Old 12-20-2008, 01:10 PM   #1
holden beach , North Carolina
Send a message via MSN to Tom-Mc
chevy duramax
What is your fuel mpg? How is the ride and how well does it pull your AS? What are the best years for mpg and repairs?
Tom-Mc is offline   Reply With Quote
Old 12-20-2008, 01:27 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I have a 2003 (LB7 engine) Around town and to and from work I get about 20MPG. That will drop to 14MPG if I do anything but Grandpa around.
Towing I get 14.5MPG with a 7000lbs trailer and 14.7 with a 3000lbs trailer.
It all depends on how hard you want to drive it. Worst mileage ever 11MPG uphill against the wind driving like a bat out of hell.
These things are fast and fun, so watch it.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-20-2008, 01:30 PM   #3
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I have an '06. Around town I get 17.5. Highway only around 19. Towing our '90 34' Excella we averaged 13. It is the best truck I have ever owned, period.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 12-20-2008, 01:49 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
We got our '06 Sierra in September '05 -- just before they switched the slider cab temp adjustments and not the set your digital temp (of course we have very little season without needing the heater). But no side air bags either. My Duramax is 3rd generation LBZ build and is not required to use ULSD -- it can still use the 200ppm and I haven't had to pay much attention. 4th generations have 2-stage turbos (good idea I think) and must use the ULSD. 3rd generation was another step in the mistaken GMC build-'em-bigger philosophy -- they ramped up to 330 hp from 300 hp (for 2nd gen). I think 1st gen was only 270 hp, which would have been plenty
Mileage? With my honkin' big engine I don't see the famous diesel economy. But moreso it depends how big a hurry I'm in. I can't stay below 60 on long trips. The best mileage towing I've gotten was 14.7 on a 120 mile leg between home & Duluth, MN -- impacting variables were that I had empty water/waste tanks, went no faster than 55mph, a modest number of medium hills only, I went up hills without increasing throttle (accepted a 5-7 mph dropoff), didn't use cruise control (the most important factor ever!). I haven't seen much for mileage effects from using the air conditioner. I usually get right around 13mpg while towing at mixed speeds while not going faster than 65mph. Cruise control is good for a 1 to 1.5 mpg drop -- a convenience but one I've learned to do without.
Lotta variables? Of course. The driver is probably the biggest. I'm happy and feel set for the long run ... ask me in 150,000 miles. Of course I'd be happy to get many miles more than 200K from it.
Look in at dieselplace.com for any variety of discussions. Let us know what you settle on!
[on edit: ohh ... and it's quiet and really a pretty fair ride in the 3/4 ton. Only a bit busy ride but much better capacity than the slightly cushy ride Nissan Titan I used to have.]
5 meter Langford Nahanni
Old 12-20-2008, 02:24 PM   #5
Woops - on further review that best trip at no more than 55 was 15.7 mpg. I can drive less nutsy on 2 lane highways letting it edge toward 60 and still get in the high fourteens. A lot of time spent at town speeds will knock your mileage right down!
Old 12-20-2008, 02:32 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
My 2003 LB7 gets around 16 around town and 18-19 freeway. I have seen as high as 21 freeway. I get around 15 towing the A/S.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-20-2008, 02:39 PM   #7
dbradhstream's Avatar
2006 28' Safari SE
Winter Park , Florida
I LOVE my truck! '08 Duramax. Pulls like a freight train. Unloaded, highway mileage is 19. Unloaded, in stop and go city traffic (it's my everyday driver) is between 13-14. Loaded, towing at about 70-74 mph is about 11.
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Old 12-20-2008, 05:37 PM   #8
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Duramax/Alison
I have an 2006 (fully loaded) and with the exception of the drive train the rest of the truck has been nothing but one problem after another. Everything from the overhead console falling out while driving down the road, while towing my AS, to the tow-haul mode switch on the shift lever failing (replacement of the switch required reprogramming of the tranny on the second visit for this problem). All this happened within the first couple thousand miles. The dealership was the worst. They could not even reset the oil/fuel filters to zero on the display, not once, but three times after oil/filter changes. All of the rubber around the doors have been replaced about four months from driving it off the lot. Head light assembly fell-out, seems it was wedged in the opening while it was coming down the assembly line (mounting tabs had been broken off). And another thing, the whole dash had to be removed to reinstall the On-star and cell phone units because they worked intermittently. Seems that when they fixed that, the huge rattle in the dash stopped. Buy the way the engine/tranny combo works great and tows my AS like a dream. The list of why I should rid myself of this truck continues to grow. After owning 7 new Ford trucks with only two minor warranty problems, I purchased the truck to support family member who work as GM.
tsunami is offline   Reply With Quote
Old 12-20-2008, 05:47 PM   #9
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
2002 LB7 gets 17-18 in town...up to 22 hwy...and usually 12 towing 31' Excella loaded @ 65-70 mph.
Injectors rebuilt @ 80,000 miles under warranty. currently 162,000 miles and all is well so far. water pump failure at 160,000 miles and an antifreeze leak at the oil pump O-ring fitting at 145,000 miles.
There is NO comparison to towing with the duramax and a gasser. I do not intend to EVER buy another gasser. Diesel is KING.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 12-20-2008, 05:50 PM   #10
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Pretty good truck. It gets 13-15 towing the 27 Safari. Diesel 4 WD and pulls very strong. Mine is an '05 with a bad instrument cluster. GM is arguing about replacing it. It is the same cluster that they replaced in all of the '03s and '04s. I have had a Ford and now this GM...when I buy another I will go back to the Ford. Maybe not quite as comfortable, but stronger, and the service and warranty support is better.
