0 is a low compression engine. Driving into a headwind will also kill your mileage. Use high quality lubricants in your diffs, transfer case, trans, and engine.
Old 03-16-2015, 08:04 PM   #24
chaseav's Avatar
2015 25' FB International
I drive a 2007 Chevy Avalanche (1500) 2wd with 5.3L and 3.73. I am a pilot so I am constantly monitoring anything that can be monitored and in this case, fuel burn and trans temp are about it. When I first got the AS back in Dec, I was shocked to see my truck go from a highway average of 20 mpg all the way down to more like 8.5 once hitched. This terrified me. Since then I've towed 2500 miles and much to my surprise the fuel economy has steadily increased to where I now average 11 mpg. * I live in the south where it's mostly flat.
Nothing about anything to do with my setup has changed at all over this time except the total weight of the stuff we bring with has gone up. Something that should have the opposite effect. The fuel economy does not seem to change if I drop down below 65 nor does it seem to go down if I go over 70... I've never pushed it though to find out.
I'm very happy with my TV and Airstream's towing capabilities with one exception... in hot weather, stop and go traffic the trans temp gets up there to 210 degrees. The manual says 180-205 is normal operating but it give no other limitations. Should be interesting to see how the setup does over the mountains this summer!
chaseav is offline   Reply With Quote
Old 03-16-2015, 08:21 PM   #25
1986 31' Sovereign
Miami , Florida
Fundamentally, it takes "x" amount of energy (btu's) to move your basic Airstream through the air and down the road. A little more for bigger, wider and a little less for shorter, narrower. Some engine/transmission combo's are a little bit more efficient than others and, of course, diesel has more btu's per gallon than gasoline.
Still, it takes more or less the same energy. So, if you surveyed all who tow, I'd be willing to bet that, long term and on average, most of us driving gassers are averaging 10-12 miles per gallon.
If you budget for that, you will seldom be cast into despair and may occasionally be delightfully surprised.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-17-2015, 05:03 AM   #26
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Our 5.7L Dodge does real well at 13.8 to 14mpg running flat ground with no or little wind at 60 pulling our Overlander.. But throw a 25mph corner wind at us and push it up to 68mph it can drop down to 11mpg in a heart beat..
Now here is my beef.. We have a well worn out (800.000 miles) 94 KW semi,, pulling a 42 foot grain trailer.. Several years ago I was pulling dry fertilizer out of Tulsa Ok.. 79,500 lbs total weight.. It was a nice day with little traffic. I just idled along at 50 to 58mph and made a 550 mile trip at 9.8mpg.. Never let the turbo boost go over 10lbs and roller coasted the hills as much as possible. I understand we are not matching up apples to apples but that rig is huge in relation to our A$..
By relation to profile and weight,, our TV should see 28mpg all the time..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 03-17-2015, 06:13 AM   #27
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
Sodbust
Thanks for the input , I presume you have one of those conventional KW tractors with the sloped nose front end . When those first showed up I thought they were terribly ugly , but after driving a few of em and comparing them to the old 68 cab over KW with a 335 Cummins inline 6 and a 13 spd I broke out in , that ugly front end does help with wind resistance . The old 335 would get about 5 mpg in the mountains of Wyoming and Utah pulling a float and grossing a bit less than 80,000 . And would hardly do any better running empty !
Much the same for our Dodge 2500 with a 5.9 Cummins inline 6 with a 5 spd overdrive on the back of it . It gets 14 to 15 mpg pulling the AS with all the usual stuff loaded and fresh water tanks full . And only a couple of miles better running unhitched with no load at all.
Weight has much less of an impact on the MPG of a long stroke high compression diesel engine with a manual transmission than it does on a low compression , short stroke , gasoline engine coupled to an automatic transmission .
We used to pull the 66 AS with a 1971 International Travelall with a 393 V-8 coupled to a Chrysler 727 slush box with a 4.10 rear end , back when the speed limit was 55 nationwide and got between 5 to 8 MPG.
All these modern computer controlled gadgets that are on newer engines have defiantly helped with the mileage and power , but at the heart of the engine is still a low compression reciprocating piston gasoline engine .
Old 03-17-2015, 07:45 AM   #28
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Here is my approximate experience, 08 Silverado 5.3L, neutral wind, etc.
60 MPH 11 to 12 MPG
65 MPH 10 to 11 MPG
70 MPH 9 to 10 MPG
75 MPH 8 to 9 MPG
My other TV 04 Tahoe 5.3, is the same less about 1/2 MPG.
Driving habits come into play a lot. I try to hold my travel gear with minimal downshifting, modern cruise control sucks while traveling in hilly terrain, it drives me nuts and wastes gas.
My goal is to NEVER allow a downshift above 70, the cruise sucks at that.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Fuel Consumption - Honda Generators Ramblinboy Electrical - Systems, Generators, Batteries & Solar 4 09-05-2014 10:29 AM
Southern Cal is on FIRE!!! Plz help if you Can.... Tim Can Our Community 5 11-04-2007 05:09 PM
My F150 Fuel consumption data MG911 Tow Vehicles 19 10-20-2007 10:20 AM
Poll: FUEL CONSUMPTION brunoffrance On The Road... 32 02-29-2004 04:37 PM
Fuel Consumption: (curious) Drew Tow Vehicles 15 12-26-2002 06:28 PM
