Old 10-05-2013, 04:29 PM   #1
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Can you do some math for me?
So we took our newly remodeled '62 Tradewind to the scales yesterday and weighed the TV, the Tradewind + TV, and then just the Tradewind, all while hitched.
TV: 5200 lbs
TV + Trailer: 8440 lbs
Trailer: 3300
Remember, this is all while hitched.
THEN we weighed just the TV (unhitched):4640
Is it possible to calculate the tongue weight from these numbers? How accurate is the trailer weight and do I need to add the tongue weight to the total trailer weight registered on the scales?
Please help this right-brainer!
aluminitus is offline   Reply With Quote
Old 10-05-2013, 04:36 PM   #2
1977 Argosy 24
Milltown , Wisconsin
I think you need the weight of the TV without being hitched and the trailer without being hitched. Then I think you figure it out.
ventport is offline   Reply With Quote
Old 10-05-2013, 05:26 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Tongue weight...
You can also use the scales to set the weight distribution.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-05-2013, 05:30 PM   #4
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Tongue weight is probably approximately 560# if you had no WD bar tension and the ground was level with the scale while weighing trailer & truck individually while connected.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 10-05-2013, 06:13 PM   #5
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
How would a weight dist. hitch change the tongue weight? We hope to get a pro-pride...can it actually lessen the weight on the tow vehicle? It seems like that would go against the laws of physics, but then again I am terrible at that kind of thing.
Old 10-05-2013, 06:24 PM   #6
Wink
It doesn't change the TW, it just re-distributes it forward to the steering axle and back to the trailer axle/axle's.
Tickets...Left to right
No weight dist, WD set for towing, TV alone.
Note with WD set the steering axle is with-in 100lbs of its un-hitched weight. Also note the difference in the AS axle weights with and without WD set. I use a Hensley Arrow hitch.
Name:	CAT Weights.jpeg
ID:	197154   Click image for larger version
PFC
"Tahawus"
RLC
John Prine
Old 10-05-2013, 06:32 PM   #7
2002 25' Safari
Images: 11
What Bob said X2.
Bud
Old 10-05-2013, 06:37 PM   #8
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Okay I think I've got it. Bob, can you explain what those receipts are for? Are the first two without and then with a WD hitch?
Old 10-06-2013, 06:43 AM   #9
Thumbs up
Those are CAT Scale tickets....
Steering axle on the first scale plate, drive axle on second, trailer axle/axles on the third.
The first is tow vehicle & trailer without weight distribution set.
The second is TV & trailer with WD set for towing. (you may have to get several weights to determine this setting).
The third is tow vehicle alone, full fuel, two peoples, and a dog.
The goal being to replace as much of the non-towing steering axle weight as possible while keeping the trailer and tow vehicle LEVEL!!.
I could replace that last 100lbs by tensioning the WD bars more, but that would raise the tongue and lower the rear bumper of the trailer, causing more weight to be transferred to the rear axle of the Airstream...NOT good!!
Remember....trailer LEVEL while towing.
Important for the TV also...don't want the headlamps searching for bats.
Good Luck...
PFC
"Tahawus"
RLC
John Prine
Old 10-06-2013, 08:49 AM   #10
2002 25' Safari
Images: 11
Alumnitis, we ended up buying a Propride about a year ago after owning a Reese dual-cam and an Equalizer brand hitch. We have been extremely happy with the Propride.
Bud
Old 10-06-2013, 12:03 PM   #11
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Thank you all so much for your help! I think we are pretty settled on a v6 Grand Cherokee with a propride WD hitch. I really felt like I was drowning in a sea of information and didn't know where to start. You all have helped to break it down into much more manageable chunks and I am really starting to understand what needs to happen to hit the road.
