Old 01-25-2016, 06:07 AM   #29
dznf0g's Avatar
Oswego , Illinois
There are no rebuilt transmissions or engines installed under warranty. They are remanufactured.....two very different things. And, I believe you would find the same policy at most, if not all, manufacturers.
-Rich-
Old 01-25-2016, 09:54 AM   #30
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Chevrolet / GMC 6.0L Engine?
A properly rebuilt or remanufactured unit is every bit as good as new, and sometimes better than new.
Brevi tempore!
Old 01-25-2016, 10:18 AM   #31
1976 27' Overlander
Delta , British Columbia
I am not sure if you made your decision yet. I have a 2012 GMC 2500HD with the Cast Iron 6.0L, 4x4 Crew Cab with 6.5 foot box. I have the 3.73 rear end. I wrote all of the above because you need to be really careful with the GCVW, my truck as configured is 15,500 combined max trailer + truck. My truck at normal operating without family and camping gear weighs in just shy of 6900 lbs. this leaves only 8600 lbs for my trailer and all the gear. We normally pack, bikes, firewood dogs and 4 people. Last year we did a 2400 mile BC to Oregon round trip. I hit an unmanned commercial scale just to check and we were within 600 lbs of our GCVW while towing our 1976 Overlander. It is a shame, not sure really how the GVVW is calculated as my trailer axles totaled 5,500 lbs which seemed very reasonable. Just be careful is my point, my father has the same 6 speed, same 3.73's in a 2008 version which has less power and his GCVW is 700 lbs more than mine. I can't explain it. While travelling Southbound on I-5 we hit some short but decent climbs around Grant's Pass area, the truck and trailer will lose about 10-15mph, I used to have a 2004 6.0; with the 4 speed and it didn't really like to rev passed about 3500 rpm. This new version, will pull all day at 4500 RPM without moving the thermo 1 deg passed the 100 mark. Our Oregon trip was in the summer 2015 where the heat inland was in the 100-110 deg range. Be prepared as others have stated 10-10.5 MPG towing, and 13.5 MPG empty everyday driving. I took my last one to 210,000 miles before I sold it, I still see it driving around 3 years later. No major repairs, the old belt and I think a water pump.
They are good trucks but on steep grades you aren't going to hang with the diesel guys. I would recommend the 4.10 gears if you tow a lot, it also negates my entire ramble above on the GCVW issue.
Happy Trails
Seabloom is offline   Reply With Quote
Report on Chevy/GMC 1500 with 6.2 engine and Max tow pack DC Bruce Tow Vehicles 345 05-15-2018 06:23 AM
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 08:46 AM
GMC Sierra engine choices and more Distantdrummer Tow Vehicles 5 07-18-2010 01:46 AM
General motors/ Chevrolet Vortec motors vajeep Tow Vehicles 10 06-25-2004 07:23 AM
chevrolet HD owners check your brakes! john hd Tow Vehicles 6 03-11-2003 05:18 PM
