Old 06-25-2007, 10:46 PM   #57
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
If you do get a 4X4 be sure to get a limited slip rear end. I have both. Other wise you are only really two wheel drive in four wheel mode.
Be sure to cycle your hubs regularly. I do after every fillup. Otherwise they stick.
Michelle TAC MT-0
Sarah, Snowball
Old 06-26-2007, 09:11 PM   #58
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Yep, been there, done that. My '92 Z71 had an open rear end differential and one time I traversed a ditch. This left me with one tire on the front and the opposite tire on the rear on solid ground. Nothing moved as each tire slightly touching the ground would not get traction. I finally was able to rock her a little to get some traction and move through. My '01 2500hd has a G80 locking rear end which has worked flawlessly.
Does Ford still have a limited slip front end option to match their rear end limited slip?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-26-2007, 09:34 PM   #59
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Welcome to the forums!
I have a 25FB. I can tell you from experiance that a 3/4 is a breeze compared to my previous 1/2 ton.
Be safe and get the right vehicle.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 06-27-2007, 07:07 PM   #60
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Thumbs up thats the machine
I'm thinking the GMC 2500 with the Duramax 6.6L Turbo Diesel V8 with the Allison 1000 6-Spd transmission and the integrated trailer brakecontroller
Well blow us away - thats the primo - Good luck and happy trails
Pop Rivet is offline   Reply With Quote
Old 06-27-2007, 07:13 PM   #61
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I think a GMC 2500 w/ Duramax and Allision would be great, but as a kid that grew up camping (and from what I read, you have young ones) with the way back availible to us in the Suburban, I would think twice about going with a pickup based on my exp. I know that the new vehicles all have DVD player and such, but at some point kids like to play and that way back area was king for us....gave my parents many thousands of miles of peace, since we didn't have DVD players or Game Boys to plug in.
Your mileage may vary.
Old 06-27-2007, 07:55 PM   #62
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
We have two boys 11 & 8 and our crew cab F250 has tons of room for us. The boys are very accustomed to traveling in our mini van and have adjusted very well to the pickup. Yes we did get the DVD system and yes they do have their game boys and such. So far its working for us.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 06-27-2007, 09:27 PM   #63
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
Thanks guys for all your suggestions and comments....
I guess it's a toss up between the GMC and the Ford....everyone has their favorite...
bottom line is... both will do the job.
I'm gonna take my time (this time) and test drive both this weekend and base our decision on comfort and style!
Buying our Airstream is the best thing we ever did for our two boys age 7 and 9. Gonna have fun fun and more fun this summer.
Thanks again!
millvalleyca is offline   Reply With Quote
Old 07-03-2007, 10:47 AM   #64
Well we did it! We traded our Yukon XL for a Ford F250 with a diesel engine.
We're headed to Disneyland next weekend....can't wait to try it out.
Next question......
The hitch set up.
Do you think we'll have to adjust the height? I just spoke to the AS service dept. and they said there are several height adjustments on our hitch.
The Yukon was pretty high off the ground but the Ford is really high off the ground. To avoid frustration....any suggestions? Lower the ball one notch?
Thanks again for all your help and comments.
Old 07-03-2007, 11:47 AM   #65
_
congrats millva' on the new truck!
07 or 08?
that new 08 is one sweet truck...
http://www.airforums.com/forums/f463...now-30023.html
you might get more specific help by offering up the hitch brand/model.
no doubt the drop will be different
and with the 3/4 ton suspension less weight distribution is needed.
so depending on brand/design that may require new spring bars, or less tension on the current bars.
as i recall ford suggests 500 miles of break in b4 towing.
mine got about 3k of exercise before hitch'n up...
enjoy and safe travels!
cheers
2air'
Old 07-03-2007, 12:19 PM   #66
Thanks 2air' for the quick response.
We got a 2008.
I'll get the info tonight on brand/model of the hitch. I think it's a Robin hitch but I don't know the model. The dealer set everything up the first time around. The bottom line is to get the trailer "as level as possible" and be able to get the ball to a height where the trailer will attach itself to? What are spring bars??
The next thing we're gonna have to figure out is the setting for the brake controller!!! any ideas?
Old 07-03-2007, 12:41 PM   #67
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
A word of caution with your new TV. Watch your speed.
You won't have any problems with power as you mentioned in your earlier posts.
This truck will give you a much more enjoyable towing experience. It's easy to forget the trailer is behind you.
I use Tow/Haul mode anytime the trailer is attached and use cruise control whenever I can.
Enjoy.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 07-03-2007, 01:03 PM   #68
dpandorf's Avatar
2000 34' Limited
We got a 2008.
The Ford F250 Manual describes the basics on setting up the integrated brake controller. (I assume the F250 you selected has this installed and you're not talking about an after market model) Basically you want to set the controller so that the trailer brakes come on before the truck brakes do. If the truck brakes come on first you would feel a bump from the trailer.
Duane Pandorf
Blog | Google+
Old 07-03-2007, 04:04 PM   #69
Keymar , Maryland
My manual stated I need to break in for at least 500 miles before towing. Furtunately it was a dealer transfer and had nearly that before it got to me.
You will most likely have to adjust the height. I did even going from an 04 F250 to and 06 F-250. The o6 is higher and I need to drop the head to the bottom of the shank.
Did you get the factory installed tow package with tow comand?
Your towing supplement should have the info on setting the tow comand. Mine is set to 6.0 for my electric hydraulic brakes.
Michelle TAC MT-0
Sarah, Snowball
Old 07-04-2007, 10:29 AM   #70
The steel bars of the load distribution hitch. I presume you now have one of these. Come back to us if you're not sure. Putting "load distribution hitch" into the search box at the top of the screen will give you more information than you thought you needed.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Sovereign weight and Preferred tow vehicle JLD 1974 - 1979 Sovereign 24 06-26-2017 10:17 PM
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
Tow Vehicle hrnicho Tow Vehicles 0 09-04-2002 02:17 PM
Tow questions ALANSD Airstream Motorhome Forums 3 05-28-2002 09:51 AM
Towing a small 60s trailer with a SUV... Andy R Tow Vehicles 15 03-30-2002 07:57 PM
