Old 09-03-2011, 12:19 PM   #141
dznf0g's Avatar
Oswego , Illinois
Originally Posted by fltlevel510 View Post
I have a 2005 silverado 3500 with the Duramax and Allison 6 speed transmission and have been getting over 50 mpg while towing. As others have said the secret is RPM. By adding the Eaton 2 speed differential and using a blend of jet fuel, water and acetone it is not uncommon to get these superior results. Additionally, water vapor creates absolutely beautiful contrails behind the airstream. My next mod is to add a duel exhaust system in an attempt to create a dual contrail. My only problem has been towing at speeds over 100mph I get an overtemp warning from my tire pressure monitoring system and stopping distances have increased substantially.
Disclaimer: All data was collected with a vehicle equipped new tires, new brakes, a recent wax job and production test pilot at the controls. Your actual results may vary
LOOK OUT!!!! there's a bunch of trees in front of you! PULL UP!!!!! PULL UP!
Old 09-03-2011, 11:55 PM   #142
2008 28' Safari SE
San Luis Obispo , California
It has been very educational for me to read the various hints about mileage that various AS owners have given since I started the thread. Thanks. I pull a 2008 28 footer with my 2008 Silverado 2500 HD 4x4 diesel. I reported that I get 12.4 mpg. I do not have a cover on the bed nor a cap. Would those increase the mileage?
flyingfinn is offline   Reply With Quote
Old 09-04-2011, 06:59 AM   #143
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
I don't think so.
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 09-04-2011, 07:09 AM   #144
dznf0g's Avatar
Oswego , Illinois
Not by much at all. Trucks are designed to create a bubble of air which sort of "stagnates" and rolls slowly in the bed area. If you drew an imaginary curve from the roof to the top of the tailgate, that is the shape of the bubble. That's why you'll find very small shape features on many trucks, like the bed a bit narrower at the tail than the front, little "spoiler lips on some, etc. A Topper creates a flat suction surface at the back. A Toneau cover probably neither helps nor hurts. Some believe that a fifth wheel ventilated gate actually hurts.
All these things affect mileage so little that you probably couldn't significantly measure it with bigger variables in play, and certainly would not be the sole reason to purchase.
Old 09-16-2011, 08:08 AM   #145
SteveH's Avatar
Common Sense , Texas
I have a camper cover on my GMC, and it certainly does not help mileage. My "gut feeling" is while towing it doesn't hurt mileage, but while driving solo, I think it does hurt the mileage slightly. This I have reasoned by comparing what others report, however others report they drive 60-65 MPH. I typically drive faster. I know if I drive under about 62, my truck does not go into 6th gear while in the tow/haul mode.
Regards,
Steve
Old 09-16-2011, 11:01 AM   #146
dznf0g's Avatar
Oswego , Illinois
I would agree with this analysis.
Old 09-16-2011, 11:20 AM   #147
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A topper only "works" when it follows the lines of the truck very closely. In which case the single "flat wall" at the far rear of the truck trumps the aero problem of two shorter "walls" (cab to bed & bed to tailgate). But a hard bed cover seems better overall, especially as crosswind sail area is reduced in comparison.
An "aero" bed topper is best of all (along a 12-degree drop from cab roof to tailgate).
Old 09-25-2011, 10:10 PM   #148
Western slope , Colorado
"Old" Duramax, Grand Junction-Lake Michigan and back
Thought I would post this trip we just came back from. Not great but not bad either.
2002 GMC Duramax (now has 206021 miles) CC, SB, Lear camper, EU3000IS
2001 70th Anniversary Slide-out 30Ft(actually 31 but who's counting)
ProPride Hitch, Sendel wheels w/ 235 75 16's Michelin E rated @75psi
trailer loaded and with a full tank of fresh water---
Steering axle-3910lbs(98% restored), Drive axle 4110lbs, Trailer axles 8160lbs (8 tons rolling, Trailer with hitch at 9140lbs---40 lbs over)
Starting Altitude---4600ft, max altitude on trip (Eisenhower/Johnson tunnel @11,158 ft, ending altitude at lake michigan 581ft
Mostly driven at around 65 but topped the continental divide tunnels AT THE SPEED LIMIT---maybe just a little over just because I could.
Miles driven 2664.6 (odometer)
Fuel consumed 209.33 gallons(US) (Receipts)
MPG 12.73
BTW... If anyone finds my "stinky slinky" on the side of the road between Denver and North Platte.......
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
Towing 2011 Classic 34 With Chev Duramax RV Doctor Tow Vehicles 13 04-17-2011 10:21 PM
93 chevy G10 van v8 305 CampNoob Tow Vehicles 7 01-21-2011 08:47 PM
