Old 01-20-2016, 06:20 PM   #1
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Chevrolet / GMC 6.0L Engine?
I'm considering our next (probably used) tow vehicle and will likely stay in the ranks of Chevrolet / GMC gasoline engine. In particular, the 6.0L.
Yes, I know there are lots of reasons to go with diesel and to consider other brands of tow vehicles but for this thread I'd like to stay on the topic of the 6.0L engine commonly available in 2010 (or so) model trucks and SUVs.
I currently tow with a 1996 GMC Suburban 7.4L and a 2005 Chevrolet Suburban 8.1L. Those engines are rated at 290 HP @ 4000 RPM / 410 LB-FT @ 3200 RPM and 320 HP @ 4200 RPM and 440 LB-FT @ 4200 RPM respectively. The 8.1L has noticeably more power than the 7.4L but it also has fewer miles on the engine. Both vehicles have a 4-speed automatic. I think these are great tow vehicles in large part due to the gobs of torque created by the big block engines. The transmissions downshift when going up a steep/long hills so the engine revs but I very seldom lose speed or have to limp up a hill at 45 MPH.
I may be off a little on the engine ratings but the numbers are in the right ballpark.
The later model trucks and SUVs with the 6.0L engine use the 6-speed transmission. The 6.0L engine produces 352 HP @ 5400 RPM / 382 LB-FT @ 4200 RPM
So anyone that has knowledge and experience with 6.0L I'd like to hear your comments. Some questions on my mind are...
1) The torque rating on the 6.0L engine concerns me. The 6.0L has 7% to 13% lower torque than my current tow vehicles.
2) Is it reasonable to think the 6-speed transmission will make up for lower torque? I can certainly imagine the 6-speed will have more suitable gear choices when tackling hills.
3) I've seen reference to cast-iron 6.0L engines and aluminum block 6.0L engines. I suspect the vehicles I'm considering - trucks and SUVs - will use the cast-iron but I'm not sure.
4) Later model trucks and SUVs I'm considering come equipped with the 3.73 differential. My current tow vehicles are 4.10 differentials. Any concerns with 3.73? I guess the manufacturer is going for higher MPG.
5) The 6.2L gasoline engine in the recent Denali line looks very comparable to the old 7.4L and 8.1L specifications. Is it worth holding out for a good, used vehicle with the 6.2L engine?
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 01-20-2016, 06:26 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I used to tow our 31 all over the country with a 6.0 Chevrolet. It had the 3.73 gears, and if you can find one with 4.10, it would be much better. I regularly towed our 7700 pound trailer over Cajon Pass in California at the speed limit for trailers, which is 55mph.
Old 01-20-2016, 06:58 PM   #3
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
Hi -- I towed a 23" Safari (actual weight loaded about 5,000 pounds) with a 2001 Denali with the 6.0 motor, 3.73 gears, and a four speed transmission. First tow was from Colorado, across Wyoming on 80, and down 15 to California.
For your reference, I disclose I am a higher-performance guy who does not begin to understand those who take pride in how little tow vehicle they can make work. Here are a few of my answers to your questions:
> Yes, the 6-speed transmission will make up for quite a bit of torque and horsepower difference
> The cast iron block was used in trucks and SUV's, the aluminum block was used in cars. Many hot rodders prefer the cast iron for the added strength.
> The 6.2 is a great motor too, and has more hp and torque.
In terms of advice I would certainly need to know the weight of your TT, and where you plan on going (e.g. the Rocky's vs. flatland). The other variable which only you can judge is how much performance is adequate for you?
For me: I supercharged the 6.0 and it now has about 500 hp and 500 torque. What hill?
field & stream is offline   Reply With Quote
Old 01-20-2016, 07:26 PM   #4
Tincampers's Avatar
Sneedville , Tennessee
We towed with a 6.0l and 4 speed transmission. 75% of the time it was fine. Add in any kind of incline and performance suffered. Add to that 9 mpg and I was ready for something better. We had the 4.10 gearing.
Tincampers is offline   Reply With Quote
Old 01-20-2016, 07:55 PM   #5
Tuco's Avatar
1988 32' Excella
Ojai , California
So your THAT guy on the 154...
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 01-20-2016, 08:01 PM   #6
2008 23' Safari SE
2007 Base Camp
Hi Ojai -- you mean that flat road between Santa Ynez and Santa Barbara?
Old 01-20-2016, 10:40 PM   #7
Tuco's Avatar
1988 32' Excella
Ojai , California
Yea, that flat stretch of road where the beast is flat out in 4th gear and 48 mph for the final climb to the top on the way to Rancho Oso off Paradise Rd. Need to get to the Longhorn Cafe for a good breakfast soon.
Dave & MJ
Old 01-21-2016, 07:34 AM   #8
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
The owner's manual for our 1992, 29ft. Classic indicates 5600 pound dry weight. We have lots of stuff and normally travel with nearly full 60 gallon fresh water tank for boondocking. I haven't taken time to weigh the rig as loaded but plan to do that soon. I imagine we're near 7000 pounds loaded.
As far as where we travel or plan to travel - everywhere. I certainly don't want to be limited by our engine and drivetrain.
I recently looked at a few web sites regarding supercharging. Tell me more about your setup - brand, ease of installation (I'm a DIY person when feasible), approximate cost, etc.
Thanks to everyone for your comments. Keep them coming.
