Old 09-27-2016, 05:43 PM   #15
Free bird's Avatar
2016 22' Sport
Grayslake , Illinois
I had the same dream. I bought a 2016 Colorado and a 22 ft airstream. It weighs only 3600 lbs without water. I keep it unloaded to try to save on the drag. I pulls fine in the midwest. I have been afraid to venture into the mountains though because I feel I do not have enough power.
Free bird is offline   Reply With Quote
Old 09-27-2016, 07:50 PM   #16
Sonoma Co. , California
Chevy Colorado Max Trailer size?
Any V6-powered truck is going to have plenty of power to tow a tandem axle 21-23 ft trailer. Another relative of mine pulls a 22 ft trailer (not an AS) into the mountains with a Tacoma just like problem. For years I regularly towed a utility trailer loaded with 2000-2500 lbs of materials using a Toyota Tundra that had the same V6 as my Tacoma. Lack of power was never an issue, either on steep winding hill roads or the freeway. I prefer the Tacoma because of its sturdier frame/springs, but I'm sure load levelers would give the Chevy equally good handling.
USAtraveler is offline   Reply With Quote
Old 09-27-2016, 08:00 PM   #17
2017 30' International
Lincolnwood , Illinois
Originally Posted by AWCHIEF View Post
I looked at the Colorado and its GMC version and decided it was not adequate for safely and comfortably pulling my 23 or if I move up in size. I did not think it had enough capacity or power for the hills with any engine available. Shame, I do like the size compared to the full size 150 that I had prior to getting the JGC.
do you have the diesel and if so how do you think it would pull a 25 FC front bedroom
Milo1952 is online now   Reply With Quote
Old 09-27-2016, 08:52 PM   #18
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
2011 JGC Overland with 5.7 Hemi V-8. Below 3000 ft it pulls my 23 comfortably. Above 3000 ft it gets anemic quickly and gas mileage drops like a rock. From what I have read and talked to other JGC diesel owners that is not an issue with the current diesel JGC. I can not speak of its ability to tow a 25 as I have never towed one. I have once again been looking at pickups because I hope to be going full time in the near future and need more on the road storage. If I win the lottery I would like to move up to the 26U.
Old 09-27-2016, 08:55 PM   #19
1979 23' Safari
Wayland , New York
Depends on the year of the trailer. The older 70's trailers were lighter than today's models. 23' is probably safe for any year, 25' might be pushing it close for recent models.
I had a Dakota 8 cylinder, towed my 23' well. When shopping for new truck I really wanted a mid size, obviously there are limited options. Decided the trade off of going up to a f150 was worth it. Very glad I did. No worries, great towing power. Better mileage than my old less powerful 8 cylinder.
Old 09-28-2016, 07:46 AM   #20
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
The rear end gear ratio in that or any truck will play a roll in what you buy. Don't just assume the max posted on the internet is the same for all trucks. Also look at hitch weight and payload. I think the truck is too small unless you're going 23' or less.
Ronman is offline   Reply With Quote
Old 09-28-2016, 08:03 AM   #21
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I tow a 30' that's 6,500 lbs dry with a F150 rated to tow 7,700 lbs, so I know about bucking up against the limit. But that's only because it's the truck I had when I bought the trailer. I travel light and it works fine for now. I will be upgrading before I do more serious adventures.
You are starting from scratch. Why put yourself against the limits of your tow vehicle?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 09-28-2016, 09:53 AM   #22
2012 23' FB Flying Cloud
Havertown , Pennsylvania
Hi , (Schafman ) here--I have a 2015 GMC Canyon , which is sister truck , supposedly from similar production line. --I pull a 2012 Flying Cloud , 24' FB WITHOUT A PROBLEM & get 15mpg on 2 trips --one around US 14,000 miles & one 5,000miles to Canadian Maritimes.--I can pull up to 7,000 lbs. my AS is 4800 dry plus 1,000 for clothing, water & propane & am still under the 7,000. --Goid Luck with ur decision. @ welcome to the forum!!😍
schafman46 is offline   Reply With Quote
Report on Chevy/GMC 1500 with 6.2 engine and Max tow pack DC Bruce Tow Vehicles 324 12-20-2017 12:29 AM
Max Trailer size for a Chevy Colorado? Grimmster Towing, Tow Vehicles & Hitches 2 09-27-2016 01:48 PM
2014 Chevy/GMC 1500 6.2L + max tow? DC Bruce Tow Vehicles 87 02-11-2015 07:17 PM