Living life on the Road
deauxrite is offline   Reply With Quote
Old 12-20-2008, 05:58 PM   #11
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Mine's an '08 Crew Cab, 4wd, standard bed. Rides o.k. - for a 3/4 tonner - but it's sure not as comfortable as my old Suburban. Gets busy on choppy roads, no question. Pulls like a locomotive; you don't need that much torque for my little trailer, but it is very nice when passing going uphill, etc. Mileage: unloaded, 20+ on Interstates, at the speed limit ... drops off fast above that. 13.7-14.8 towing a 23' Safari mostly AT 65 mph ... depending on wind, hills, etc. In town, no idea - I try not to do that ... not it's ideal mission profile. No regrets so far, no warranty issues at all. I wanted to buy a F250, but its new "big truck" stance makes it too tall to fit through a standard garage door into my garage, while the 2500 is several inches shy of the top of the door opening. Ford had a better idea! Not.
AirsDream is offline   Reply With Quote
Old 12-20-2008, 07:12 PM   #12
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Duramax
My two previous p/u trucks were Ford and had no problems except ford service and warranty was terrible. Purchased the one ton 2005 Chevy and the Duramax/Allison combination is great. Seems like the Ford interiors were nicer but we have really enjoyed the Chevy. When not towing usually 20mpg, when towing in fairly flat terrain we get 15mpg. We usually carry a lot of supplies in the bed of the truck and the 30' Classic s/o is heavy to begin with so our ride is very smooth.
fltlevel510 is offline   Reply With Quote
Old 12-20-2008, 08:20 PM   #13
1994 30' Excella
2012 25' FB International
Anchorage , Alaska
Just thougt I'd add my 2 cents worth. I just traded my 03' Duramax extended cab (55,000 miles) off this AM for a new Tundra. My Duramax was an awesome vehicle, but for me it was way too much truck for my needs. I had done a few mods to the truck that I think enhanced its fuel mileage. First, I went with larger diameter tires, which in turn raised the rear end ratio higher than the standard 3.73 ring. Second, I added a Bully Dog power enhancer which really made an already nice vehicle much, much better. When I checked my average fuel mileage earlier this morning, it still showed 18.9 miles per gallon. This is usually about what I get, or at times even better. The 19 mpg. figure is for relatively short jaunts (15-20) miles back and forth to work. Also, take in mind that we've had a fairly cold winter here, which also takes away from the mpg. So why did I trade it off? Because I'm positive that the 7/8 ton chassis is way too much for pulling our 30 foot around with. Could never have enough tongue weight to where the suspension is even beginning to work.. Also, am tired of being cold and paying the extra added price to own a Duramax... Plus, I'm scared of how much it's going to cost when I really do start having problems with the truck (our local Chevy dealers all "suck")...Hope this info helps... In closing, just like any vehicle, the harder you are with the "go" pedal, the lower fuel mileage you're going to get....
bpcaudill is offline   Reply With Quote
Old 12-20-2008, 10:31 PM   #14
catson4's Avatar
1991 34' Limited
Port Orchard , Washington
Thumbs up 2007 Duramax
My Chevy is a 2007 HD 2500 EXT cab w/6.5' box. 4x4 w/Duramax & 6 speed Allison. The Allison includes the tow mode as well as the "Manual Mode". The manual mode allows you to shift gears up or down as you choose, not when the truck wants you to. Great for hills, whether going up or down.
I am averaging: Freeway, empty...rite on 23.5 to 24 if I stray at 60 mph at 65 the mph will drop off to 22.5 and at 70 down to 21.
In town, empty... about 17.5
Back and forth to work, a combination of freeway and town, 20 mpg for a 65 mile run round trip.
Towing my 34' Classic Limited , 8900 pounds loaded, freeway 14.5 to 15.5 at 60 mph
On th Oregon & Washington Coast and in the mountain roads the mph will drop down to 12 or 13 but that is because of the "on the throttle / off the throttle" action caused by other traffic and hills and curves. Believe me I do not hold up traffic, but I drive very safely.
This truck gives me all the power I want or will ever need for that matter.
Each rig has it's high points. Some say the interior of a Ford is better, I don't think so, some say the Dodge is tougher looking ( not me) and some , like me, want the convenience of the manual trany and NO CLUTCH.
I used to drive big rigs and believe me this no clutch is great.
I started driving semi's back in the dark ages ( read 1957) with a 220 hp Cummings diesel, NO TURBO, 5 speed main box, 4 speed Brownie (auxiliary trans) and a "Duplex Splitter" ( 2 speed third trans.) That is a total of 3 gear shift levers coming up thru the floor, that at times had to be ALL shifted at the same time..
That gave 40 gears go ahead. That is how they made a 220 HP motor pull then what they pull today with 550 and 600 HP and a 6 speed Allison.
So you will find every one has a different take on all these tow vehicles.
Me, I'll stick to my Chevy.
Oh, and the manual mode is GREAT in the SNOW like we have right now.
JMHO
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Duramax Pop Rivet Classic Motorhomes 17 08-22-2006 01:51 PM
Duramax Suburban! Pick Tow Vehicles 14 05-22-2006 12:17 PM
DuraMax Info Over59 Tow Vehicles 17 08-06-2005 09:31 PM
Help! Duramax vs. Quadrasteer Hit'the'road Tow Vehicles 24 10-14-2004 05:03 PM
Duramax=Trouble ???? Silvertwinkie Tow Vehicles 37 08-10-2004 04:45 AM