Lucius and Danielle
Old 01-21-2016, 07:54 AM   #9
vintageracer's Avatar
1958 22' World Traveler
Nashville , Tennessee
If you are considering a USED gas motor truck and can handle 10-11 MPG ALL THE TIME loaded or unloaded look at a 2500 or 3500 Chevrolet/GMC truck equipped with the 8.1 liter engine and the Allison Automatic Transmission. Pulls like a diesel all the weight you want.
IF you can find one of the VERY RARE but out there and desirable 8.1 litre trucks equipped with the 6 speed MANUAL transmission you will get 11 MPG all the time.
REPEAT 10 MPG loaded or unloaded for the Allison automatic transmission truck and 11 MPG for the manual transmission 6 speed truck.
I have pulled many a mile in a 8.1 litre Allison Automatic Transmission equipped 2500 series 4WD Crew Cab Short Bed Single Rear Wheel Chevrolet PU with a 2 car tag trailer LOADED (10k-12k Lbs) running 80 MPH.
60 MPH or 80 MPH LOADED OR EMPTY the truck STILL got 10 MPG no matter how you drive it!
IF you can stand the fuel mileage you will have "NO WORRIES MATE" pulling your Airstream trailer or much of anything else for that matter!
vintageracer is offline   Reply With Quote
Old 01-21-2016, 08:08 AM   #10
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The 6.0 L truck with 3.73 gears will out pull your 454, and do so more efficiently.
My point of reference in making the declaratory statement is that my 5.3 L 3.73 truck will out pull any factory stock 454 made since 1978. I say this bluntly without equivocation.
Brevi tempore!
Old 01-21-2016, 08:15 AM   #11
2008 23' Safari SE
2007 Base Camp
Lucius - There are a couple of ways to go here.
The turnkey approach is to get a Callaway-modified pickup or Suburban from a Chevy dealer. Not cheap but quick, easy and full warranty from GM.
LINK: Callaway Silverado/Callaway Sierra
The way I went was to buy a complete supercharger/intercooler kit from Magnuson in Ventura CA. Because this project is over my head, I had a local hot rod shop (Bel Air Ranch) do the build starting with a new 6.0 long block from GM, which honors the warranty with the blower installed. Total cost, including complete tranny rebuild with HD parts, about $16K. Not cheap, but way cheaper than buying a new vehicle!
LINK: Magnuson Products, LLC
We have over 25,000 miles on this motor, the majority of which have been with one or another trailer attached. Zero problems. (Maybe because it is only about 6 pounds of boost, and maybe because we see it as a tow vehicle and not a race car and drive it conservatively.) No regrets, and would absolutely do it again.
Gas mileage is the same as without the blower. As the Magnuson guy told me, the only part of this system that can cause more fuel to be used is your right foot!
Old 01-21-2016, 08:30 AM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
After towing for many years with a half ton, I bought a brand new 2010 Silverado 2500 with the 6.0L. That is the only Chevy vehicle that I owned which disappointed me. The first time I went to the mountains I knew I made a mistake. Towing my 25' at ~6,000 lbs it struggled in the mountains going uphill. It did not have enough power. The problem is the 2500 is it is a much heavier truck than a 1500. The truck is towing that additional weight with basically the same engine as a half ton. I'm not sure of the exact weight difference, but it is substantial. To boot, my 6.0L was a gas hog, whether empty or towing.
I've had both the 5.3L and the 6.2L in half ton truck. No doubt the 6.2L is a more powerful engine, but the truck I own now has the 5.3L & 8 speed with the max tow package. I'm happy with it!
If I were going to buy a new truck today, I would get a half ton, maybe with the 6.2L.
My advice: If you can keep payload low enough, go with a half ton. If you need to haul more stuff, go with the three quarter ton.
Alan
Old 01-21-2016, 08:51 AM   #13
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I currently own a 2015 2500 6.0 six speed. I tow a 31' excella, and many other trailers. The 6.0 is not a diesel, but I can't tell my airstream is back there. It has no trouble, even with incline. Diesel is no doubt the best, if you tow often enough to justify the cost. If I were a fulltimer, or anytimer I may buy a diesel. I have no complaints about my 6.0 matched to the six speed transmission, for the amount of miles I tow.
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 01-21-2016, 09:59 AM   #14
1976 31' Sovereign
Oswego , Illinois
chev gmc 6.2 engines
I am also high performance person having built many dirt track flat track cycle race engs. and flat track race car engs.Not true that Gm only used aluminum 6.0 eng. in cars, cast iron in trucks & suvs. As 6.0 alu. eng. are used in 2500 pu as standered in 1999 and earlier with 3.73 std. gears. A 4.11 rear will out pull 3.73 but at lower gas mileage. My 6.0 avg. 10 mpg as my 1979 cast iron 454 w. 4.11 is 4 mpg....
Report on Chevy/GMC 1500 with 6.2 engine and Max tow pack DC Bruce Tow Vehicles 345 05-15-2018 06:23 AM
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 08:46 AM
GMC Sierra engine choices and more Distantdrummer Tow Vehicles 5 07-18-2010 01:46 AM
General motors/ Chevrolet Vortec motors vajeep Tow Vehicles 10 06-25-2004 07:23 AM
chevrolet HD owners check your brakes! john hd Tow Vehicles 6 03-11-2003 05:18 PM
