Old 08-02-2008, 06:55 PM   #1
Profile:  2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
Chevy 2500hd Silverado worth it's salt?
Any advice on this as a tow vehicle for a 27FB? The rearend is a 4.1...but it's a gasser--not Diesel. Found an 04 with only 64k miles...nervous that it's not Diesel...any thots?
stowaways is offline   Reply With Quote
Old 08-02-2008, 07:06 PM   #2
2airishuman's Avatar
Profile:
Originally Posted by stowaways View Post
l...any thots?
in terms of capacity it should work...
but beyond the used truck selling price,
consider the COST of the add onz u will need...
-a better receiver
-towing mirrors
-brake controller
while a lightly used f-250 powerstroke from 05-07 will be READY to tow
equipped with an integrated brake controller, great mirrors and a solid factory receiver.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 08-02-2008, 07:24 PM   #3
ZoominC6's Avatar
Profile:  2004 30' Classic Slideout
Blacksburg (College Town USA) , Virginia
Nice towing truck especially with the 4:11 rear end BUT you had best own an oil well or three as that baby won't want to pass up the EXXON station. I speak from experience. Having said all that, my Duramax isn't exactly cheap to fill up either. I'd look for a 3:73 rear end if you want a gasser, check the towing capacity and go for it if it all fits. Best of luck to ya.
HAPPY TRAILS
HAPPY TRAILS ONE AND ALL
ZoominC6 is offline   Reply With Quote
Old 08-02-2008, 07:31 PM   #4
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
You didn't mention engine size. The 6.0 litre engine performs better with the 4.10 rear end ratio because it loves to rev. I have the 8.1 litre engine with 3.73 rear end ratio and I love it. If you are worried about the 4.10 rear end then go up one size in tires to a LT265-75-16.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-02-2008, 08:14 PM   #5
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
That truck, with the 4.10 rear, will pull 2 or 3 of anything AirStream ever made...
Bill (nuthin but GM's) Tex
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
BillTex is offline   Reply With Quote
Old 08-02-2008, 08:16 PM   #6
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Seriously, that truck is more than enough for a 27 footer.....you won't be disappointed.
Old 08-02-2008, 09:30 PM   #7
1969 31' Sovereign
Ft. Worth , Texas
Thanks so much for the feedback...we really apprecite it. We're signing the papers on Monday. You guys are the best!
Old 08-02-2008, 10:00 PM   #8
Aluminut
Glad to hear it..friends don't let friends drive Fords.
Old 08-02-2008, 11:50 PM   #9
full-timer
DreamStreamr's Avatar
Profile:  2005 25' International CCD
Everywhere , North America
Images: 42
Stowaways,
Echoing and adding: We have 30,000 miles on our 2006 2500HD with 8.1L engine, 3.73 rear, and Allison 6spd transmission. This setup tows at the legal limit on every road we encounter. Why would I need more?
We spent $45 on CIPA tow mirror extensions which snap on very snugly and simply. We are using the factory receiver and keep a close eye on it. We average 10mpg overall and did not like a 260 mile range so changed to a 45 gallon gas tank. 4,000 miles later we still love the fuel tank conversion.
We are sooo glad we have the gas engine. We love our friends who tow with diesels, but their towvees are noisy, stinky, expensive to purchase, expensive to operate, and are noisy and stinky. Did I say the diesels are loud and smell when they land in the rv park and are idling? Some day we may regret we aren't towing with a diesel. Probably about the same time Exxon gets a conscience and starts charging fifteen percent less for diesel than for gasoline.
Jim N5RTG & Deb KI4OKI
WBCCI #4822 / WBCCI ARC/ RV SVC Network
Escapees full-timing in our CCD 25 blue streak
sometimes seen behind the magnificent 2500HD 8.1L/Allison 6spd 3.73
visit us at http://dreamstreamr.com
DreamStreamr is offline   Reply With Quote
Old 08-03-2008, 01:38 AM   #10
Profile:  1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
You didn't mention engine. The 6.0 needs the 4.11 rear, the 8.1 would be fine with the 3.73. The 4.11 puts you on the right side of power to the wheels when pulling heavy. You can get on the gas a little bit and the truck will respond without downshifting. Minimal lugging down in OD.
I would not want to pull with a 6.0 and a 3.73 rear.
I have a 2003 2500hd, 6.0 eng, 4.11 rear, extended cab. It has been one very good truck at 45,000 miles.
The 2500hd is a "truck". It gets 12 mpg around town and nearly the same pulling my 29'. This year on the caravan, I was matching the diesels on cost per mile with diesel at $4.75 per gallon.
Only problem with this truck is the small gas tank on the short bed trucks.
I try to never use the last qtr tank to keep the fuel pump cool.
They do have a few small mechanical problems which you could read about on www.chevytalk.com.
wingfoot321 is offline   Reply With Quote
Old 08-03-2008, 07:04 AM   #11
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I've got a 2500HD with the Duramax. You will love the truck. I have 4 years and 56K on mine. Been to the dealer twice, both recalls, on tailgate straps and fuel filter. I do all my own servicing.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 08-03-2008, 12:23 PM   #12
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
you will not be disappointed with the trucks performance.
mine has given 8 years of excellent service.
john
you call them ferrets, i call them weasels.
john hd is online now   Reply With Quote
Old 08-03-2008, 01:12 PM   #13
many cheeses are edible
RedSHED's Avatar
Profile:  1985 31' Excella
Columbus , Indiana
Originally Posted by wingfoot321 View Post
You didn't mention engine. The 6.0 needs the 4.11 rear,... You can get on the gas a little bit and the truck will respond without downshifting. Minimal lugging down in OD.
Lots of different opinions on this, I think. We tow a 1985 31' with an '03 1500HD, 6.0L 3.73 and think we might actually be a little over-trucked - almost never do we have the thing wide open. I'm not complaining, mind you. I don't mind downshifting; I paid for a 4 speed transmission and will feel cheated if I don't get to use them all.
Worst tank towing was 9.9 mpg; best was around 12.9. We seem to be averaging around 11.0 towing.
Depending on age & equipment, this might be pretty similar weight-wise to a 27' trailer.
Coincidentally, the guy next to us this weekend tows a 27' A/S with a 1500 & a 5.3 (as did the previous owner of ours). I don't think he drag races it in that configuration, but he's basically satisfied with it.
I don't think you mentioned the most important thing: what color is it?
RedSHED is offline   Reply With Quote
Old 08-03-2008, 07:42 PM   #14
1969 31' Sovereign
Ft. Worth , Texas
Red...It's shiny white with tan leather! Appears to be a one owner and in great condition. I believe it's a 4.11 rear with a 6.0. After reading a few other posts on the factory receiver, may need to give it a second look. Might consider the extra fuel tank as well---because you know when you left off on the gas---the dogs suddenly have to pee. ; )
GMC 2500HD Owners Beware. boatdoc Hitches 47 08-22-2008 05:23 PM
Towing capacity of a Chevy Silverado 1500 luca_brasi Hitches 11 10-03-2007 10:07 PM
GMC 2500HD Query gowyn Tow Vehicles 6 09-21-2007 11:53 PM
Hensley and 2500hd davidz71 Hitches 4 03-24-2005 09:57 PM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 06:41 AM
