Old 11-26-2009, 09:24 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Chevy 1500 TV for Ambassador
Can I temporarily use my 1500 stepside Chevy as the TV for a 1965 Ambassador 28 ft. I am buying next week.
My brother is towing it 6 hrs.for me with his big diesel,but after that I am on my own.
It is a one owner very well maintained 180,000 miles small V8.auto.
Not sure of final drive.I have towed a Uhaul 16 ft fully loaded around town recently with ease.
I will be renovating when I get it and getting all systems up to speed
I will not be towing in the mountains and trips not over 400 miles for the time being.I will at least add a trans cooler and beefier shocks.
bwaysteve is offline   Reply With Quote
Old 11-26-2009, 10:57 AM   #2
1972 29' Ambassador
Fort McCoy , Florida
Images: 16
I towed my 1972 29 foot Ambassador with a 2000 Chevy Z71 with the 5.3 engine and 178,000 miles from Maine to Florida. I did have the braking system installed and made sure the AS trailer brakes worked. I also have new brakes, shocks and 10 ply tires. You should not have any problem-use the towing setting on your transmission
Mrwaterway is offline   Reply With Quote
Old 11-26-2009, 11:20 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You should be able to tow it ok,just make sure you have brakes and an equalizer hitch. I towed a 73 27' with a 5.3 ok,but when I went to a 77 27' it just didn`t have the ump, had to run in 3rd gear which really killed my mileage.Finally got a 2500 with a 6.0.
Dave
easyride is offline   Reply With Quote
Old 11-26-2009, 11:28 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
It's doable, as long as you are set up correctly. Adding a transmission fluid cooler would be a real good idea. A quality weight distribution/sway control hitch system is a must, along with a trailer brake controller. Also, load range D or E tires would be a real good idea.
Brian
SuEllyn & Brian McCabe
Old 11-26-2009, 11:40 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Found some weights for you in case you did not have them.
1965 AMBASSADOR 28 TWIN Dry Wt. 4140 Hitch Wt. 400 Hitch Ball Ht. 20.5
1965 AMBASSADOR 28 DOUBLE Dry Wt. 4140 Hitch Wt. 400 Hitch Ball Ht. 20.5
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-26-2009, 12:15 PM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Thanks for the specs Happy Thanksgiving
towing with a chevy 1500 leighmiller Tow Vehicles 11 05-09-2008 04:07 AM
Towing capacity of a Chevy Silverado 1500 luca_brasi Hitches, Couplers & Balls 11 10-03-2007 09:07 PM
Craigslist Find - $1500 Ambassador toddster 1959 - 1965 Ambassador 0 05-19-2006 11:54 AM
Avalanche 1500 ifly4cal Tow Vehicles 17 02-05-2006 11:26 AM
Suburban 1500 FiveGreers Tow Vehicles 20 01-23-2006 12:01 AM
