Old 07-15-2007, 02:42 PM   #29
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Since I don't know, I will ask
Originally Posted by nilesrob
... The only issue I have ... is finding a bike rack that supports the bikes from the wheels, versus the cross bars. ...
What is the advantage of supporting the bikes from the wheels?
Tom
Old 07-15-2007, 02:45 PM   #30
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Originally Posted by LI Pets
Do you mean the noise from the straps or the canoe?
The straps are tricky, too much twist is amost as bad none.
My canoe made no noise once I founf that out.
Bob,
We probably didn't play with the strap issue enough and had too many twists. One probably would have sufficed.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 07-15-2007, 05:38 PM   #31
nilesrob's Avatar
Marietta , Georgia
Images: 12
Tom
I was trying to do two things: 1) reduce the height of the bikes (visibility), and 2) avoid the problem of having bikes without cross bars.
I may have solved the second issue - just found that Thule and Yakima offer extendable bars that clip onto a bike lacking a horizontal croosbar.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 07-15-2007, 05:40 PM   #32
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Originally Posted by Happycampers
I got our front hitch from E-Trailer.com for about $100.00 and it just bolted on in about 15 min. We use ours to carry the canoe.
Do you go jousting with that?
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 07-15-2007, 05:51 PM   #33
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Why not just put the bikes in the trailer, in what for us is the bedroom area? If you're worried about grease all over everything, stick an old sheet on the beds before putting the bikes in. Problem solved. We have towed our trailers thousands of miles with the bikes in that position, with no problem at all. They are 26" adult touring bikes, not the fold up ones.
Old 07-15-2007, 06:11 PM   #34
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I carry mine, which is a tandem, on the front of my dodge truck. I got two 1 1/4" square recievers and mounted one on each forward frame support using u bolts. I then slipped a 1 1/4" square stock into each of the receivers and secured them with hitch pins. I mounted a 1"x3" channel aluminum on top of the square stock. The channel has a piece of 1 1/2" square tubing welded to each side to support the side load of the bicycle. This rig has carried the tandem bicycle up and down the east coast as well as to the west coast and back. It is easy to remove and very lightweight and fairly inexpensive to fabricate.
The idea came from the front end of the B Van as it has 2" receivers.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-15-2007, 06:23 PM   #35
Denis4x4's Avatar
Durango , Colorado
I have to chime in here about front/rear bike racks and the hitch platforms that add another 4' to the length of the vehicle. Just returned from a cruise with 21 other couples driving hot rods/muscle cars through Flaming Gorge, Jackson Hole, West Yellowstone and Cody.
The number of SUV/trucks with add on bike racks and platforms keeps increasing. Rigs thus equipped screw up parking and present a danger on streets with diagonal parking.
Instead of a cap over the bed of a pickup, use a hard cover with bike racks on the tonnau cover equipped with super HD lifts. Put 'em in your trailer or carry a 4' step ladder so you can put 'em on the roof.
Denis4x4 is offline   Reply With Quote
Old 07-16-2007, 10:51 AM   #36
2007 19' Safari
The Woodlands , Texas
We just returned from Bull Shoals AR. Before the trip, I installed a 2" front hitch I purchased online for $90. It was designed for a snow plow and was a direct bolt-on. Installed in about 15 minutes. I needed to mount the bikes on the front as we also carry our Kayaks and have them roof mounted.
The only negative for me was visibility. I used a Yakima 2-bike rack and they sat pretty high. I too am looking for a rack that allows them to sit lower.
64Vette is offline   Reply With Quote
Old 07-16-2007, 11:10 AM   #37
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Unhappy Be very careful
Hello... We had a near miss when we had our bikes mounted on the front receiver..... too scary.... please make sure your line of sight is not blocked... even partially...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-16-2007, 12:13 PM   #38
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
In case you missed this before...remove the bike seats. Forward vision will be vastly improved...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-16-2007, 01:05 PM   #39
1973 23' Safari
Maryville , Tennessee
Images: 13
So is there not a way to reinforce the bumper/rear frame to be able to accommodate a rear hitch bike rack? I would think two bikes and the rack would only add around 100LBS.
kneal is offline   Reply With Quote
Old 07-16-2007, 04:42 PM   #40
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
No way am I leaving my bike out there as a bug/whatever catcher. It travels INSIDE where it deserves to be. But it' a pretty serious bike.
Old 07-16-2007, 04:49 PM   #41
TomW's Avatar
1967 26' Overlander
Got a picture?
Originally Posted by Wayne&Sam
... But it' a pretty serious bike.
What's special about your bike?
If my Trek could not survive a bug splat or two I would be ... annoyed.
Tom
Old 07-16-2007, 04:52 PM   #42
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Bike Bug Catcher
Ditto. I have a Fold-a-Cover and a Bedrug bed liner. My bike lives there.
Vaughan
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow Vehicle Question-for a 34 ft, 3 axle Excella dmreilly10000 Tow Vehicles 26 08-02-2011 09:05 PM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
Chevy's new tow vehicle John Tow Vehicles 7 01-09-2003 01:07 AM
