Old 06-25-2010, 03:42 PM   #1
SSChanger's Avatar
Louisville , United States
Duramax Diesel Problem:15 mph on a Hill...
It's a fairly hot day here in Huntsville, Alabama, and our 2003 Chevy Duramax with the 6.6L Diesel/Allison Transmission took me to work and back with no problems earlier in the morning.
Hitched up the Airstream [30' '94 Execella ~8500lbs.] and headed up Governor's Drive to the excellent Monte Sano State Park. All went well on the freeway to Governors, then problems started on the hill.
Usually march right up the hill (it's a fairly steep incline), but could only get to 45mph--first time that's happened. Then on Monte Sano, dropped to 2K rpm and only about 15 mph. All gauges were within range. Half way up the hill, the "check engine" aka "OBD" light came on. Limped into the camp, dropped off the AS, and on the way back down the mountain, it's like nothing was wrong--The truck was right back to being delightful again.
What's up with that? Any ideas? Tranny too hot? Will it be this way in hot weather on inclines? Thought I was invincible with the big diesel, but guess not!
Thanks for your ideas and for reading this!
SSChanger
'94 Excella 1000; '03 Silverado 2500HD
Louisville, Tennessee
SSChanger is offline   Reply With Quote
Old 06-25-2010, 04:01 PM   #2
tpi
Trabuco Canyon , California
If the check light came on it should have set a code. Check that for a clue.
A wild guess fuel filter clogged.
tpi is offline   Reply With Quote
Old 06-25-2010, 04:07 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Had similar problem once towing with my gas truck. Baffles in the tailpipe had clogged with particles from the muffler causing huge back pressure problem. You may want to check the exhaust for flow.
Old 06-25-2010, 04:09 PM   #4
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
SSChanger.....You may be better off posting this inquiry on the Diesel Place Forum that is dedicated to the Chevy's & GMC's with the Duramax.Diesel Place - Duramax Diesel Discussion Forums
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 06-25-2010, 05:20 PM   #5
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Duramax
Possibly a dirty fuel filter. These need to be changed about every 7000-8000 miles. The symptoms sound very similar. This is an area where you should not go on the cheap for the filter. The better filters will work much better. You can go to the Duramax forum for the best method to replace these filters or simply go to your local Chevy dealer.
fltlevel510 is offline   Reply With Quote
Old 06-25-2010, 05:58 PM   #6
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
I agree with the probability of a problem with the fuel filter. I had the same problem with my 2004 (down from 30 mph to 10 with my foot all the way to the floor) going through Yellowstone. Stopped several times, restarted and ran OK for a short while and then the same thing. At the dealership they confirmed the Duramax has a system to not completely shut the engine down but restrict the speed, etc if the fuel filter is plugged.
I believe the newer Duramax's indicate when a fuel filter needs to be replaced. Ours do not and I bought a special gauge from Kennedy Diesel (plus spare fuel filters, oil filters and a OBD device) which should tell me when to change the fuel filter and not simply based on how many miles since the last change.
If you want any other details send me a PM.
Cheers,
Don
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Old 06-25-2010, 06:34 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
only takes ONE bad tank of dirty diesel to clog a filter.
BTDT....mine was a dirty filter when it happened to me.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-25-2010, 07:42 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I think I have to agree with previous posters. First place to go,FUEL FILTER . You may need to stay away from MOM&POP gas stations that sell fuel. Try always to deal with high profile diesel suppliers,in others words,those who TURN alot of fuel. Truck stops are the best places. Becareful when changing the filter,try to catch as much of the fuel comming out of the old fiter as U can and let it settle is something clear plastic,such as a clear peanut butter jar or old glass pie plate. You should be able to see the water in the fuel.
When I first got the 7.3 ,I went thru $100 worth of fuel filters the first week and $20 worth of fuel treatment, I was the second owner and I bought a LEMON.thru FORD(lemon law vehicle). Funny Ford dealers never fixed the problem or even found it. Now at 80K I have never had a problem since.
GOOD LUCK TO YOU,
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 06-25-2010, 08:12 PM   #9
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
I may reveal my ignorance of the Duramax, but if it is anything like my Dodge it has neoprene connections on the metal air supply tube that goes from the turbo to the intercooler. If one of those is not installed correctly, has slipped off, or has damage it will cause severe loss of power. Couldn't hurt to pull an inspection.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 06-26-2010, 04:32 AM   #10
1978 28' Ambassador
Savannah , Georgia
Driving a friend's '97 Chevy diesel. Lost all power, engine light, etc. Had it towed to a dealer. No codes. Said the problem was that I let the fuel get below a quarter of a tank. Confused why service engine light came on and then no code. An expensive lesson. Was buying fuel at Mom and Pop, but after reading this forum I will be buying at truck stops. Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 06-26-2010, 09:22 AM   #11
SSChanger's Avatar
Bingo! It was the fuel filter, and we're back in business. What I learned is that when the rig starts to show a bit of hesitation in shifting under non-towing hard acceleration, that's a clue. Last fuel filter change was 10K miles ago, and may've gotten some heavy sediment.
Thanks to all of you for your counsel--you nailed it!
Dennis
SSChanger
Old 06-26-2010, 10:55 AM   #12
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
The same thing happened to me a week ago. Mine set a code that it was a turbo over boost, I have gauges but the tech said it happens so fast that unless you are looking at the gauge when it happens you don't see it. Haven't had it happen again.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-26-2010, 10:57 AM   #13
1979 30' Argosy
Oh well, started this a couple hours ago and got distracted by company and just got back to finish. Glad you got it solved.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
GM postpones 4.5L Duramax Diesel Silvertwinkie Tow Vehicles 26 03-16-2009 06:02 AM
chevy duramax Tom-Mc Tow Vehicles 22 02-06-2009 09:28 AM
GM's New Duramax Diesel Engine Streamer1 Tow Vehicles 6 01-14-2008 11:20 AM
GM Engineers Design NEW 4.5L Duramax Turbo Diesel V8 Streamer1 Tow Vehicles 4 09-28-2007 10:24 AM
