Old 03-16-2011, 09:46 AM   #43
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Rick
That looks great very nice job. Why did you change to black and did you happen to find out what epoxy he uses or what kind of plastic the dash is made of
John
shepherd57 is offline   Reply With Quote
Old 03-16-2011, 04:45 PM   #44
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Originally Posted by Overlander & Sea View Post
Sorry guys, the green is going away, going back to the original color.
For the record, I did not go back with the original outside color. I went with a white, I thought it goes better with the dark blue I picked out for the stripe color.
Originally Posted by shepherd57 View Post
Rick
John
John,
Sorry, he would tell me what he uses for the repair on the dash & plastic covers. I went with black because the dash & door panels where originally black and black matches everything. I have not pick out the materials for the carpet, seats, cushions, etc. so, I did not want a blue dash that may not match the rest of the items.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 04-22-2011, 10:15 AM   #45
Images: 30
John,
Sorry, my post should have read "he would NOT tell me......"
A month later..........they painted the lower half navy blue.......
Name:	'75 Argosy Motorhome 066.jpg
ID:	127849   Click image for larger version
Name:	'75 Argosy Motorhome 067.jpg
Name:	'75 Argosy Motorhome 068.jpg
Old 04-22-2011, 10:23 AM   #46
Images: 30
Next, they painted the center white. We still need to install the mouldings and moulding inserts (black), access doors and all the compartment locks.
Name:	'75 Argosy Motorhome 069.jpg
ID:	127852   Click image for larger version
Name:	'75 Argosy Motorhome 070.jpg
Name:	'75 Argosy Motorhome 071.jpg
ID:	127854   Click image for larger version
Name:	'75 Argosy Motorhome 072.jpg
Old 04-22-2011, 04:41 PM   #47
Images: 30
A little detail on the outside mirrors. We painted the original mirror arms and purchased two new mirrors that are the same size as the original ones.
Name:	'75 Argosy Motorhome 074.jpg
Old 04-25-2011, 06:20 PM   #48
RivrCtyStrmr's Avatar
1969 18' Caravel
1978 20' Argosy 20
Richmond , Virginia
Fantastic progress! Thanks for the great pics. Nice upgrade on the mirrors. Where did you find them?
Steve
I scream, You scream, We all scream for Airstream!
RivrCtyStrmr is offline   Reply With Quote
Old 04-26-2011, 04:49 PM   #49
Images: 30
Steve
Thank you. The brand name on the mirrors is Velvac. I do not know if this brand was original, but they are still available. We ordered them from www.drillspot.com but the mirrors were shipped direct from Grainger. The new Velvac mirrors were a match to the ones that were on it.
About 95% of the trim is back on it, all the mouldings, moulding inserts, new locks, new lights and new lens, door handle, etc. A few problems, the rear clearance lights are blowing fuses, new fog lights are not working, and the batteries are going dead. I'll see if we can wash it tomorrow and post a few more photos. Thursday is goes to the glass shop for new windshields and window channel and seals.
Old 05-16-2011, 03:18 PM   #50
Images: 30
We did some of the screen door repair. The center section that was removed and flatten out & installed a new slide. The screen stills needs to be replaced. Also, installed a new porch light.
Name:	'75 Argosy 20' MH curb side door.jpg
ID:	129977   Click image for larger version
Name:	'75 Argosy Motorhome 085.jpg
Old 05-16-2011, 03:24 PM   #51
Images: 30
A few more photos, the rear tail light panel has been repaired and installed and all the mouldings with the black inserts are installed.
Name:	'75 Argosy Motorhome 083.jpg
ID:	129979   Click image for larger version
Name:	'75 Argosy Motorhome 084.jpg
Name:	'75 Argosy Motorhome 086.jpg
ID:	129981   Click image for larger version
Name:	'75 Argosy Motorhome 087.jpg
Old 05-16-2011, 08:24 PM   #52
sharbours's Avatar
1975 Argosy 24
West Linn , Oregon
Images: 11
It's so beautiful!!! You've done some amazing work.
I really like the shiny new paint job; it will be a while before we can swing that kind of expense. Hope you don't mind if I live vicariously through you for a little bit...
How is the interior coming along?
Sean & Sharon
AIR #: 27389
TAC #: OR-3
sharbours is offline   Reply With Quote
Old 05-17-2011, 05:44 PM   #53
Images: 30
Thank you!
We have not done any work to the interior, except the dash. I'll post some "before" pictures of the interior soon........
A few more things need to done to the to the outside first, window seals & weather strips & window channels.
Old 05-17-2011, 09:01 PM   #54
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
We were tent campers back in the 70s, and don't remember seeing the Argosys or Airstream motorhomes... I bet yours looks better than they did new.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 05-19-2011, 08:30 PM   #55
Images: 30
Items that were on (and still on!) the to-do list this week:
1. Wire the new porch light.
2. Replace both batteries.
3. Repair short in the rear clearance lights & install lights.
4. Check all the gauges on the dash.
5. Replace the speedometer. Found one on ebay-new GM in the box.
6. Install & wire 2 new lights on the step inside the door. The holes are there, but the lights are missing.
7. Install the outside A/C cover.
8 Repair the A/C-heat switch (or cable) on the dash A/C. This turns out to be a corroded heater valve (manual), which may also mean a corroded heater core-which would have been a lot easier to replace when the engine was out.
9. Reinstall the passenger seat.
work is slow, but steady................
Old 05-20-2011, 10:16 AM   #56
1969 18' Caravel
1978 20' Argosy 20
Richmond , Virginia
Congrads on your great progress. Paint looks awesome!
Would love to see how you address the heater/ac switch issue. Sometime would be great to have a 20footer meet up.
How to ship a Argosy?Loaded weight of a 22' Argosy outerbanksdeb Shipping & Export/Import 18 12-17-2011 10:53 PM
What Size Tow Ball On 77 Argosy 22? Zenflyr Hitches, Couplers & Balls 2 04-01-2008 11:26 AM
Can I tow my Argosy with a '82 Mercedes diesel? outerbanksdeb On The Road... 18 06-16-2006 09:26 PM
Argosy 24 MH Tow Capacity Question outbound Argosy Motorhomes 3 03-14-2004 11:35 AM
Tow vehicle for 28' argosy TT 1978 Lovecraft Tow Vehicles 8 11-30-2003 06:49 PM
